Yamakawa 625 dvd recorder
Χρήστος Ακρατόπουλος
The new Yamakawa DVD Recorder DVR-625 has smashing features at a very attractive price.
The DVR-625 not only is a DVD Recorder with many editing and programming functions, it is also a full featured DVD player with built in Dolby 5.1 Decoder and Progressive Scan for flickerfree pictures in connection with modern high resolution TV systems.
Using the four selectable quality levels, you are able to record up to 6.5 hours on a normal DVD+R/RW disc. The DVR-625 automatically formats the disc when recording. The remaining recording time will be adjusted depending on the selected recording quality. With only a few commands you can programm recording sessions from the internal TV tuner, since the DVR-625 is using the VPS programming system. For every programmed recording session, you can individually select the recording quality and source.
The DVR-625 is equipped with a large variety of audio and video connections. Behind a little door in the front panel you can even find a digital video DV connector for convenient recordings from your digital video camcorder. As a very unique feature the DVR-625 even offers a USB Interface for easy connection of USB devices like digital cameras and MP3 Players.
On the backside of the DVD recorder, there are three video inputs, four video outputs and analog audio input (2) / output (6) connectors as well as two digital audio outputs. This large number of connectors guarantee an easy and optimized integration of the DVR-625 into your home entertainment equipment.
Through the SCART input connector e.g. signals of a DVD player can automatically be passed through to your TV set, if that does not have enough direct input connectors.
Similar to the Yamakawa DVD Players, the DVD Recorder DVR-625 is equipped with a stunning media and data compatibility. Almost every combination of data and disc type can be played on the DVR-625. Even DVD-R/RW or DVD+R/RW media with MP3, WMA or JPEG data, do not cause problems for this multi talented device.
The DVR-625 is available at a SRP of
€ 249,- incl. VAT starting from August.
Features:
* writeable media: DVD+R, DVD+RW
* readable formats: DVD, CD, MP3, JPEG, WMA, VCD, SVCD, Kodak Picture CD
* readable media: DVD, CD, CD-R/RW, DVD-R/RW, DVD+R/RW
Recorder Features:
* One-Touch recording function
* Timer for daily, weekly, mondays -> fridays, with 1 year preprogramming time
* Four quality levels HQ, SP, EP, SLP (1/2/4/6.5 hours MPEG2) on a 4.7GB Disc
* Disc auto-formatting during recording
* Edit and delete functions - recorded sequences may be seperated and segments (e.g. commercials) can be deleted
* automatic display of remaining recording time depending on selected recording quality
* recording programming with quality and source selection
TV-Tuner
* Analog PAL/SECAM Tuner
* 181 programmable channels
* VPS / PDC programming system
* auto-set clock
Connectors:
* Front inputs: USB, DV (IEEE1394, digital Video)
* Rear inputs: SCART, S-Video, Video, Stereo L/R
* Read outputs: Component Video (YUV), SCART, Digital Audio coaxial and optical, S-Video, Video, Stereo L/R and additional 6 x audio analog (Dolby 5.1)
* Signal (e.G. a DVD player) passthrough via SCART input/output also during standby
Audio/Video formats:
* Dolby Digital 5.1 Decoder – 6 analog outputs for home theatre sound systems
* 24bit 96 KHz Audio DAC
* TV-System: NTSC, PAL, AUTO
* TV Format: 4:3, 16:9
Progressive Scan for flickerfree pictures via SCART and YUV output with PAL and NTSC
Πιστεύω πως σε αυτή την περίπτωση θα πηγαίνει το "ότι πληρώνεις παίρνεις"......
Πιστεύω δηλαδή ότι ο encoder του θα είναι προβληματικός ή τουλάχιστον κακής ποιότητας.
panaplio
