NBS .....
vlasis
Φωτογράφος!
Απο καλωδιο εταιρεια σε ....δεν ξερω τι να πω....μαλλον θελουν επειγοντως γιατρο καποιοι κατασκευαστες.....
Για του λογου το αληθες διαβαστε και παρακαλω σας τις αποψεις σας....εγω τρεχω στον γιατρο μου να αλλαξω τα χαπια μου!!!!!
NBS Universal Power Amplifier
This Class D amp is analog all the way—"D" doesn't stand for "digital"—and designed so that its frequency response is unaffected by changes in the speaker's impedance at different frequencies.
Specifications:
AC Mains voltage:
(without switches) 85-135VAC and 200-265VAC
50-60 Hz
Power factor: >.95 Power output: >650W into any load from 2 Ohms to open circuit
Clipping: Typ 1kW in to 8 Ohms Frequency range: 4Hz - 35 kHz Controls: Magnetic 2-pole mains breaker
Input selector
Gain
Size: H 19” x W 20” x D 20” Weight: 120 lbs (54.5 kg) Construction: Machined aluminum clear anodized Price: $80,000.00 U.S.D
Για classD 80000 dollars?????????
vlasis
Φωτογράφος!
Απάντηση: NBS .....
NBS UNIVERSAL PRE AMPLIFIER
Configuration
Inputs: 2 sets – balanced in = 48K Ohms differential
2 sets - single-ended in = 30K Ohms Outputs: 2 sets – balanced out = 200 Ohms, load = any
2 sets - single-ended out = 600 Ohms, load = any Gain: Max 6dB to single-ended outputs
12dB to balanced outputs Gain control range: 101.5dB Gain step size: 0.5dB, tracking within 0.1dB over entire range Frequency range: DC-100kHz, +0, -1dB Remote control: Volume Panel illumination: Proportional to ambient light Mains: 90VAC - 265VAC, 50-60 Hz, no adjustments Dimensions: 5.925" (150mm) H
17.000" (432mm) W
16.000" (406mm) D Weight: 42 lb (18 Kg) Supplied Accessories: BLACK LABEL II+ A/C POWER CABLE
Price: $30,000.00
vlasis
Φωτογράφος!
Απάντηση: NBS .....
NBS UNIVERSAL PHONO PRE AMPLIFIER
Specifications:
Inputs: L&R Moving coil, RCA connectors
L&R Moving magnet, RCA connectors Input loading: MC: 50,100,250, 500, 1000 Ohms
MM: 47K Ohms Outputs: L&R balanced, XL connectors, Pin 2 Hot
L&R unbalanced, RCA connectors Output loading: Balanced 600 Ohms or greater
Unbalanced: 600 Ohms or greater Gain: MC Low: 60 dB at 1 kHz
MC High: 70 dB at 1 kHz
MM: 40 dB at 1 kHz
Mute: -100dB Equivalent input noise: MC: 150 nV, 22Hz - 22 kHz, unwtd Equalization: RIAA +/- <0.08dB Power requirements: 85-265VAC, 50-60Hz, 15 Watts Dimensions: 16"(406mm)D
17"(431mm)W
2.25"(57mm)H
Plus feet and cable clearance Mass: App 65 lb (30Kg) Supplied accessories: BLACK LABEL II+ A/C POWER CABLE
Price: $30,000.00
Παρε -παρε...οτι παρεις 30000 ψωροχιλιαρικα.............
vlasis
Φωτογράφος!
Απάντηση: NBS .....
THE NBS UNIVERSAL CD PLAYER
Specifications:
AC Mains requirement: 85-265VAC 50-60 Hz HxWxD: 6.25" x 17" x 16" (159mm x 432mm x 406mm) Weight: Approximately 72 lbs (32Kg) Outputs (L&R): Balanced, Source Z = 100 Ohms, 2Vrms
Single-ended, Source Z = 100 Ohms, 2Vrms Permissible load: Any Supplied power cable: NBS Black Label II+ Price: $50,0000.00 U.S.D.
Απάντηση: NBS .....
Αμα θες να σου δωκω το κινητο του μπαμπη να σε ενημερωξει
vlasis
Φωτογράφος!
Απάντηση: NBS .....
THE NBS PYRAMID PYRAMID JUNIOR & MONITOR III LOUDSPEAKER SYSTEMS
Monitor III
Pyramid Junior
Pyramid
SPECIFICATIONS & PRICING
PYRAMID: $75,000.00 PYRAMID JUNIOR : $45,000.00 MONITOR III: $25,000.00​
Pure Music. Sensitivity: 96 dB SPL/1 Watt @ 1m Nominal impedance: 8 Ohms Pyramid: H 66" Base 28" X 28" W 300 lbs. Pyramid Junior: H 48" Base 22" X 22" W 220lbs. Monitor III: H 35" Base 16" X 30" W 160lbs.
vlasis
Φωτογράφος!
Απάντηση: NBS .....
Εχω χασει τιποτις επεισοδια βρε παιδια????
Μπορειτε να με βοηθησετε????
Μαλλον εχω μεινει πισω ...........και νομιζα οτι επειδη πηρα 4000 κα το Κρελλι ψωνισα ακριβα.!!!!!!!!!!!!!!!!!!
:143:
Απάντηση: NBS .....
απλα δεν ξερεις που να χαλασεις τα λεφτα σου.:143:
Απάντηση: NBS .....
ότι είναι η Ypsilon, ε, μια απ'τα ίδια κι αυτή.
που το παράξενο?
vlasis
Φωτογράφος!
Απάντηση: NBS .....
Ναι ...οπωσδηποτε ...μην το ξεχασεις γιατι νοιωθω αδειος βρε Αργυριους και δεν το σηκωνω!!!:143::143:
Απάντηση: NBS .....
Ειναι τα πολλα λαυτα στις τσεπες,γιαυτο εχεις βαρος.
Με ενα richard grays καμποσες ασφαλειες hifitunning σημενιες
κατι απο δω κατι απο κει.Θα χασεις βαρος αμμεσα:143:
Re: Απάντηση: NBS .....
:143:
ελα ντε !!φαντασου 4000 !!!!
Alex_Zapantis
Απάντηση: NBS .....
Οι πελάτες τους να δεις τι θέλουν...
Άλλωστε το R&D στα καλώδια κοστίζει.:142:
Τα φτηνά δεν έχουν "χροιές"...
Άλλωστε το High End ξεκινάει από τα 5 χιλιάρικα (μίνιμουμ)...
Απάντηση: NBS .....
τελικα ρα χιλιαρικα πρεπει να ειναι
ή
Απάντηση: NBS .....
τελικα οσο πιο πολλα χιλιαρικα <φας> σε καλωδια , τοσο πιο χαιεντας εισαι:143:
Απάντηση: NBS .....
δεν ειναι μουτζες χιλιαρικα ειναι :126:, και τα χιλιαρικα ανηκουν στον λαο που τα εχειο για χαλασμα
George Markop
