WWDC 2015
xfader
Χθες έγινε το Worldwide Developers Conference του 2015. Περιληπτικά οι νέες παρουσιάσεις:
* OS X 10.11 El Capitan
The latest version of Apple’s OS X software, El Capitan takes over from its predecessor in Yosemite and ratchets everything up to eleven. Split View, Improved Spotlight functionality, under the hood technology for things like gaming should ensure El Capitan receives a warm welcome when the public beta begins next month.
* iOS 9
Following on from last year’s iOS 8, the new iOS 9 software brings with it improved Siri support, Proactive Assistant, actual split-screen multitasking on iPad Air 2 and a new side panel on older versions of the iPad that allows users to interact with two apps simultaneously. Apple also needs iOS 9 to pave the way for watchOS 2, which will take the Apple Watch to new heights. Siri also received a new lick of paint, though that may be doing it a disservice.
* Apple Pay
Apple Pay is finally breaking out into Europe, with Cupertino’s payment service reaching the United Kingdom next month. Those in the U.S. also now have support for reward cards and more financial institutions, too. A new Square accessory for use with Apple Pay was also announced.
* watchOS 2
Potentially the biggest news out of WWDC’s opening keynote bar the iOS 9 iPad multitasking bombshell, watchOS 2 brings with it native apps and a raft of improvements including a Nightstand mode that allows the Apple Watch to act as an alarm clock when needed.
* Apple Music
The much rumoured Apple Music is here, or at least it is at the end of the month. Bringing with it a streaming service that offers a free three month trial, Apple Music is more than just a streaming service and hopes to bring exclusive content and added value to the music industry.
Gojakla
Αρχαιολάγνος πιουριτανίστας
* Apple Music
Έχουμε πληροφορίες για δαύτο?
xfader
Αντιγράφω από το Techblog.gr:
Από το WWDC 2015, η Apple μαζί με το νέο iOS 9 και το OS X El Capitan, ανακοίνωσε και επίσημα ότι μπαίνει στην αρένα των υπηρεσιών music streaming. Από το iTunes που αποτέλεσε πλήγμα για την βιομηχανία των CD, αλλά αντιμετωπίζει ανταγωνισμό από την νέα πραγματικότητα του music streaming, πηγαίνει στο Apple Music για να ανταγωνιστεί εφαρμογές όπως το Spotify.
Όσοι χρησιμοποιούν το Beats Music θα μπορούν να μεταφερθούν εύκολα στο Apple Music και όταν αγοράζεις μουσική στο iTunes, η Apple θα σε παραπέμπει να εγγραφείς στη νέα μουσική υπηρεσία. Το iTunes Radio από την άλλη, θα αλλάξει και θα γίνει σταθμός με ζωντανό περιεχόμενο με guests DJs, όπως Zane Lowe, Pharrell, Drake, Muse και David Guetta.
Το όνομα του πρώτου ραδιοφωνικού σταθμού της Apple θα είναι Beats 1 και θα είναι από την αρχή διαθέσιμος σε 100 χώρες. Στην νέα μουσική εφαρμογή, θα υπάρχει ένα section με την ονομασία Connect, με το οποίο θα μπορείς να ακολουθείς έναν αγαπημένο καλλιτέχνη και να βλέπεις τα updates του στα κοινωνικά δίκτυα.
Η εφαρμογή Music έλαβε και αυτή τον δικό της ανασχεδιασμό, με ένα mini player να πετάγεται στο κάτω μέρος της οθόνης και να δείχνει τι παίζει εκείνη την στιγμή, το οποίο θα μπορείς να κάνεις swipe away κατά βούληση. Επίσης θα έχει album art το οποίο θα κάνεις swipe up για να το δεις και ένα νέο section fresh For You, στο οποίο θα λαμβάνεις προτάσεις, ανάλογα με τις προτιμήσεις σου. Επιπλέον, το app θα είναι γεμάτο μουσικά videos τα οποία μπορείς να παίξεις από εκεί με πολλά από αυτά να είναι σε HD ποιότητα.
Η νέα υπηρεσία streaming μουσικής, Apple Music θα κοστίζει 9.99 δολάρια τον μήνα ή 14.99 αν θέλεις άδεια για μέχρι 6 μέλη της οικογένειάς σου. Η υπηρεσία θα είναι διαθέσιμη με το iOS 8.4 που θα έρθει στις 30 Ιουνίου. Το φθινόπωρο θα είναι διαθέσιμη και η αντίστοιχη εφαρμογή για Android.
Και ένα έξτρα στοιχείο από το Wired:
Siri’s a big part of the interface: You can ask her to play her favorite Bruce Springsteen song, or that song from that movie that one time, or the best songs from 1988. You can see music videos, artist pages, and lots and lots of recommendations of new stuff you might want to listen to.
Gojakla
Για το είδος των αρχείων δεν έχω διαβάσει πουθενά τίποτις...
xfader
Δεν έχει ανακοινωθεί επισήμως τίποτα ακόμα. Το trustedreviews έχει μία προσέγγιση:
What quality does it stream at?
Here’s the big one. Apple mentioned nothing about streaming quality, something every digital music fan should care about, at least a bit.
Our first assumption: it’s not lossless. Not only would Apple be shouting if Apple Music were lossless, it would also make launching in 100 countries globally on 30 June more of a risk. Lossless audio takes up several times the data of lossy audio, even when using a clever codec. That's some serious server strain.
But what quality could it be? There are a few clues.
First, there’s what iTunes sells as standard. It uses 256kbps AAC files, including streaming from iTunes Match. This is what Apple already has ‘on file’, if you like. Of course, streaming 30-million-strong audio tracks and dealing with smaller Match libraries are different, so perhaps we should be looking at Beats Music instead.
Apple bought headphone-peddler Beats back in 2014. And as well as owning the most popular headphone brand around, it has a streaming service. It’s called Beats Music.
Beats Music offers downloads at 320kbps using the kinda-dated MP3 format and uses HE-AAC at 64kbps by default for mobile streams. If Apple Music uses this, and it may well do given iTunes uses standard AAC, it’s not great news for music fans.
HE-AAC is incredibly efficient and will sound leagues better than a 64kbps MP3 file, but it’s not as good as the array of OGG settings you can pick in Spotify. What it does is to chop out the bits your ears won’t notice, optimising in particular the upper end of the frequency spectrum. Version 2 of HE-AAC also uses parametric stereo, which turns the stereo track into a mono feed, but adds a tiny bit of dedicated data that allows the stereo effect to be restored before it hits your ears.
Are there any future plans for lossless?
If Apple Music is to use Beats Music’s quality options, there’s a lot of room for improvement, and plenty of scope for Apple to move into lossless audio. No doubt with a price hike.
iTunes has showed fairly little interest in lossless audio to date, though. Until 2009 it sold 128kbps AAC files, before upgrading to 256kbps AAC with the iTunes Plus initiative.
Apple made its own lossless codec years ago, ALAC, but if it does end up offering lossless streams you can bet it’ll come up with something more efficient that that. One contender is Meridian Audio’s MQA, a high-efficiency compression method that can be used with both lossy and lossless content.
But now we’re just speculating.
Read more at http://www.trustedreviews.com/opinions/11-things-we-don-t-know-about-apple-music#f4yUGWPUibFfG1Sv.99
Gojakla
Επαναστατήσανε και πάλι δλδ... :roflmao:
xfader
Οι παροχές πλέον καθορίζονται από το τι θέλει ο μέσος υποψήφιος πελάτης και το βαθμό ευκολίας/κόστους του κάθε έξτρα χαρακτηριστικού.
Η καλύτερη πιστότητα του ήχου, σε σχέση με το τρέχον επίπεδο, απασχολεί μονοψήφιο ποσοστό ακροατών.
    Chauncey Gardiner * tl;dr *
mdim051
