AZbox HD Elite ... under hard test...
Απάντηση: AZbox HD Elite ... under hard test...
Exω εντοπισει καποια καναλια αλλα και ενα feed απο τα χιλιαδες που δεν παιζουν καλα.Το τι εννοω καλα αν τσεκαρετε θα καταλαβετε.
Και ρωταω επειδη τον εχετε αρκετοι και μου εχει κανει εντυπωση που δεν το εχει παρατηρησει καποιος.
Αν βεβαια εσεις δεν εχετε προβλημα, τοτε ειναι δικο μου και θα κοιταξω να δω πως θα το διορθωσω.
Νέο MaZ 3.0
Module configuration
- Added an option in the configuration that keeps the size and position of the window, as well as some other variable.
- The columns have been changed FIRMS, plugins, etc. Now the first column is three sections (FIRMS official newspapers and FIRMS FIRMS KGD) and the second two (plugins and cams) and the third is to see updates from the last start of the program.
The program connects to various servers now and we'll have the top two buttons (except FIRMS), one to download the file and one to install it directly in Azbox. Clicking on these buttons will appear different links where we can download it, if we decide to download it to our disk or flash drive, the program automatically generate the file plugins.lst or need.
Telnet Module
Is placed above the console is a button bar. In the bar has been placed the copy and paste buttons, reboot, etc and two buttons that contain a list of the script system we had before on the right, leaving this part only for the user scripts. Thus, the names of the scripts of the system are translatable and remain in a separate file, so the file is not overwritten scripts.ini with each update
Channel lists
- Added the ability to change data files *. dat DVBTa.dat and DVBC
- It also adds a new concept "My Settings", which is nothing that can save our configuration of satellites and antenna so that, when we open a channel list that only contains the file all_channels.dat use our default settings and can correct the list if there are problems with the indices of the satellites (which do not match those on the list with those of our configuration)
- Added a new button to the right of the buttons up and down the list to update the list from *********. From this new window are chosen sopciones satellites and we want and then have the opportunity to view and change the channel to be deleted, modified and will be added. This also modify the list of satellites with transponders or changes in them.
- Added a new function in the menu list of favorites that allows us to import lists of bookmarks to another list or a list AzboxHD Enigma 1 Enigma 2. If the list is Enigma is necessary that the channels are already tuned to our list or otherwise will not appear if a list of AzboxHD this is not necessary and if we send a list of favorite channels that we had not tuned, these are created automatically.
- Also supports a command called reload I created and which is installed in the last firm KGD. this command recharge Azbox memory channel list and recording reservation without rebooting. That yes, this only works if we have the deco in standby or turned on but in a different menu of TV, otherwise we will always appear the window and restart. Much eye on this: For a bug in the TV API recharge antenna_list.dat and DVB files *. dat is not possible without rebooting, so if you have made changes to the configuration of the satellite antenna or you will have to do manually restart the deco though you reload the list without rebooting
Εδώ
Re: Απάντηση: AZbox HD Elite ... under hard test...
Εγω γυρισα το πιατο στις 12,5 και τσεκαρα αλλά δεν ειδα διαφορά , αν εξαιρεσεις οτι εχει την ιδια εικονα με τα al jazeera στις 13 .αλλά αυτό αφορά το sportsitalia 1 , για το 2 ηταν οκ η εικονα .
Αν θες διευκρίνησε τι συμβαινει σ εσενα
Νέο MaZ 3.0
Telnet Module
Channel lists
Εδώ
Πολύ καλό
Απάντηση: Re: Απάντηση: AZbox HD Elite ... under hard test...
Εμενα η εικονα πιξελιαζει παρα πολυ και ειδικα στις γρηγορες κινησεις ειναι πολυ εμφανες.
π.χ. σε αγωνα μπασκετ σαν να 'πηδανε' μεσα απο τη μορφη τους οι εικονες.
Re: Απάντηση: Re: Απάντηση: AZbox HD Elite ... under hard test...
Μαλλον ειναι προβλημα του πιατου αφου λες πιξελιασμα .Παντως δεν εχω τετοιο προβλημα καθολου
Exω ενα σωρο δεκτες και δεν εχω προβλημα με αυτους.
Σιγουρα δεν ειναι το πιατο.
Τι να σου πω.. εγω δεν εχω παντως προβλημα σε κανενα από τα καναλια που λες γιατί το ξανακοιταξα .
Δεν ξέρω αν είσαι κάτοχος άλλου Hd δέκτη έτσι συμπωματικά!!!
Αν ναι σύγκρινε την ποιότητα εικόνας στα συγκεκριμένα κανάλια μεταξύ των δυο δεκτών
Κατά 90% θα δεις μειωμένη απόδοση στα δυο κανάλια στον azbox το έχω διαβάσει και αλλού αυτό το θέμα και παραμένει αναπάντητο(προσοχη μονο σε αυτά τα καναλια)
Αυτό φυσικά δεν μειώνει τον συγκεκριμένο δέκτη απλά κάποιες παρατηρήσεις που γίνονται τις συζητάμε όλοι μαζί για να βγάλουμε τα συμπεράσματα μας
Επίσης στο feed HD του παγκοσμίου πρωταθλήματος στο snooker την περασμένη εβδομάδα από τις 10 Ε υπήρχαν ανεξήγητα σκαμπανεβάσματα στην συχνότητα με αποτέλεσμα να μην μπορείς να το παρακολουθήσεις
Το συζήτησα και με ξένους έβαλα και τον Nano xx 9500 αλλά και το spιderbox 9000 hd oi οποίοι δεν είχαν πρόβλημα στην συγκεκριμένη συχνότητα
@Ο azbox σε γενικές γραμμές είναι ένας δέκτης με πολύ καλή εικόνα και στα sd αλλά και στα hd κανάλια τα παραπάνω γεγονότα είναι λεπτομέρειες
Όποιος θέλει να παρακολουθεί feed 4 2 2 τον αγοράζει με κλειστά τα μάτια καθότι έχει τεσταριστει και σε χαμηλές συχνότητες και αποδίδει το μέγιστο
@@ η εικονα του ΑΖΒΟΧ για να γινω και λιγο ποιο συγκεκριμενος ειναι πολυ ποιο μπροστα και απο τον 800 και τον 8000 εκει ο alpha ειναι :121:
μπορει κανεις να συνδραμει?
εδω http://forum.azbox.com/index.php/topic,62.msg827/topicseen.html#msg827
ζηταει η opensat πληροφοριες για να διωρθωσει το προβλημα του EPG με τα ελληνικα
Εχω την αποψη ,χωρις να εχω κατι με τον αντιπροσωπο, γιατι ουτε τον ξερω ουτε με ξερει, αλλα σε αυτο επρεπε να ειχε ενδιαφερθει.
Και νομιζω οτι θα ειχε λυθει τοσο καιρο.
Εγω με καποιους αλλους ειχαμε την επιθυμια για blind scan, και αυτο προχωρησε ως ενος σημειου και μεχρι εκει.
Μετα μαλλον θελησαν να ακουσουν αλλους και γι αυτο στην τελικη δεν λειτουργει εστω και softwar ικα.
εγω δεν εχω ιδεα απο προγραμματισμο και αλλα mambo jumbo για να βοηθησω , ουτε και αλλο δεκτη που να τους αποδειξει οτι το νοβα εχει και ελληνικα στο epg της.
ειναι ευκαιρια καποιος που ξερει, μιας και που το εχουν παρει ζεστα το θεμα, να τους δωσει καποια στοιχεια για να συνεχισουν
Πρεπει να βρουμε πιο image επαιζε ελληνικα απο τα παλια και να τους το στειλουμε πσαχνω στα παλια ποστ και σε αλλα φορυμ και θα το στειλω μολις το βρω
Ειναι το 0.9.1621 και τους το εστειλε ο Μανος 1978
και για οποιον ενδιαφερεται να δοκιμασει το συγκεκριμενο η οποιοδηποτε αλλο παλιο fw
http://www.hd-box.info/index.php?section=downloads&category=15
:144: ναι φιλε νασαι καλα αυτο ηταν αντε να δουμε τι θα γινει περιμενουμε ευχαριστα νεα :109:
Ναι βρε παιδιά αλλά το EPG από το 0.9.1621 το έχετε δει.? Μόνο κάποιες επικεφαλίδες έδινε... Περιεχόμενο τίποτα. Ας ελπίσουμε πως κάτι θα γίνει όμως γιατί ζητάνε διάφορες πληροφορίες και κάποιοι είναι ήδη στην φάση να τους τις παρέχουν. Ίδωμεν...
Χαιρετώ
καλα? νεα για το προβλημα του epg διαπιστώθηκε οτι οταν ενα καναλι εκπεμπει μονο ελληνικο epg o δεκτης δεν εχει κανενα προβλημα στο να το εμφανισει με ελληνικους χαρακτηρες ενω οταν εκπεμπει σε αγγλικά και ελληνικα επιλεγει μονο τα αγγλικα αρα δεν ειναι θεμα γραμματοσειρας αλλα επιλογης γλωσσας ενημερωθηκε η εταιρεια και απαντησαν οτι θα το τεσταρουν και θα το διορθωσουν?
Το πρόβλημα αυτό έχει επισημανθεί από το Φθινόπωρο στο επίσημο φόρουμ και συντηρούταν με posts από διάφορους Έλληνες. Κάποια στιγμή κάποιος moderator συγκινήθηκε και ρώτησε πληροφορίες, του εδόθησαν και έκτοτε ούτε φωνή ούτε ακρόαση. Έκανα κάποια στιγμή ένα ψιλοεπιθετικό post ότι είναι ντροπή τους να μας γράφουν στα ..... τους αλλά όπως καταλαβαίνετε σβήστηκε άμεσα.
Μακάρι να λυθεί το πρόβλημα έστω και τώρα αλλά δεν είμαι και πολύ αισιόδοξος. Αυτοί εκεί στην opensat ή πολύ τεμπέληδες είναι ή πολύ άσχετοι...
panosop
Συστημικός
τους είχα γράψει και εξηγήσει και παλαιότερα αλλά και τώρα, ότι το πρόβλημα δεν είναι στα fonts, αλλά στον τρόπο που βλέπει και διαβάζει τους headers απο το EPG stream, δεν μπορεί να επιλέξει τους Ελληνικούς απο τους Αγγλικούς όταν εκπέμπουν και τα δύο μαζί.
Για την ακρίβεια τους έγραψα και αυτο το κείμενο πρίν απο λίγες ημερες :
panos279 said:
For the opensat...
the problem i thing is to read the starting header from the epg stream or xmltv or other epg protocol.
http://www.etsi.org/deliver/etsi_en/300700_300799/300707/01.02.01_40/en_300707v010201o.pdf
read chapter 6.2 , page 26.
That means the azbox reads the english epg not the greek one.
The Nova sends two differend epg streams. How can you manage the epg stream with Azbox?
Καλησπερα στην παρεα:107:Εχω τον Azbox HD Elite και εχω περασει μια λιστα με IPChannels στο /DISK2 και παρολ΄αυτα ενω μου βγαζει την λιστα των καναλιων στους δορυφορους δεν ανοιγει κανενα καναλι ...να υπενθυμησω για να μην τον ξεχασω οτι ειμαι συνδεμενος με το ιντερνετ....μου βγαζει την κιτρινη μπαρα του σηματος σχεδον γεματη αλλα δεν ανοιγει το καναλι..Τι μπορει να φταιει και δεν ανοιγουν...μηπως φταιει η λιστα που εχω βαλει ?Μπορει να μου δωσει καποιος καποιο link με αναλογη λιστα που να ανοιγουν καναλια....Αν μπορει καποιος να μου πει βημα βημα πως και που βαζω την λιστα μηπως και κανω εγω κατι λαθος?:110:
Ευχαριστω εκ των προτερων!!!
  • loggeo
Γιώργος Π
