Yamaha DVD-S1700
Πωλειται σε αριστη κατασταση 200e. Δεκτη ανταλλαγη με Blu ray συν διαφορα απο μερους μου. (Δεν υπαρχει δυνατοτητα αποστολης εκτος Αθηνας)
Yamaha DVD-S1700 Specs
HDMI output including 1080p video out
DVD-Audio and Super Audio CD playback
Progressive Scan (PAL/NTSC)
Audio Direct mode
Noise Shaped Video
Faroudja DCDi™ processing
MP3, JPEG, DivX� and WMA playback
Bass Management
RS-232C interface for a touch-panel controller
Wide screen mode selection
216MHz/12-bit video DAC
192kHz/24-bit audio DAC
On-screen display with GUI
Gold-plated terminals for all pin jacks
Video picture mode: Brightness, Contrast, Hue, Sharpness, DNR, Gamma, Chroma Level, Chroma Delay and True Life
Picture CD playback
3-step dimmer modes
PAL/NTSC complete conversion
Multiple repeat play
Programme play
Screen saver
Aluminium front panel
Discrete remote control commands
Playback
DVD, DVD+R/RW, DVD+R Dual Layer, DVD-R/RW, DVD-Audio
SACD, Audio CD
CD-R, CD-RW
VCD, SVCD, DivX
Kodak Picture CD, JPEG
MP3, WMA
Dolby Digital, DTS Digital Surround
Film Mode
Video DAC: 216MHz/12-bit
192 kHz/24-Bit-D/A-Convertor: Cirrus Logic CS4382 1x 6 Channel D/A Wandler
Faroudja DCDi: FLi 2310
Progressive Scan: PAL/NTSC
NSV - Noise Shaped Video
On-Screen Display
GUI - Graphical User Interface
Frequency Response: 2Hz – 44000Hz
Signal-to-Noise Ratio: 115dB
Harmonic Distortion + Noise: 0,002%
Dynamic Range: 105dB
Connections
Coaxial digital output: x1
Optical digital output: x1
Composite video output: x1
S-video output: x1
Component Video output: x1
HDMI: x1
SCART Terminal: RGB
Video scaler: Only HDMI: 576p, 720p, 1080i, 1080p
6-Channel Audio Output
Outputs - others: 1x mixed 2-channel audio
Subwoofer Output Terminal
Power Consumption: 21W
Standby Power Consumption: <0,5W
Remote Control Unit
Dimensions (W x H x D): 435 x 87 x 285 mm
Weight: 3,3 kg
Color: black
Απάντηση: Yamaha DVD-S1700
Το player υπαρχει ακομα. Δεν ισχυει το ενδιαφερον για blu ray. Δεκτες προτασεις ανταλλαγης με καλωδιο ρευματος, tuner, πικαπ, subwoofer.
who7
