Musical Fidelity V-DAC
Απάντηση: Musical Fidelity V-DAC
ΟΚ περιμένουμε εντυπώσεις στο αντίστοιχο θέμα...
Τελικά την ψηφιακή ή τη Usb να προτιμήσει κανείς;
tyler durden
Μη ριβγιούερ
δεν υπαρχει κανονας, παραμονο ο υποκειμενικος κανονας που λεει "ταυτισου με τ' αυτι σου!":201:
Re: Απάντηση: Musical Fidelity V-DAC
Εξαρτάται απ τό τί είδους αρχεία έχεις.Αν είναι μέχρι 16/48 η Usb
αρκεί.Αν είναι 24/48,24/96 ή 24/192 τότε την ψηφιακή.
Mp3 πάνω από 256 και flac
η ψηφιακή με βολεύει...
Υπάρχει περίπτωση να ακούγεται χειρότερο από USB ;
Καμία περίπτωση.
Από τη στιγμή που σε βολεύει κιόλας η ψηφιακή είναι μια χαρά.
Κώστας Φ.
Έχουμε και review-δάκι από τον Sam Tellig του Sterophile...
Comparisons
The V-DAC begs to be compared to the Cambridge DacMagic, which retails for $449 (actual street price is $400, so the DacMagic effectively costs 1/3 more than the V-DAC). The DacMagic, which I wrote about in March, offers more features, including balanced analog outputs, a phase-reversal setting, variable digital filters—and a larger wall wart, if that makes any difference. It's cool the way the DacMagic can stand vertically on its rubbery isolation base—there's no need to hide it away, and it doesn't flop over. All the V components are so lightweight that our cat can paw them around. And does.
I tried the two DACs using the Denon player as a transport and the V-CAN headphone amp (see below). Back and forth I went, playing a classical work all the way through, or a movement or two of a symphony or concerto. Through the Audio Technica ATH-AD700s I heard more low-level detail with the DacMagic, more ambience, more of the recording venue. The V-DAC was a little airless by comparison, but seemed balanced on the slightly soft side of neutral—no bad thing when it comes to digital recordings and headphone listening. The DacMagic appeared to have a fuller, richer, if not tighter bottom end. The DacMagic bloomed but didn't boom. But, as Bob Deutsch would say, I am less a leveler than a sharpener: I look for differences to overemphasize.
I couldn't establish a clear preference for either DAC; your choice may be determined by features and price. Many customers will turn to mail order—Audio Advisor, for instance, carries both. If you love ambient detail, you won't go wrong with the Cambridge Audio DacMagic. If you lust after a silken, sweet (but not oversweet) sound, you'll marvel at the Musical Fidelity V-DAC. When I'm listening to one, I don't miss the other. Always a good sign.
Δε θα μπορούσαν να λείπουν οι μετρήσεις από τον Atkinson, φυσικά:
Yes, the D/A chips now coming from the foundries run by companies like Burr-Brown/Texas Instruments are capable of superb linearity and resolution, but the designer of a product like the Musical Fidelity V-DAC still has to be able not to compromise that performance with analog design and circuit layout. The V-DAC's generally superb measured performance indicates that compromise was avoided; it would not disgrace a much-higher-priced product, let alone one that costs just $299—half what our family spends on groceries each month
Διαβάστε περισσότερα: Stereophile.com
Φίλος που πούλησε το Oppo 83 γιατί του άρεσε η εικόνα του Pioneer 52, έμεινε με τον κακό ήχο του 52 κι έτσι αγόρασε ένα v-dac.
Κάναμε συγκρίσεις 52 vs v-dac... Καμία σχέση.
Το 52 από τις αναλογικές "φωνάζει", με μεσοϋψηλές να τσιρίζουν. Ακρόαση που κουράζει.
Μετά δοκιμάσαμε πώς παίζει ο Yamaha RX-V2700 μέσω hdmi πάλι με πηγή το 52. Ο ήχος πιο γλυκός από το 52, υποφερτός, αλλά το μπάσο λίγο πλαδαρό και οι μεσοϋψηλές μουντές, με αισθητή την προσπάθεια του Yamaha να λεπτύνει τις υψηλές, ώστε να δώσει αίσθηση καλλιεργημένου ήχου.
Με V-Dac, πάλι με πηγή το 52, αναλογικά στον Yamaha, ο ήχος "ήρθε"! Ανάλυση, μικροδυναμικά, παλμός, ισορροπία σε όλο το φάσμα. Έφυγε το πέπλο που υπήρχε κατά την ακρόαση με τα dac του receiver, ενώ ο ήχος παρέμεινε γλυκός κι ευχάριστος.
Συμπέρασμα ότι το v-dac αναβαθμίζει εμφανώς ένα bd-player ή ένα receiver μέσης κατηγορίας τιμής.
Μου πέρασε από το μυαλό εμένα, ναι. v-dac, v-can και ακρόαση από τα Sennheiser HD800 :126:
Μια ερωτηση επειδη εχει 12volt.Σε αυτοκινητο μπαινει?Το εχει σκεφτει κανεις?
Σαφέστατα και μπορεί να τροφοδοτηθεί από τα 12 (13,5) volt ενός αυτοκινήτου.
Ποιο το όφελος όμως?
Χαιρετω ολους τους φιλους και ευχομαι καλες γιορτες με υγεια πανω απο ολα.. Εχω ψηθει και εγω με το μηχανημα(μεχρι πριν απο 1 μηνα δεν ηξερα καν τι ειναι το dac) αλλα θελω να κανω και την χαζη ερωτηση μου..εχω το wd σαν player με ενα pioneer vsx-415 και ηχεια wharfedale diamond 9.2..Με τα μεσα που διαθετω θα καταλαβω την βελτιωση?Σεβομαι την γνωμη σας και θα ηθελα να την ακουσω...ευχαριστω
Σαν dac θα παιξει καλυτερα απο αυτα του pioneer αλλα δεν σου προτεινω να το κανεις.Αν ειχες ενα καλο δικαναλο ναι αλλα με τον 415 σαν ενισχυτη οχι.
Δεν γνωρίζω αν ο ενισχυτής σου έχει επιλογή Direct (ή κάτι αντίστοιχο) με την οποία παρακάμπτει κάποια κυκλώματα επεξεργασίας και αποδίδει καλύτερα σε δικάναλες ακροάσεις.
Αν έχει κάνε μια δοκιμή.
Απάντηση: Re: Musical Fidelity V-DAC
Από την οπτική είσοδο και οδηγούμενο από το media player της WD έκανε άμεσα αντιληπτή τη ποιότητα του μουσικού προγράμματος που το τροφοδοτούσε.
Σαφέστατα βελτίωσε τον ήχο του συγκεκριμένου media player κάνοντας έτσι αποδεκτό το αποτέλεσμα.
Σκεφτομαι να παρω αυτο τον συνδιασμο,το media player της WD,με καποιο V-DAC,και με χαλασε αυτο το "αποδεκτο αποτελεσμα" :108:
Δηλαδη δεν αξιζει;;;
Η αλήθεια είναι ότι το WDTV, σαν (red book) audio transport, είναι εκπληκτικό με αξιοζήλευτο ήχο!!!!!
roberto_portale
