Egreat A1080...έρχεται τον Ιούνιο!
Νέο μοντέλο από την Egreat με πολλές δυνατότητες!
Αντιγράφω από το iboum.com
One of three new EGreats with identical casing but different chipsets. The A1080 uses the fastest of the Sigma chips (8643) and promises to do everything including all HD-Audio and BD-ISO. The look of the unit is impressive and the size is small for the level of specification it packs. In addition to the discreetly mounted internal 2.5" HDD, the A1080 has the unique feature of an external SATA port (not eSATA but full SATA mounted externally!). A USB3 slave port is promised, which would be a first sight of USB3 in a Media Player.
On paper the hardware is spectacular but everything will come down to firmware quality. Other similar 864x players have suffered from buggy firmware since their introduction at the end of 2009.
The A1080 looks great and promises the elusive 'everything'. We just hope it lives up to the promise. We have no firm launch date for any of the new EGreat players.
Features:
Ø Solid Aluminum alloy slim case, good heat sink; at same time, mobile rack design give user
easily/friendly/quickly installation.
Ø Besides of internal 2.5” mobile rack for 2.5” SATA HDD, there is another external SATA
port for external SATA HDD or Blu-ray DVD ROM without extra power.
Ø Support BD disk (need extra SATA BD-ROM which isn’t standard accessory)
Ø Special USB3.0 slave port.
Ø Can be refurbish to other FW depend on your choice.
Ø NFS & Samba are supported.
Ø External subtitle can be adjusted size/color/position and so on.
Ø File copy/delete can be supported.
Ø Power on/off by remote control.
Ø Sigmadesign8643 667MHz CPU ,256MB NAND FLASH and 512MB DDR2.
Output connectors:
Video Output connectors:
Ø HDMI 1.3
Ø Composite
Audio Output connectors:
Ø Stereo
Ø SPDIF Digital audio output
Other interface:
Ø 2 x USB hosts.
Ø 1 x USB3.0 slave
Ø 1 x SATA port which can install DVD ROM or HDD without extra power.
Network
Ø Ethernet 10/100/1000M
Ø
Power on/off control by RC
Ø Add one MCU which can support power on/off by RC.
Spec:
Video format
MPEG1/2/4 Elementary (M1V, M2V, M4V)
MPEG1/2 PS (M2P, MPG)
MPEG2 Transport Stream (TS, TP, TRP, M2T, M2TS, MTS)
VOB
AVI, ASF, WMV
Matroska (MKV)
MOV (H.264), MP4, RMP4
Video codec
XVID SD/HD
MPEG-1
MPEG-2 -MP@HL
MPEG-4.2 - ASP@L5, 720p, 1-point GMC
WMV9 -MP@HL
H.264 -BP@L3 ,[email protected] ,[email protected] ,[email protected]
VC-1 -MP@HL ,AP@L3
Audio format
AAC, M4A
MPEG audio (MP1, MP2, MP3, MPA)
WAV
WMA
FLAC
OGG
Audio codec
WMA, WMA Pro
AAC
MP1, MP2, MP3
LPCM
FLAC
Vorbis
DTS Stereo
Dolby Digital
Picture format
JPEG, BMP, PNG, GIF
Subtitle format
SRT, SMI, SUB, SSA
HDD partition
FAT32, NTFS,EXT3
Unit size
165x165x35mm
Package:
Ø Remote control 1pcs
Ø 7P+15P SATA cable 1pcs
Ø USB 3.0 cable 1pcs
Ø 12V/3A power adapter 1pcs
Ø AC cable 1pcs
Ø CD-R 1pcs
Ø User guide 1pcs
Απάντηση: Egreat A1080...έρχεται τον Ιούνιο!
Δεν έχει ανακοινωθεί τιμή ακόμη.Σε λογικά πλαίσια θα είναι νομίζω!
To remote control είναι ακριβώς ίδιο με αυτό των popcornhour όπως επίσης φοράει το chipset που έχει και το wd tv live εννοείτε ότι έχει πολύ περισσότερα(Όπως usb3, esata, bluray iso menu κ.τ.λ.) αλλά στάνταρ θα τα πληρώνεις όλα αυτά τα έξτρα καθότι αποκλιεται να κοστίζει μεχρι 100 ευρώ που κοστίζει τώρα το wd tv live έτσι δεν είναι?
Μακάρι να κοστίζει βέβαια τόσο αλλά δεν το κόβω.
Έχει το λογισμικό που έχουν και τα popcornhour αν όχι τότε ποιο έχει?
κατω απο 200ε θα εχει λογικα.Για κανενα 170αρι το κοβω μαξιμουμ...
Αν κοστίζει τόσο τότε είναι καλή τιμή.
Είχε κανείς κανένα άλλο egreat ρε παιδιά να μας πει εντυπώσεις για το πόσο γρήγορο - εύκολο είναι το μενού του κ.τ.λ.
Θα φοράει το chipset που φοράνε τα Popcorn Hour A-200 και Popcorn Hour C-200 και όχι το wd tv live.
'The A1080 uses the fastest of the Sigma chips (8643)'
Ναι έχεις δίκιο το egreat a1010 θα φοράει το sigma tech 8643 ενώ το wd tv live φοράει το sigma tech 8655 που είναι υποδιερεστερο σε δυνατότητες αυτού που έχει το wd tv live με βάση αυτό.
Πάντως ένα καλό για το 8655 είναι ότι είναι το τελευταίο και δυνατότερο sigma tech chipset της σειράς 865x
Ναι το live ειναι για μενα πολυ δυνατο value for money.
Aπλως λογικα τωρα , η δυνατοτερη φουρνια τσιπ 864Χ περναει στα 'low budget' (θελω να πιστευω και εγω οτι θα κανει κατω απο 200, κανα 160-170 ) πια μηχανηματα.
Θα περιμενω και την απαντηση της wd.Θα υπαρξει λογικα :137:
864x φοραει το wd live , δεν νομιαζω να βγει κατι.
Συνειδητα δεν εχει hd audio το wd live.
8655 φοραει...:114:
Εγω ειμαι ρομαντικος και περιμενω την version 3 με το 864Χ και υποστηριξη των παντων ολων και κατι παραπανω .. :143:
Ναι για πρόσεξε καλύτερα το link που δίνω στο παραπάνω μου ποστ που δείχνει ποιο chipset φοράει το wd tv live ώστε να δεις ότι φοράει το 8655 και όχι το 864x που λες εσύ.
Με τιμή 203 € στο αγγλικό μαγαζί.
καλη περιπτωση αλλα εχει και 50ε μεταφορικα η κανω λαθος?
opanamas
