Nέο Logitech Squeezebox Touch
Κώστας Φ.
Logitech® Squeezebox™ Touch. The color touch-screen Wi-Fi music player that lets you
discover a world of music. Listen to your personal digital music collection, new music
from online music services*, and thousands of Internet radio stations—all through your
stereo. A 4.3-inch color touch screen makes it easy for anyone to use.
Με υποστήριξη για 24/96.
Περισσότερα: Thread 1, Thread2
Squeezebox Touch
http://www.logitech.com/index.cfm/speakers_audio/wireless_music_systems/devices/5745&cl=us,en
System Requirements
    • For access to music on your computer use Squeezebox software with the minimum system requirements:
      256 MB RAM and 100 MB of available hard disk space
    • With any of the following operating systems:
      Macintosh: Mac OS X 10.3 or later
      Windows: 733MHz Pentium running Windows 2000, XP, or Vista
      Linux/BSD/Solaris/Other: Perl 5.8.3 or later
    • Broadband Internet connection required for Internet radio and music services
    • Stereo system or powered speakers
    • Ethernet or 802.11 b/g wireless home network
Technical Specifications
    • Audio formats:
      -MP3, FLAC, WAV, AIFF, WMA, Ogg Vorbis, AAC, Apple Lossless
      -WMA Lossless, APE, MPC and WavPack supported through transcoding
      -Some formats may require additional software installation
    • Internet radio
      -Support for MP3, Ogg Vorbis, and WMA formatted Internet Radio streams
    • Wireless interface
      -True 802.11g wireless networking
      -Support for 802.11b and 802.11g routers and access points
      -One-touch setup (with compatible WPS-supporting routers)
      -Supports WPA Personal, WPA-2AES, and 64/128-bit WEP encryption
    • Ethernet interface
      -Connects to any 100 Mbps or 10 Mbps network (with Auto MDX)
    • General:
      -USB host connector for accessing music and photos via USB drive or USB key
      -SD card slot for music and photos
      -Supports sampling rates up to 24 bit / 96 kHz
      -Stereo analog (RCA), headphone jack, digital optical, and digital coax output
      -4.3-inch 24-bit color LCD with capacitive touch screen
      -Ambient light sensor to adjust display brightness according to environment
      -Infrared proximity sensor to detect presence
299,00 δολάρια
Αναμένεται εντός μήνα στο Αμέρικα.
Υποστηρίζει 24/96
Κώστας Φ.
Πάντως το Transporter έχασε ένα μεγάλο του ατού σε σχέση με τα φθηνότερα προϊόντα της Logitech κι αυτό δεν είναι άλλο από το 24/96...
Στο transporter χρυσοπληρώνεις και το καλό DAC - αλλά μην ξεχνάτε ότι με πολύ λιγότερο από τη διαφορά στην τιμή που το χωρίζει από το Touch φτιάχνεις DAC κλάσεις ανώτερο..
Απάντηση: Re: Nέο Logitech Squeezebox Touch
Ναι αλλά δεν θα έχεις ηλεκτρονικά VUμετρα... :114:
Κώστας Φ.
Says who?! :144:
Στο παλιό γινόταν και στην SlimDevices ετοιμάζουν το αντίστοιχο plugin και για το Touch!
Εδώ το παλιό in-action (από 30sec και μετά):
[youtube]ucb9Oek7RzU[/youtube]
Απάντηση: Nέο Logitech Squeezebox Touch
Να ρωτησω κατι για το Squeezebox καθως λιγο ασχετος γενικα με το internet radio.
Τους γνωστους Ελληνικους σταθμους που υπαρχουν στα FM , τους ακούμε μέσω internet radio ?
deleted user 10898
το squeezebox touch εχει usb εξοδο για συνδεση εξωτερικου σκληρου με τραγουδια.
ενας κυριος εκει, ξερετε που ειναι οι μουρλοι ντιουηδες, το εσπασε και μπορει πλεον να συνδεθει η usb εξοδος με usb dac το οποιο να μην απαιτει drivers. τα αποτελεσματα με ayre ηταν "οτι καλυτερο σε δικαναλο εχω ακουσει στο συστημα μου (b&w 802 belcanto 1000aria κλπ...)"
του στελνεις μαιλ και σου στελνει την μοντα, μεχρι να βγει ποιο "επισημα"
και γιατι απλα να μην παρεις σημα απο την ομοαξονικη ψηφιακη εξοδο και να το στειλεις σε ενα καλο dac?
deleted user 10898
στο stereophile το διαβασα αρχικα και μετα ειδα αναφορες στα φορουμ δεξια αριστερα.
γιωργο να στο σκαναρω? δεν λεει λεπτομερειες, ψαξε γενικα και θα το βρεις.
ταντο τα μειονεκτηματα της ομοαξονικης γινονται εντονοτερα οταν υπαρχει πριν απο αυτη συσκευη με οχι ιδιαιτερες δυνατοτητες χρονισμου του σηματος. η ασυγχρονη usb στη συγκεκριμενη περιπτωση οπως στα ντακ της ayre wavelength dcs rotel (400eyro) μετατρεπει το τατσ σε ενα υψιλης αποδοσης σερβερ.
Μπά,θα του ρίξω μια ματιά όταν το ανεβάσουν online.
deleted user 10898
αυτος ακουει απο b&w 802 με belcanto ref mkII1000aria, με ψηφιακο προ με διορθωση χωρου, τον εμπιστευεσαι? χιχι που ειν ο Κωστας...
Φαντάζομαι ότι μετά το χάκιασμα, οι άλλες έξοδοι πάνε περίπατο ε? Ή όχι?
σιγουρα παει περιπατο η εγγυηση
stratos.april
