Αν οι Beatles ήταν κολλημένοι με τα pc
Yesterday
Yesterday,
All those backups seemed a waste of pay.
Now my database has gone away.
Oh I believe in yesterday.
Suddenly,
There's not half the files there used to be,
And there's a milestone hanging over me
The system crashed so suddenly.
I pushed... something-wrong What-it-was...
I could not say.
Now-all my data-is-gone and I long.....
for yester-day-ay-ay-ay.
Yesterday,
The need for back-ups seemed so far away.
I knew my data was all here to stay,
Now I believe in yesterday.
Eleanor Rigby
Eleanor Rigby
Sits at the keyboard
And waits for a line on the screen
Lives in a dream
Waits for a signal
Finding some code
That will make the machine do some more.
What is it for?
All the lonely users, where do they all come from?
All the lonely users, why does it take so long?
Guru MacKenzie
Typing the lines of a program that no one will run;
Isn't it fun?
Look at him working,
Munching some chips as he waits for the code to compile;
It takes a while...
Eleanor Rigby
Crashes the system and loses 6 hours of work;
Feels like a jerk.
Guru MacKenzie
Wiping the crumbs off the keys as he types in the code;
Nothing will load.
Eleanor Rigby
Eleanor Rigby
Lives in a dream
Waits for a signal
Finding some code
What is it for?
Guru MacKenzie
Isn't it fun?
It takes a while...
Eleanor Rigby
Feels like a jerk.
Guru MacKenzie
Nothing will load.
Unix Man
He's a real UNIX Man
Sitting in his UNIX LAN
Making all his UNIX plans
For nobody.
Knows the blocksize from du(1)
Cares not where /dev/null is going to
Isn't he a bit like you
And me?
UNIX Man, please listen(2)
My lpd(8) is missin'
UNIX Man
The wo-o-o-orld is at(1) your command.
He's as wise as he can be
Uses lex and yacc and C
UNIX Man, can you help me At all?
UNIX Man, don't worry
Test with time(1), don't hurry UNIX Man
The new kernel boots, just like you had planned.
He's a real UNIX Man Sitting in his UNIX LAN
Making all his UNIX .plans For nobody ...
Making all his UNIX .plans For nobody.
Something
Something in the way it fails,
Defies the algorithm's logic!
Something in the way it coredumps...
I don't want to leave it now
I'll fix this problem somehow
Somewhere in the memory I know,
A pointer's got to be corrupted.
Stepping in the debugger will show me...
I'm too close to leave it now
You're asking me can this code go?
I don't know, I don't know...
What sequence causes it to blow?
Something in the initializing code?
And all I have to do is think of it!
Something in the listing will show me...
I'll fix this tonight I vow!
Write in C ("Let it Be")
When I find my code in tons of trouble,
Friends and colleagues come to me,
Speaking words of wisdom:
"Write in C."
As the deadline fast approaches,
And bugs are all that I can see,
Somewhere someone whispers:
"Write in C....."
Write in C, Write in C,
Write in C, oh, Write in C.
LOGO's dead and buried,
Write in C.
I used to write a lot of FORTRAN,
For science it worked flawlessly.
Try using it for graphics!
Write in C.
If you've just spent nearly 30 hours,
Debugging some assemb-l-y,
Soon you will be glad to
Write in C.
Write in C, yeah, Write in C.
BASIC's not the answer.
Write in C.
Pascal won't quite cut it.
Write in C.
:143::143::143: :142:
Απάντηση: Αν οι Beatles ήταν κολλημένοι με τα pc
:114: :114:
Abessalom
Βαρώνος
Μελίδης Μιχάλης
Πρόεδρος ΕΒΒΕ
Υπάρχει μια εκδοχή ενός τραγουδιού του Άκη Πάνου, που λέει:
Εφτά νομά σ΄ένα δωμά
που να ξαπλώ να κλείσεις μα
ο ένας πάει σινεμά
ο άλλος πέφτει και κοιμά
Η διασκευή ξεκινάει κάπως έτσι:
Εφτά πουτά σ΄ένα μπουρδέ
ποια να διαλέ απ΄τις εφτά
η μια είναι σαν σκ@τά
η άλλη είναι σαν την τσατσά .....
flastex
