Abbingdon Music Research cd 777
vlasis
Φωτογράφος!
Απάντηση: Abbingdon Music Research cd 777
Philps DEM DAC
At the heart of the CD-777 is a Philps DEM Digital-to-Analogue Converter. This unique chipset is not used in any other CD source and it produces a sound that is so natural and organic. It is the only CD source at this price range with a performance that is truly en par with vinyl systems.
Digital to Analog Converter: Philips, 16-Bit, Multibit, Dynamic Element Matching
Compact Disk Drive: Custom, Toploading
Valve Complement: 2 X 6Н1П-ЕВ Supervalve
(6DJ8 / 6922 / ECC88 / E88CC / 6Н23П / 6N11P may be fitted)
Digital Audio Inputs: 1 x USB interface for PC or Mac
1 x RCA S/P-DIF
Analog Outputs: 1 X RCA; 1 X XLR per Channel
Digital Output: 1 X RCA S/P-DIF
Operation modes: Direct Master I; no digital or analogue filter
Direct Master II; no digital filter, anti-sin(x)/(x) analogue filter
Oversampling 2X
Upsampling 96KHz
Oversampling 4X
Upsampling 192KHz
Output voltage (Digital Full Scale) : >2V
Output Impedance: < 300ohm
Frequency Response: 20Hz to 20 kHz +0.0, -0.5dB
Signal-to-noise ratio 'A' Weighted: > 100 dB
Total Harmonic Dist. + Noise ( THD +N ): <0.3%
Dynamic range: >90 dB
Channel separation: >100 dB
Power consumption: Standby: < 0.1 W
Power on: < 40W
Power Transformer: 2 X 35VA Custom EI Transformer
Rated voltage: 90V-135V & 190V-260V AC
Colour: Silver or Black
Dimensions: 17.5in W by 4in H by 14.2in D
444mm W by 100mm H by 360mm D
Weight: CD Processor: 22lbs / 10kg
Shipped: 33lbs / 15kg
These include silver leaf capacitors, Sanyo Oscon capacitors, precision wire wound resistors, 70um gold plated, military-grade printed circuit boards, German-made premium film capacitors, AMR's own power supply polypropylene film Music Capacitors and zero-noise Schottky rectifiers.
Το CD-777 μπορει να συνδεθει με τον υπολογιστη μεσω θυρας USB και να ακουτε τα φλακια σας......
Τιμη στα 3500 ευρω.
Αντιπροσωπευεται απο την Rapsody audio.
Re: Απάντηση: Abbingdon Music Research cd 777
Philps DEM DAC
bla...bla...bla....
Ορέ τι λέει ετούτος εδώ ο άρρωστος ???
Το μοναδικό CD που κοιτάζει στα ίσα βινυλιακά συστήματα ???
Δηλαδή μετά από τριάντα χρόνια κατώρθωσαν να φτιάξουν σουβερο_γυρίστρα που να παίζει σαν τον φωνόγραφο !!!
Να παίζει σαν το θορυβώδες...το σκρατσαριστό...το παλιομοδίτικο...το άβολο...το μαύρο κι άραχνο βινύλιο...
(Πάντως η υπόθεση έχει κι ένα καλό...Ωρισμένοι από μας θα τσιμπήσουν σε τιμή ξυπτίλα κανα 'παλιό' AMR...Βλάσση παλουκάρι μου...ξέρεις εεεε...ρίξε τελεφούνκεν...:114:)
Mπα,τούτο δεν είναι αντικαταστάτης αλλά νέα-χαμηλότερη σειρα...
vlasis
Φωτογράφος!
Απάντηση: Re: Abbingdon Music Research cd 777
Aκριβως mister συντονιστα μου και λοιποι!!!!
:410:
gvts
