Samsung Galaxy Note 4, QHD OLED display
gkontoletas
trouble in my brain
πήρε τα σκήπτρα της καλύτερης οθόνης σε φορητή συσκευή ξεπερνώντας τα Galaxy Tab S και Galaxy S5...
With the Galaxy Note 4 there are many significant improvements over the Galaxy Note 3 that we tested a year ago, but also with the Galaxy S5 that we tested in March, and the Galaxy Tab S that we tested in June. The most impressive improvements are in the pixels per inch and resolution, the Absolute Color Accuracy, Peak Brightness and screen readability in High Ambient Light, and display Power Efficiency. See the main Display Shoot-Out Comparison Table for all of the measurements and details.
Based on our extensive Lab tests and measurements, the Galaxy Note 4 is the Best performing Smartphone display that we have ever tested. It matches or breaks new records in Smartphone display performance for: Highest Absolute Color Accuracy, Highest Screen Resolution, Infinite Contrast Ratio, Highest Peak Brightness, Highest Contrast Rating in Ambient Light, and the smallest Brightness Variation with Viewing Angle. Its Color Management capability provides multiple Color Gamuts – a major advantage that is not currently provided by any of the other leading Smartphones. The Galaxy Note 4 delivers uniformly consistent all around Top Tier display performance: it is the first Smartphone display to ever get all Green (Very Good to Excellent) Ratings in all test and measurement categories (except one Yellow for a Brightness Variation with Average Picture Level) since we started the Display Technology Shoot-Out article Series in 2006, an impressive achievement for a display. The Galaxy Note 4 has again raised the bar for top display performance up by another notch.
http://www.displaymate.com/Galaxy_Note4_ShootOut_1.htm
gkontoletas
trouble in my brain
Ακόμα μια πρωτιά για την AMOLED οθόνη του Note 4, αυτή τη φορά η σύγκριση αφορούσε την πιστότητα των χρωμάτων...
We used the Color Accuracy Measurements from Table 1 above to generate an ordered 1 to 6 Ranking of the displays in each Color Accuracy category to help identify the Best of the Best, which is shown in the Table below. When the color accuracy values are fairly close we labeled them as a Tie with abcd according to their actual pecking order. Here are the results…
1. The Samsung Galaxy Note 4 is the winner in Absolute Color Accuracy, coming in first place in all categories for its Basic Screen Mode setting.
2. The Microsoft Surface Pro 3 and the Samsung Galaxy Tab S 10.5 are tied closely for overall second place.
One particularly interesting and significant result is that the Apple iPhone 6 Plus and iPad Air 2 perform considerably better in both the very important Skin Tone and Organic Color Accuracy categories, with the iPad Air 2 coming in a solid second behind the first place Galaxy Note 4. Its seems likely that Apple has concentrated on the important Red to Green part of the Color Space, which includes both the Skin Tone and Organic Colors. On the other hand, both the iPhone 6 Plus and iPad Air 2 are in last place for the Full Gamut Color Accuracy. This is partly the result of an over saturated Blue primary that distorts almost the entire Blue Region, which accounts for about half of the half of the entire Color Space and increases the Average Color Error, and also partly due to the less accurate bluish White Point. The iPhone 6 has very similar Color Accuracy performance to the iPhone 6 Plus as shown here.
The Amazon Kindle Fire HDX 8.9 winds up being squeezed between these two major Color Accuracy trends and comes in between 4th and 6th place. When we originally tested it in November 2013 it captured first place in Color Accuracy. It is still very good, but has slipped because overall Color Accuracy has been steadily improving over the last year. We hope to test the new 2014 model in the near future.
http://www.displaymate.com/Color_Accuracy_ShootOut_1.htm
melina
Cargo 200
Κάποιος φίλος που να το έχει (ή αντίστοιχου μεγέθους) και να έχει καταλήξει σε κάποια καλή βάση για το αυτοκίνητο, κατά προτίμηση όχι με βεντούζα κάτι που να πιάνει στους αεραγωγούς.
Βασίλη, τσέκαρε τις Brodit. Είναι ό,τι καλύτερο: http://www.brodit.com/
Επίσης τσέκαρε και την Kenu Airframe+. Μπαίνει στους αεραγωγούς και δουλεύει τέλεια (έχω την Airframe που είναι για πιο μικρά τηλέφωνα). Θα τις βρεις στο Amazon αλλά παίζει να τις έχουν και στην Ελλάδα. Εγώ την είχα πάρει από Ηχοκίνηση.
http://www.kenu.com/products/airframe-plus
melina
Cargo 200
Ευχαριστώ Γιώργο.
Παρήγγειλα τη Kenu να τη δοκιμάσω. Οι άλλες από ότι φαίνεται έχουν και αυτοκόλλητο και φοβάμαι ότι αν θέλω να τη βγάλω μετά θα αφήσει και σημάδια-κόλλες (σε δύσκολο σημείο για να βγουν) και ίσως παραμορφωθεί και μόνιμα το πλαίσιο εκεί που θα μπαίνει. Το airframe+ αν αντέχει το βάρος του τηλεφώνου και δεν είναι χαλαρό πολύ φαίνεται πιο sick λύση.
Για να δούμε.
Μελίδης Μιχάλης
Πρόεδρος ΕΒΒΕ
Ρε παιδιά για ποιο λόγο κάνουν αυτά τα τεστ λυγίσματος στα κινητά;
Δηλαδή αν έχεις κινητό και το βάλεις στην κωλοτσέπη και κάτσεις επάνω του και λυγίσει δεν είναι γερό;
Ε μην κάθεσαι επάνω του.
Αμάν πια, κριτήριο για την αντοχή του.
melina
Cargo 200
σήμερα τα κινητά Μιχάλη είναι συσκευές πολλαπλών χρήσεων, δεν τηλεφωνείς μόνο με αυτά...πρακτικά η φαντασία του καθενός είναι το μόνο όριο, οπότε ποτέ δεν ξέρεις σε τι θα χρησιμεύσει, άλλος μπορεί να ξεχαστεί και να κάτσει πάνω του και άλλος...να το κάνει επίτηδες :whistling: :laugh::laugh::laugh:
melina
Cargo 200
Το έχω κάμποσες μέρες τώρα αλλά μόλις χθες του έβαλα SIM και σήμερα το έβγαλα την πρώτη βόλτα μαζί μου.
Δεν έχω παρατηρήσει τίποτα το αρνητικό μέχρι τώρα, ειδικά θέματα τύπου lag που ακούγονται.
Απεναντίας το βρίσκω πάρα πολύ έξυπνο και για κάποιον που είναι συνηθισμένος στο android θα το ευχαριστηθεί. Το πενάκι είναι όλα τα λεφτά και ειδικά το handwriting!!
Παράλληλα με το νέο τηλέφωνο έβαλα και νέο bluetooth το plantronics voyager edge. Αυτό έχει πολλές έξυπνες λειτουργίες, όπως να σου λέει ποιος καλεί, να παίζει τη μουσική στο αυτί σου από το κινητό, έξυπνους αισθητήρες και διάφορα άλλα....μόνο που δεν έχω καταφέρει να το δουλέψω σωστά ακόμη στην απλή του λειτουργία :oops:, όταν με καλούν ενώ με ειδοποιεί και μπορώ να δεχτώ την κλήση όταν ανοίγει η συνομιλία δεν έρχεται ο ήχος στο ακουστικό αλλά μένει στο τηλέφωνο. Πρέπει να πατήσω το headset στην οθόνη για να ενεργοποιηθεί ο ήχος στο ακουστικό ξανά. Δεν μπορώ να βρω ποια ρύθμιση του φταίει ακόμη. Μόλις τώρα έκανα και μια τελευταία δοκιμή, να είναι συνδεδεμένο μόνο ως phone audio, όχι και ως media audio, για να δω αν θα αλλάξει συμπεριφορά. :idk:
melina
Cargo 200
Κατά τη γνώμη μου οι κατασκευαστές έχουν πάρει ένα λάθος δρόμο...όπως παλιά ανταγωνίζονταν ποιος θα φτιάξει το πιο μικρό κινητό με αποτέλεσμα συσκευές δύσχρηστες ως άχρηστες έτσι και σήμερα παραγκωνίζονται για το ποιος θα φτιάξει την πιο λεπτή συσκευή.
Οι πολύ λεπτές συσκευές είναι εξίσου δύσχρηστες, δεν μπορείς να τις πιάσεις σωστά/στιβαρά στο χέρι σου, σε προδιαθέτει για ένα χαλαρό και σημειακό πιάσιμο με αποτέλεσμα την υψηλή πιθανότητα να σου πέσει και σου προκαλεί δυσφορία η ανασφάλεια στο πιάσιμο.
Θα μπορούσαν κάλλιστα οι λεπτότερες συσκευές να είναι το ελάχιστο στα 10-12mm, και καλύτερο πιάσιμο θα είχαν και μεγαλύτερη μπαταρία και δεν θα προεξείχε ο φακός της κάμερας.
Σε μέγεθος οθόνης, καταλήγω σε 2 μεγέθη, ένα γύρω στις 4.5" για χρήση κυρίως ως τηλέφωνο και messaging και ένα στις 6" για πιο επαγγελματική χρήση ως mini tablet που το έχεις πάντα μαζί σου.
my 2 cents
  • Like
Reactions: PPG
gkontoletas
trouble in my brain
Νέο μοντέλο του Note 4 ανακοίνωσε η Samsung, οι διαφορές με τα άλλα 2 που ήδη κυκλοφορούν εντοπίζονται στον επεξεργαστή και στο LTE modem.
Tο νέο Note 4 έχει Snapdragon 810 και LTE-A cat 9 για ταχύτητες έως 450Mbps.
http://global.samsungtomorrow.com/s...nced-tri-band-carrier-aggregation-smartphone/
melina
Cargo 200
Εκανα ένα update πριν λίγο και νομίζω ότι πάει extraσφαιρα το εργαλείο. Κάποιος άλλος που να το έκανε;
  • n_olympios
    Μαντιναδόρος!
geo kok
