Pioneer A-50DA και A-70A
indikos001
Games
Η τάση για επιστροφή στο βινύλιο έχει δώσει ώθηση και στην επιστροφή στο παλιό αλλά καλό hi fi. Μια νέα σειρά από προϊόντα έρχεται να μας φέρει και η κ.Pioneer, με τα A-50DA και A-70A να υπόσχονται απλά κυκλώματα, καλά υλικά, λογικές τιμές και Japan ούγια…
Ακόμη έχεις: symmetrical XLR, low-loss loudspeaker volume control, Quad-DSD (11.2 MHz), MOSFET Class D ενισχυτή με 90 watts, PCM με 384 kHz και 32 bit, full-metal χειριστήριο και 17 κιλά βάρος!
The A-70DA, which weighs more than 17 kilos, is not just about mass, it is above all about class: Separate mains transformers for pre-amplifier and amplifier sections, above all when they are individually cast and shielded as here, provide not only weight, but also working conditions with unsurpassed low interference for the audio circuitry. The doubled A-70DA is worth it because its pre-amplifier has a completely symmetrical layout. An individual, particularly low-loss loudspeaker volume control was even integrated for the symmetrical XLR input. Via its digital inputs the A-70DA is equipped for all modern music formats. In this respect, the very highest resolutions, such as Quad-DSD (11.2 MHz) and PCM with 384 kHz and 32 bit, are supported via USB. The high-resolution counterparts in the analog world are exclusive MC pick-ups which, thanks to the a switchable phono stage, supply this top model just as precisely as the widespread MM systems. With its doubled chassis, the full-metal loudspeaker knob and the thick aluminium front and side panels, the casing guarantees a suitably high-class performance.
  • 90 W + 90 W (20 Hz-20 kHz, THD 0.5 %, 4 ohms)
  • 65 W + 65 W (20 Hz-20 kHz, THD 0.5 %, 8 ohms)
  • THD: 0.02 % (Rated Output -3 dB, 8 ohms, 1 kHz)
  • Guaranteed Speaker Impedance: 4-16 ohms (A or B), 8-32 ohms (A+B), 4-16 ohms (Bi-Wiring)
  • Frequency Response (Measured with DIRECT button switched on): SACD/CD, NETWORK, LINE1, LINE2 5 Hz-50 kHz, ±3 dB
  • RIAA Deviation: PHONO MM 20 Hz-20 kHz, ±0.5 dB, PHONO MC 20 Hz-20 kHz, ±0.5 dB
  • Signal-to-Noise Ratio (IHF, A Network, Short Circuited)
    SACD/CD: 101 dB
    Phono: 89 dB (MM: 5 mV input)/74 dB (MC: 0.5 mV input)
    Power Amp Direct: 110 dB
  • Channel Separation
    SACD/CD: 90 dB (100 Hz), 84 dB (1 kHz), 75 dB (10 kHz)
    Power Amp Direct: 95 dB (100 Hz), 95 dB (1 kHz), 80 dB (10 kHz)
  • Pure Audio Grade High Efficiency Power ›› MOSFET Amplifier (Class D Amplifier)
  • Fully-Balanced Preamplifier Circuitry
  • Separated Construction for Preamp and Power Amp
  • Source Direct Mode
  • Highly Acclaimed ESS SABRE32 Ultra DAC
  • 384 kHz/32-bit USB-DAC for Asynchronous Transfer
  • Shielded Twin Transformer for Preamp and Power Amp
  • Trans-Stabilizer
  • Speaker A, B, A+B Selector
https://www.gadgetfreak.gr/
βρε παιδια αυτα εχουν κυκλοφορησει εδω και δυο χρονια,αληθεια κανενα μελος του φορουμ δεν εχει αγορασει καποιον απο τους δυο?
Την ιδια απορια εχω κι εγω.γενικως μαρκες που βγαζουν μηχανηματα για ολο το κοσμο οπως pioneer,sony,philips σπανιως συζητιονται σε av φορουμ.
νομίζω το τεστάρανε στο περιοδικό ήχος τεύχος 11/2016 ή 12/2016 με απόδοση 4,5 αστεράκια.
Δεν ειναι hiend....:p
Απλα εχουν αλλαξει οι καιροι και η πολιτικη της εταιρειας......οταν η pioneer εφτιαχνε μηχανηματαρες (70-80s) ,καποιοι μεταγενεστεροι hi-endαδες ανακαλυπταν το κολλητηρι.
κατάλαβα!;)
Τώρα όμως που κάθε ευρώ μετράει,καλό είναι να κάνουμε θέματα για τέτοια ''νορμάλ'' μηχανήματα εαν τα έχουμε στη κατοχή μας φυσικά,όχι να αναμασάμε ρηβιούερς...
κατάλαβα!;)
Σωστός! όταν όμως δεν έχουμε τα συγκεκριμένα μηχανάκια μιά πληροφορία την αξιοποιούμε ανάλογα ;)
Tanto-απόδειξη των καλών παλιών μηχανημάτων η διαχρονικότητά τους που ακόμη παίζουν υπέροχα που εκπλήσσει!
Ασε μας, κουκλίτσα μου (pioneer), πρωί-πρωί, με το "zinc made in Vietnam"
Μου θυμηθηκατε όλοι, τώρα, "ξαφνικά", το "στέρεο", το "βινύλιο", το "balanced" και τα "κιλά".
Άιντε και καλη Κυριακή!!!
krell made in china
NAIM made in china
cambridge audio made in china
κτλ..κτλ...το made in Vietnam σε πειραξε?
Pionner,Sony,Philips,Onkyo,Υamaha,Denon, αν θελoυν βγαζουν μηχανακια οπου χτυπανε στα ισα χαιενταδικες μαρκες. Οπως ειπε ο tanto οι εποχες αλλαζουν και ακολουθουν το ρευμα της εποχης.
Τον ενισχυτη αυτον μπορεις να τον συνδεσεις με 2 ηχεια και sub? Δε βλεπω pre out ούτε sub out, μονο line out. Γινεται απο συτη την εξοδο να στείλεις σημα σε sub?
timurakhmetov
