Bel Canto --DAC3.5VB
vlasis
Φωτογράφος!
The e.One DAC3.5VB
192kHz 24-bit DAC Control Center
Analog input * ST Glass-Fiber • Internal Virtual Battery Technology
Top of the e.One line of Bel Canto Dual-Differential DAC Control Centers, the DAC3.5VB integrates all your source components with peak-performance 126dB of dynamic range, providing unprecedented resolution, flexibility and control with a new, intuitive, easy-to-read display and user interface. The heavily-regulated internal VB power supply maintains an optimal electrical environment, dramatically reducing noise.
The core of all Bel Canto's DAC Control Centers is our jitter-eliminating Two-Stage Master Reference UltraClock. Our 24-bit digital volume control is completely transparent and ensures the highest resolution possible while VB technology delivers the quietest, most isolated power available. Low jitter, low noise, low heat, low power consumption, and effective power line isolation brings music to life with extraordinary nuance and power.
Features
* 126dB dynamic range
* 24/192 digital inputs: AES, ST Glass-Fiber, BNC, Coaxial RCA and TOSLINK
* Two-Stage Master Reference UltraClock anti-jitter circuit
* Low-noise full galvanic isolation on all digital inputs
* Analog input
* Fully-balanced XLR and single-ended RCA outputs
* Virtual Battery technology
* New 8-character alpha-numeric display for Volume, Sample Rate and Input control
* Green, eco-friendly, low-heat, low noise, low power consumption
* RS232 port and remote
http://news.ecoustics.com/bbs/messages/10381/636859.html
Bel Canto e.One DDAC3.5VB
$3,495.00
Απάντηση: Bel Canto --DAC3.5VB
Μωρέ, καλά κάνω εγώ και κοιτάζω πρώτα τα οπίσθια. Σε όλες τις περιπτώσεις.
Re: Απάντηση: Bel Canto --DAC3.5VB
τον νου σου ομως,δεν ξερεις καμια φορα τι θα βρεις απο μπροστα.:116:
Απάντηση: Re: Bel Canto --DAC3.5VB
Ρε μάστορα αυτό δεν έχει interface για pc ( 1394 η usb ) :121:
και που είναι το πρόβλημα? αφού κυκλοφορούν κάτι usb-στικάκια που βγάζουν AES/EBU ή spdif, δεν υπάρχει πλέον κανένα απολύτως θέμα!
Ίσα ίσα θα έλεγα, δε σε περιορίζει με τον usb μετατροπέα του κι έχεις τη δυνατότητα να βάλεις το δικό σου.
μα καλά, που ζείτε....:136:
α, αυτό ναι, κι εγώ το κάνω. Κυρίως σε άλλες περιπτώσεις.
κι ο βλάσης το κάνει. ναι.
Ελπίζω αυτό να μην είναι τόσο συναισθηματικό όσο ο αντίστοιχος ενισχυτής...:143:
Re: Απάντηση: Re: Bel Canto --DAC3.5VB
έχεις λινκ για το aes?
roberto_portale
