Dan D'Agostino Inc.
Legendary High-End Audio Designer Dan D’Agostino Announces New Company, New Products
New line of audio electronics is built in the USA and environmentally friendly.
WESTON, CT, SEPTEMBER 15, 2010 — Dan D’Agostino, the world’s best-known designer of high-end audio products, has announced a new company that will carry his experience and creativity into the coming decades. Dan D’Agostino Inc. will build high-end audio products in its own facility in the United States. All will be built and tested by hand, and designed for extremely low standby power consumption—a rare feature in high-end audio.
The company will begin shipping its first product, the $42,000-per-pair Momentum monoblock amplifier, this fall.
Soon to follow is the Momentum preamp, an innovative product that combines the traditional functions of a high-end analog preamplifier with the ability to play digital audio files stored on computers and hard drives.
D’Agostino is best known as the Chief Engineer of Krell Industries, a company he cofounded in 1980. During his decades at Krell, D’Agostino became the industry’s most passionate advocate for high-powered high-end amplification. His designs are used by countless speaker manufacturers in their product demonstrations and engineering labs. He sold Krell Industries in 2009, and founded Dan D’Agostino Inc. in 2010 to extend his engineering and design concepts into an all-new line of audio electronics.
“With Dan D’Agostino Inc., I want to focus on making high-end audio products more user-friendly in every way,” D’Agostino said. “These components are much more compact than the ones I’ve developed in the past, thanks in part to some innovative cooling technology. They interoperate flawlessly, so they’re much easier to use than typical high-end audio electronics.
“Dan D’Agostino products are also environmentally friendly,” he continued. “They consume far less power at idle than most high-quality audio products do. For example, the standby power consumption of the new Momentum amplifier is less than 1 watt. Some of the amplifiers with the same power rating consume hundreds of watts in standby mode.”
For more information on the Dan D’Agostino company and its products, please visit www.dagostinoinc.com.
ABOUT DAN D’AGOSTINO INC.
Dan D’Agostino Inc. was founded in 2010 by famed high-end audio designer Dan D’Agostino. The company designs and builds high-end audio electronics in its Weston, CT facility. All products are built and tested by hand to the highest standards, and all incorporate innovative design and circuit topologies not seen in any other audio products.
Απάντηση: Dan D'Agostino Inc.
The King is dead. Long live the King!
Και Μπράβο του!
Που δεν χαράμισε περισσότερο τον εαυτό του και τη ζωή του! :444:
Απάντηση: Re: Dan D'Agostino Inc.
Καλά,εμένα μου φαίνεται καρακιτσαριό,αλλά γούστα είναι αυτά..:126:
Πολλοί, τελικά απ' ότι βλέπω, έτσι χαρακτηρίζουν το αναπάντεχα και έντονα διαφορετικό-ανατρεπτικό, με αισθητικούς περιβαλλοντικούς κραδασμούς!
:107:
Και απο τιμή τεφαρίκι μόνο 42.000$ το ζευγάρι και αν θες και διενίσχυση μαζί με ένα προενισχυτή να τα 100.000$.
vlasis
Φωτογράφος!
που ειναι ο Βλασης; :116:
Παρων!!!
Λοιπον φιλε μου εγω προλαβα και τον πηρα τον Κρελλιδη μου ποιο φτηνα και ειναι και ποιο παχυς και ποιο βαρυς και ποιο κλασσατος!!!!
Αλλωστε με αρεσουν ποιο πολυ τα μαυρα κτηνη!!!!!
:137::137:
Re: Απάντηση: Dan D'Agostino Inc.
:137::137:
Θα σου έλεγα κάτι για αυτό αλλά άσε ……………. :136:
Ντιπ γούστο δεν έχει ο νταν
Μάλλον τα παλιά τα κρελ δεν τα σχεδίαζε αυτός εξωτερικά
Kotsidis John
Photography
Moυ θυμιζει πιο πολυ τιποτα σε ζυγαρια η σε βραστηρα για νερο παρα για ενισχυτη....
Και ειναι κ τζαμπα πρα-μα εε????
Εντάξει θρύλος ο D'Agostino..respect.
Bεβαια τα 42000 να πω την αλήθεια τα ...εκτιμω πιο πολύ.:136:
Όσο για την εξωτερική του σχεδίαση-εμφάνιση επειδή δεν είμαι στην καιμπραρισμενη ΕΙΖΟ μου για να βλέπω σωστα τα χρώματα,αν το χρωματάκι στα πλάγια είναι χάλκινο οκ έχει άποψη,αν είναι ροζουλι όπως φαινεται στην οθόνη του φορητού μου θυμίζει την μπιζουτιέρα της συμβίας μου...
Ημίθεος
εγω βλεπω πολυ εντυπωσιασμο για να ζητησει μετα τα 42000$
Εμ, άμα έκανε μόνο 39000$, δε θα έπαιζε τόσο καλά. Δεν το μάθατε ακόμα το ποίημα;
Σαν χιουμιντορ ειναι και το οργανο μπροστα ειναι το υγρομετρο.:142:
COSTOPOULOS NIKOLAS
