Δοκιμή των Dune HD Max & Smart B1-D1-H1,Duo
Απάντηση: Δοκιμή των Dune HD Max & Smart B1-D1-H1
Εδώ οι αλλαγές που φέρνει το νέο firmware:
Changes since 101201_1626:
* Various playback improvements.
- Bugfix: Specific MP3 files were playing with distortions when played
during photo viewing.
- Bugfix: Specific AVI files with AC3 audio were playing without sound,
and no file with audio could be played afterwards.
- Bugfix: Specific AVI files with H.264 video were not playing, and no
other video file could be played afterwards.
- Improvement: unsupported non-LC AAC audio tracks in MKV are not shown
in the list of audiotracks to avoid confusing the user.
- Bugfix: The setting "HDMI audio = disabled" did not work properly in
some cases with some equipment.
- Bugfix: Specific AVI files with AAC audio could not be played
correctly.
- Added support for playback and recorinding of A/V streams based on MMS
protocol (useful for MMS-based Internet Radio and Internet Video
resources).
* Added support for MMS audio/video streaming protocol.
- Useful for MMS-based Internet Radio and Internet Video resources.
- Both playback and recording of MMS streams is supported.
- Usage: launch playback of MMS URL ("mms://...") via .M3U playlist file
or in any other way supported by Dune.
* Volume control improvements.
- Added a new setting "Audio / Volume control" with the following
possible values:
- "Off". Volume control is completely disabled. The volume level is
fixed at 100% (0dB) and the player does not perform any
modifications of the digital audio signal.
- "Best quality". The default setting. The user is allowed to control
the volume in the safe range till 0dB (ensuring no audio
distortions on all audio content). When needed for specific files,
it is also possible to temporarily overcome the 0dB limit by
pressing and holding "V+" RC button for several seconds (the
increase volume level takes effect only for the current playback
session and is automatically reset to 0dB when the playback session
finishes).
- "Allow overload". The setting corresponding to the behavior taking
place in previous firmware versions. The user is allowed to set the
volume to values greater than 0dB. Depending on played content,
this may lead to severe audio distortions and thus is not
recommended.
- Added a new setting "Audio / Volume indication" with the following
possible values:
- "Percents". The default setting. The volume level is shown as
[0..100%] (corresponding to [-48..0dB] range). When the volume
level is set to 100%, the player does not perform any modifications
of the digital audio signal. Overloaded volume level is shown as
(100..150%] (corresponding to (0..+24dB] range).
- "Decibels". The setting corresponding to the behavior taking place
in previous firmware versions. The volume level is shown in
decibels.
- Volume control for background audio during photo viewing is
implemented in the same way as for regular file playback.
- NOTE: As in previous firmware versions, the player can apply volume
control only to PCM audio signal (i.e. when playing PCM audio tracks
or audio tracks which are decoded by the player itself); when using
"bitstream" audio output mode and playing audio tracks supporting
bitstream output, the volume control does not take any affect. When
A/V receiver is used, it is recommended to control the volume using
the A/V receiver.
* Other OSD improvements.
- When performing time navigation using LEFT/RIGHT/UP/DOWN/P+/P- RC
buttons (in file/DVD playback mode), the OSD does not only show the
selected playback position, but also shows the offset from the current
playback position.
- Certain notification OSD elements, such as volume control and certain
information messages can now be quickly hidden by pressing any
non-relevant RC buttons (no need to wait for autohide timeout).
* Added IP Control possibilities (control the player from iPhone etc).
- A simple HTTP protocol allows to control the player from network
(start/stop playback of the given media resources, control the
playback, check current player status, emulate RC button presses,
etc).
- Applications for various devices can be created based on this IP
Control procotol. Several such applications are already announced /
provided (e.g.: applications for iPhone/iPad, integration with
Control4 smart home systems).
- More information: http://dune-hd.com/support/ip_control
* Added new possibilities for authors of FlashLite applications.
- Added ability for FlashLite application to store persistent data in
the flash memory of the player ("persistent SharedObjects").
- Added support for showing specific text message on the front panel
display (for player models having front panel display) on startup of
FlashLite application.
- More information: http://dune-hd.com/support/flash
* Added new UI customization possibilities (for "dune_folder.txt"
applications).
- Added a possibility to load icons shown in the right panel of the
"extended list view" asynchronously. When this feature is enabled,
navigation in such folders becomes much faster.
- Syntax:
- async_icon_loading = yes
- Added "icon_archive" feature, allowing to download a collection of
icons/images from an HTTP server once when entering certain folder,
and cache it in the player (in System Storage), that allows to
significantly improve the performance.
- Syntax:
- icon_archive.{n}.name = {name}
- icon_archive.{n}.url = {HTTP-URL-to-TGZ-archive}
- icon_path = icon_archive://{name}/{file-path-in-archive}
- When a new version of the icon archive is deployed on the HTTP
server, a modified URL should be used for it, then the player will
automatically reload the icon archive next time when the user opens
the folder.
* Setup usability improvements.
- When the user tries to exit "Video" or "Network" setup screen with
unsaved changes, a warning dialog is shown. The user is asked to
either apply the changes, discard the chances, of cancel the action.
- When selecting WiFi network connection type, the WiFI settings dialog
is shown automatically.
- When selecting PPPoE network connection type, the PPPoE settings
dialog is shown automatically.
- Online firmware upgrade function does not require an attached storage
device (such as USB flash drive) any more.
* Added built-in functions for management of System Storage.
- New Setup page "Miscellaneous / System Storage" provides the following
functions:
- "Initialize System Storage": allows to initialize the system
storage if it is not configured yet. Two possibilities are
provided: create the system storage on an empty storage device (USB
flash drive, SD card, an already existing HDD partition), or
partition an empty HDD into system storage and user data
partitions. Usage instructions:
- The system lists all found empty 1GB+ storages.
- Select the desired storage.
- If the selected storage's capacity is less than 100GB, the
entire storage is initialized as the system storage.
- Otherwise, if the selected storage is 100GB+ storage device, it
is partitioned into two partitions, the first partition is
initialized as the system storage, and the second partition is
kept unformatted (to format it, select it in the file browser
and press ENTER).
- "Deinitialize System Storage": allows to deinitialize the system
storage if it is already configured.
- "Clear System Storage": deletes all data stored on the system
storage. This, in particular, includes Blu-ray cache, main screen
shortcuts, content of Internet Radio and IPTV folders.
- "Clear Blu-ray Cache": clears Blu-ray cache (also known as "Blu-ray
local storage").
* Added support for "Flash Memory Storage" - an area of main flash
memory that can be used to store data instead of System Storage in some
cases.
- Flash Memory Storage currently can be used to store the following
data:
- Data cache for dune_folder.txt applications utilizing
"icon_archive" function (graphics packages downloaded from
Internet).
- Data cache for KartinaTV application (graphics and some other
information downloaded from Internet).
- For all other kinds of data that can be stored in System Storage,
Flash Memory Storage can not be used, and System Storage is still
required. This includes, in particular: Blu-ray cache, main screen
- In future, it is planned to allow to use Flash Memory Storage for more
player functions.
- The purpose of Flash Memory Storage is that it makes it easy to use
the corresponding player functions for the users not having System
Storage attached. When System Storage is available, Flash Memory
Storare is not used (System Storage is used instead).
- Flash Memory Storage availability and capacity depends on a particular
Dune model.
- Dune HD Max, Dune HD Duo: Flash Memory Storage is always available
and its capacity is ~100MB (due to total 256MB of main flash memory
in these models).
- Dune HD Base 3.0, Dune BD Prime 3.0, Dune HD Smart D1/H1/B1: Flash
Memory Storage can be enabled/disabled (disabled by default) and
its capacity is ~16MB. Enabling Flash Memory Storage is performed
automatically when it is needed for the first time, or can be
performed manually via Setup. When Flash Memory Storage is enabled,
some optional firmware components (asian fonts) are removed from
the flash memory. When firmware is reinstalled/updated, Flash
Memory Storage becomes disabled again and these optional firmware
components are restored automatically (until Flash Memory Storage
is required again by some application). If these optional firmware
components are required, Flash Memory Storage can not be used
(System Storage should be used instead).
- Dune HD Lite 53D: Flash Memory Storage is always available and its
capacity is ~16MB.
- Setup section "Miscellaneous / System Storage" allows to see the
current status of Flash Memory Storage and provides the following
functions:
- "Enable Flash Memory Storage": allows to enable Flash Memory
Storage (only for Dune models where Flash Memory Storage is
optional, other Dune models have Flash Memory Storage always
enabled).
- "Clear Flash Memory Storage": deletes all data from Flash Memory
Storage.
* Improved "Reset Settings" function.
- The confirmation dialog includes the information that player reboot
will be performed.
- Added clearing of all user-related data stored by the player in System
Storage (including main screen shortcuts and cached icon archive
data). NOTE: the content of Internet Radio and IPTV folders is not
cleared automatically (since these folders may contain files important
for the user); if needed, these folders can be cleared manually.
- Added clearing of all data in Flash Memory Storage.
* Integrated "KartinaTV" Internet TV service.
- More information: http://dune-hd.com/support/kartina_tv
* Integrated "IVI.ru" Internet Video service.
- More information: http://dune-hd.com/support/ivi_ru
* Various other improvements.
- The function of quick video mode choosing now provides feedback using
the LED on the front panel of the player:
- When the function is activated: the LED blinks once.
- When the user cancels the function: the LED blinks once.
- When a new video mode is chosen: the LED blinks 2 times.
- When the user confirms the new video mode: the LED blinks 3 times.
- Some interface languages added/updated.
- Some other improvements/fixes.
* Includes also all changes from 101201_1626.
όσον αφορά τα άλλα όμως...
Αγαπητοί φίλοι γεια σας.
Είμαι κάτοχος ενός Egreat M31B από το οποίο είμαι πολύ ευχαριστημένος.
Επειδή όμως έχει αρχίσει να δείχνει σημάδια γήρανσης άρχισα να γλυκοκοιτάζω τα Dune και ειδικότερα το Η1. Τα reviews του Ram και του hitech καθώς και το πολύ καλό review του lesarros με «έπεισαν» πως αυτό το player θα είναι η επόμενη αγορά μου κι έτσι, απλά περίμενα να γίνει η εισαγωγή από την αντιπροσωπεία για να γίνω ευτυχής κατοχός του.
Όταν έμαθα από αυτό το forum ότι ξεκίνησε η διάθεση των smart H1 στην εξωπραγματική τιμή των 320€ (τα περιοδικά ανέφεραν τιμή 275€, τιμή ήδη τσιμπιμένη σε σχέση με όλη την υπόλοιπη Ευρώπη) επικοινώνησα με την αντιπροσωπεία για να επιβεβαιώσω την τιμή θεωρώντας πως ο Αντρέας ίσως να έχει κάνει κάποιο λάθος (με δεδομένο μάλιστα ότι το Η1 παρουσιάζεται ακριβότερο από το D1!!!!) Με μεγάλη μου έκπληξη πληροφορήθηκα από πωλητή της εταιρίας ότι πράγματι το Η1 κοστίζει 320€ και σε ερώτηση μου γιατί τα περιοδικά αναφέρουν 275€ η απάντηση ήταν πως τα περιοδικά είχαν γράψει μία τιμή «κατά προσέγγιση» και τώρα που έγινε η εισαγωγή υπολογίστηκαν τα τελικά κοστολόγια.
Αγαπητοί φίλοι, φαντάζομαι ότι οι περισσότεροι από εμάς προτιμάμε να κάνουμε τις αγορές μας από την Ελλάδα ακόμη κι αν υπάρχει μια μικρή επιβάρυνση που δικαιολογείται από το μέγεθος της ελληνικής αγοράς και τον αυξημένο ΦΠΑ αλλά μήπως πρέπει κάποιες αντιπροσωπείες να αλλάξουν λογική τιμολόγισης; Το ότι ένα προιόν έχει καλές κριτικές και αυξημένο ενδιαφέρον από τους καταναλωτές πριν καν εισαχθεί δεν είναι λόγος για να τιμολογηθεί σχεδόν 50% ακριβότερα από τη Γερμανία. Ενδεικτικά αναφέρω πως το Η1 το βρίσκω σε αρκετά (και αξιόπιστα) γερμανικά e-shops στα 240€ μαζί με τα μεταφορικά ή στα 320€ (όσα ζητάει ο εδώ αντιπρόσωπος) μαζι με σκληρό δισκο 2Tb!!!!!!!!!
Είναι κρίμα να αναγκαζόμαστε να κάνουμε ακόμα πιο ισχυρές τις ήδη ισχυρές ξένες αγορές αλλά δυστυχώς όταν οι διαφορές στις τιμές είναι τόσο μεγάλες και μάλιστα σε εποχή οικονομικής κρίσης το συμφέρον υπερτερεί του φιλοτίμου. Βεβαίως σε μια ελεύθερη αγορά ο καθένας έχει δικαίωμα να καθορίζει τις τιμές του. Η πρόθεση αυτού του ποστ δεν είναι να προσβάλεικανέναν απλά παραθέτω τους προβληματισμούς μου διότι υποθέτω πως κι άλλοι συνφορουμίτες αισθάνονται ανάλογα. Ζητάω συγγνώμη αν κούρασα κάποιους με το μέγεθος του ποστ μου και ευχαριστώ για τη φιλοξενεία.
Aγόρασα σήμερα το Smart D1 και το εγκατέστησα αμέσως. Πολύ όμορφο μηχάνημα και φαίνεται κι ευκολοχείριστο. Οι πρώτες εντυπώσεις, λοιπόν είναι θετικές. Η εικόνα του είναι καλύτερη (στα δικά μου μάτια) από το WD TV Live που οδεύει τώρα για την κρεβατοκάμαρα.
Ερώτησή μου είναι αν συνίσταται να αναβαθμίσουμε το firmware την τελευταία έκδοση που είναι beta. Eδώ όμως, το θέμα είναι ότι προσπαθώ να κατεβάσω το 110127_2105_beta firmware από το site που προτείνει ο Ανδρέας, αλλά μου βγαίνουν κάτι αλαμπουρνέζικα... Υπάρχει τρόπος να το βρούμε από αλλού;
Re: Απάντηση: Δοκιμή των Dune HD Max & Smart B1-D1-H1
Να αναβαθμίσεις άμεσα στο τελευταίο firmware κι ας είναι beta.Μη το φοβάσει είναι το καλύτερο firmware που έχει βγάλει ως τώρα η Hdi για όλα τα μοντέλα της!
http://files.dune-hd.com/firmware/hdsmart_d1/dune_firmware_hdsmart_d1_110127_2105_beta.dff.zip
Θα γίνει απόψε...
Ευχαριστώ lessaros!
Καλησπέρα. Μόλις παρέλαβα. Λεπτομέρειες εντός ΣΚ
Παιδιά το μηχάνημα δεν παίζεται. Κάνει τα πάντα όλα. Και επειδή κάνει τα πάντα όλα σκέφτηκα να του βάλω και το νέο - έστω beta firmware - και τον ήπια. Φαίνεται ότι κράσαρε και δεν ξεκινάει. Δείχνει μια σελίδα loading και τέλος. Πάγωμα (blank screen). Δοκίμασα να βάλω σε στικ το προηγούμενο firmware που είχε όταν ήρθε. δείχνει ότι διαβάζει το στικ για λίγα 3-4 secs και μετά πάγωμα. Καμιά ιδέα;
Κάτι κατάφερα. Βάλε βγάλε το στικ, συνεχή reboot, φαίνεται να δουλεύει. Ουφ. Εντυπώσεις (αν και τα έχει πει ο Λεωνίδας) πολύ σύντομα. Πρώτη εντύπωση παίζει τα πάντα αέρα. Και το σημαντικότερο ότι κάνει τα νέα φορμά passthrough...
Λοιπόν. Επιγραμματικά για να μην κουράσω. Ό,τι εξτρά θέλετε μου λέτε να δω:
-Παίζει iso από δίκτυο (κανένα κόλημα)
-Παίζει bluray folder από δίκτυο (κανένα κόλημα)
-Mkv 720-1080 άνετα
-Εννοείται υπότιτλους srt
-Κάνει passthrough τα DTS-MA - DD+ σε απλά DTS - DD (από τα πιο σημαντικά features για μένα)
-Πολύ smooth κίνηση σε ό,τι δοκίμασα μέχρι τώρα.
-Από ήχο έπαιξε τα πάντα μέχρι και 96 Khz/24 bit που έχω
-Μουσικά video με DTS άνετα
-Γενικά τα πάντα
Σύνδεση HDMI με προβολέα για εικόνα και οπτική ίνα για ήχο
Σαν συμπέρασμα θα έλεγα ότι είναι μια εξαιρετική αγορά. Ενδεχομένως να υπάρχουν (που υπάρχουν) και φτηνότερες λύσεις, αλλά οι δικές μου απαιτήσεις έχουν να κάνουν με streaming δύσκολων αρχείων από NAS, σημείο στο οποίο το DUNE έδειξε ότι δε μασάει.
HIGHLY RECOMMENDED!!!
Να μην ξεχάσω ότι όντως με το τελευταίο fw κλειδώνει το audio output στο 100% ώστε να μην κάνει καμια επεξεργασία ήχου εσωτερικά...
αυτη την βδομαδα παραλαμβανω και εγω Smart B1 πως κανω το update,το βαζω σε φλασακι και μετα,ευχαριστω
Εμένα μου το βρήκε Online. Δηλαδή το είχα στο δίκτυο και με το που έκανε boot μου βρήκε όλα τα διαθέσιμα fw με ένδειξη αν είναι beta ή όχι. Βέβαια όπως έγραψα πιο πάνω έφαγα και κόλλημα, αλλά τελικά όλα καλά.
Μάλλον είναι καλύτερα να το βάλεις σε στικ και να μην το έχεις συνδεδεμένο στο δίκτυο.
Πάντως είναι φοβερό μηχανάκι. Από ό,τι δείχνει το τρέχον sigma 8643 είναι υπερ αρκετό για ό,τι κυκλοφορεί αυτή τη στιγμή και το streaming γίνεται απροβλημάτιστα ακόμα και με 100Mbit ethernet.
Αποσυμπιεσμένο στο φλασάκι, πηγαίνεις από το μενού του Dune> Usb disc, enter, βρίσκεις το αρχείο, enter επάνω του και τα υπόλοιπα τα κάνει το Dune.:126:
Μετά από μια εβδομάδα συμβίωσης με το Η1, οι εντυπώσεις από το μηχανάκι θετικότατες.
Πέρασα το beta firmware από φλασάκι χωρίς κανένα πρόβλημα και είδε αμέσως τα shared folders του pc (windows 7). Άψογο streaming σε 1080p ματρόσκες αν και το έχω πάνω σε 100αρι hub. Ακόμα και ο 2ΤB δίσκος της Samsung που ήρθε μαζί με το Dune, αν και φορμαρίστηκε σε Ntfs για πιο εύκολη ανάγνωση από το pc, παίζει μια χαρά. Τώρα το Egreat θα μετατραπεί σε καλαμπόκι και θα πάρει τη θέση του στη βοηθητική τηλεόραση
Παιδιά το H1 είναι και ασύρματο (ή μπορεί να γίνει με κάποιο usb stick?)
Για μουσική το προτείνετε? (εκτός από τις ταινίες που το θέλω). Παίζει flac?
Ευχαριστώ.
Απάντηση: Re: Δοκιμή των Dune HD Max & Smart B1-D1-H1
Ευχαριστώ.
παιζει
κοιτα και δες τι αρχεια υποστηριζει
http://dune-hd.com/hd_players/current/132-dune-hd-smart-h1.html
intergrale
