Το αρχείο για να κάνετε την δοκιμή είναι στην παρακάτω διεύθυνση:- Place it on USB stick, put the stick on TV and play it. Panasonic VT owners needs to play it from other external device (BD player) to be able to enable the 3D mode.
- Enable 3D and choose the side-by-side mode and open 3D glasses.
- In the middle of the video press pause.
- First close your right eye and write the smaller number which is visible on the top half screen and then write the smaller number which is visible on the bottom half screen
- Do the same procedure then with the left eye closed.
http://www.box.net/shared/lpe35vy1h8
Αναφέρετε τα αποτελέσματα όσοι θέλετε..
Πηγή:
http://www.avforums.com/forums/3d-p...h-crosstalk-ghosting-has-your-3d-tv-test.html
