YAMAHA DSP AX1 6x110rms
Πωλειται πολυκαναλος ενισχυτης που ειχε πανω απο 1 εκατομμυριο δραχμες σε αριστη κατασταση και τιμη χρωμα μαυρο.Πολλα ρευματα για δυσκολα ηχεια!
Τιμη 370 ευρω!
Specs:
Power output: 110 watts x 6 & 35 watts x 2 (8 ohms, RMS)
Decoders: Dolby Digital Matrix 6.1 EX, DTS ES, Dolby Digital, DTS, Dolby Pro Logic
DSP modes: 54 hifi and home cinema preset options
Video inputs & outputs: 4 x video inputs (with S-video, composite and stereo audio), 3 x video loops (with S-video, composite and stereo audio), 2 x S-video monitor out, 2 x composite video monitor out, zone 2 composite video and stereo audio out, 3 x component video in, 1 x component video out
Audio inputs: 7 x optical, 3 x coaxial, 1 x AC3 RF coaxial, phono, 2 x tape loop, 2 x line level, 6 channel external decoder in,
Speaker outputs: 2 pairs (switchable) stereo audio, front centre, rear centre, rear stereo, front effects 4mm banana/binding posts
Audio outputs: Headphones, pre-outs for: front, rear, centre front and centre rear, stereo subwoofer and mono subwoofer; main & centre in/out pre/power loop, optical output
Remote control: Yes, backlit display, 563 key learning ability, 15 programmable macro sequences (up to 10 events each)
On screen display? Yes
Dimensions WxHxD / Weight: 471 x 211 x 473 / 28 Kg
Supplied accessories: Learning remote control, batteries.
Extra: RS232C computer interface, ten channel multi-bit Burr Brown PCM170A DACs, all-source record output selector.
opanamas
