Asus EEE PC Box B202 Windows 7
Πωλείται το πολύ μικρό και τέλειο Asus EEE PC Box B202 με Windows XP
Είναι τόσο μικρό που μπαίνει άνετα στο έπιπλο της TV ή και πίσω από την TV αφού έχει ειδική βάση.
Επίσης έχει αναβαθμιστεί ή μνήμη στα 2GB (το μάξιμουμ που δέχεται)
Πάιζει μέχρι 720p χωρίς κολλήματα και το είχα συνδεδεμένο με την Kuro.
Στο κουτί του με όλα τα παρελκόμενα και δώρο DVI to HDMI καλώδιο.
Τιμή 250 ευρώ.
Πωλείται λόγω του ότι έχω πια imac για ίντερνετ και το popcorn για τα άλλα.
Τηλ. 6977697323
http://www.vnp.gr/index.php?target=products&product_id=483
Overview of ASUS Eee Box - Windows XP
The Eee Box is a mini desktop PC with huge possibilities. Since the Eee Box only requires 20 watts of power; your carbon footprint is reduced by 90% compared with a standard PC.
With a slim svelte design, the worlds smallest desktop PC allows and array of space saving options. Plus, it's easy to use. The intuitive, Windows user interface lets you get started right away.
Enjoy easy living with the eclectic, efficient and eco-friendly Eee Box.
Turn your home into an integrated wireless network.
The latest generation of wireless connectivity, Wi-Fi 802.11n, is now 6 times faster. Network with other computers, connect to the internet or transfer images from a digital camera wirelessly. What used to take 10 minutes to download a 30 minute HD video can now be done in 44 seconds (conditions dependant).
Windows – The Operating system you can count on
The Microsoft Windows operating system allows more experienced users to seamlessly utilise the Eee Box through familiar Windows interface, and incorporates Genuine Windows Live features, like Live Messenger for instant messaging, Live Mail for consolidated email accounts on your desktop. Completing this, is Microsoft Works, which equips you with numerous office applications to work efficiently.
With such flexibility the ASUS Eee Box is an ideal computing solution, for use in a home office to a bedroom, lounge or study why consider anything else? You can even mount the Eee Box to the back of an LCD monitor (VESA 75/100 standard mount)!
Features of ASUS Eee Box - Windows XP
Extremely slim and compact
Genuine Windows XP English
Latest generation Wi-Fi n connectivity
Energy efficient - Needs just 20 watts of power!
4 x USB ports
2GB RAM
160GB Hard Drive
What's in the box of ASUS Eee Box - Windows XP
ASUS Eee Box
Documentation
Re: Απάντηση: Asus EEE PC Box B202 Windows 7
Έχει κάποια διαφορά από αυτό που στο e-shop κάνει 239 ευρώ;
http://www.e-shop.gr/show_per.phtml?id=PER.908602
Φίλε Νίκο, το δικό μου είναι το μαύρο (θα δεις ότι είναι πιο ακριβό), έχει 2GB μνήμη και έχει windows 7 professional εάν καποιος θέλει (όχι παράνομα). Επίσης δίνω και ένα εξωτερικό USB DVD-RW labelwrite.
Tasosnissanp12
