Seaton sound
Eξ Αμερικής τα παρακάτω καλούδια:
Catalyst
Drive Units:
  • High efficiency, Italian made, 8" coaxial midrange w/ Neodymium compression tweeter.
  • Custom built, low distortion, high excursion, 12" sealed woofers utilizing a full copper sleeve over the pole piece for exceptionally low inductance and increased linearity.
Electronics & Amplification:
  • Internally powered, tri-amplified design.
  • Three (3) ICEpower channels of amplification with 24-bit/96kHz DSP executing the crossover design and response contouring.
  • 300W powering the coaxial 1" Neodymium compression tweeter
  • 700W powering the 8" midrange (coaxial with tweeter)
  • 1000W powering the pair of 12" sealed woofers.
  • Galvonic isolation of XLR inputs.
Σιγά μη σας άφηνα χωρίς διάγραμμα:138:
Απάντηση: Seaton sound
SubMersive
  • Dual, custom designed, 15" drivers with 3" diameter voice coils
  • A sealed enlcosure constructed only 20 miles from our warehouse with precision CNC cut and lock mitered construction.
  • Drivers on opposing faces for a completely inert, stablized cabinet that won't walk, shake or quiver.
  • A robust, high efficiency, 1,000W ICEpower based amplifier with SMPS power supply.
  • Isolated balanced input eliminating common ground loop problems
  • Cabinet dimensions: 24.25" W x 17.5" D x 25.5" H
  • Frequency response: +/-3dB 18-200Hz - outdoor ground plane
Και σε όσους τα 1000watt φαίνονται λίγα...
Κλικ
Και για όσους θέλουν να νίωθουν(που ΄σαι Flash με τα κλιπσάκια σου:116:)
Terraform XL
High Output, Ultra Low Frequency subwoofer design
  • Two(2) 15" drivers (internally mounted)
  • Two(2) 18" passive radiators (HF chamber)
  • large enclosure with slot vent tuned to ~12Hz
  • DSP Controlled (manufacturer only) class D amplifier 4000W burst power (>1200W long term)
  • Tentative dimensions: 54" x 22.5" x 28"
  • Frequency response: 15-100Hz +/-3dB - in-room extension 10-11Hz
  • Weight: ~280 lbs
Οι πτωχοί συγγενείς πάνε εδώ:
Spark
Internally Bi-amplified (160W-140W) loudspeaker
  • 8" coaxial midrange w/Neodymium magnet 1" HF driver
  • Compact vented 2 way design
  • Intended operating range: 70-20,000 Hz
  • 17" H x 11" W x 11" D
  • 36 lbs.
  • Textured black finish
Re: Απάντηση: Seaton sound
Εντυπωσιακό το XL, αλλά θα προτιμούσα πολλαπλά sealed Submersive. :116:
δημητρη κανε 2 βδομαδες υπομονη , και θα δεις..........
Απάντηση: Re: Απάντηση: Seaton sound
Γιατί σου είπε κανείς ότι αυτό μπαίνει χωρίς τα submersive;:138:
Ξέρεις,για συμπλήρωμα ακόμα πιο χαμηλα..
Η αλήθεια είναι ότι πρώτη φορά βλέπω σαμπ με δύο 15ιντσα εσωτερικά ενεργά, με δύο εξωτερικούς 18ιντσους ακτινοβολητές.
Και με συχνότητα συντονισμού στα 12hz στο port, φαίνεται ενδιαφέρον.
τι θα παιζ ειναι το ζητουμενο
Ε, εντάξει, για σεισμό θα είναι ούτως ή άλλως. Κακό δεν θα είναι.
Ξέρουμε μήπως αν υπάρχει αντιπρόσωπος στην Ελλάδα;
Δεν εννοεί αυτά ο Αργύρης. Αυτά είναι Internet Direct ή απ΄ευθείας από τον τυπά γιατί δεν πουλάει μεσω dealer. Αυτά τότε που του είχα μιλήσει πριν 1 χρόνο.
Σωτήρηηηηηηηηηηηηηηη..
Σειρά σου..
Τι να πω..τον τύπο τον εκθειάζουν όσοι τα αγοράζουν. Από εκεί και πέρα μόνο αν τα πάρει κάποιος θα δούμε.
Πάντως κάποια στιγμή ίσως πάρω ένα ζευγαράκι γιατί θα σκάσω. Αν δε παίζει θα το κρατήσω για πάρτυ!:137:
παιδια και αλλο κατασκευαζουν ηχεια φωτοβολιδες, δεν θαβω αυτα αλλα καλο ειναι να τα ακουσουμε πρωτα.
manos.papadopoulos
