Bergmann Audio Sleipner
Απάντηση: Bergmann Audio Sleipner
Πικάπ που δεν λέγεται sl 1200, απο και εως mk5 δεν είναι πικάπ.
Aπό το site του κατασκευαστή:
"Speed stability
As mentioned before, the platters speed stability is of a vital importance for the extraordinary musical experience. Several elements have an influence:
1. The bearing must have as low friction as possible.
On our reference model the platter is supported and centered by air. This means that the platter has no physical contact with the rest of the turntable - except from the contact with the driving belt - and with that no friction or mechanical noise at all.
2. The motor must be running in a uniform speed.
We have choosen DC motors which run in a high speed. A higher speed from the driving element secures an improved speed stability for the platter. The motor is supplied with a pure and even current from a seperate motor control to optimize the motors rotation. Our reference model is delivered with battery power supply for the motor to ensure the purest current as possible.
3. The driving belt must be made very precisely.
The platter is driven by a very precise flatbelt with a very uniform material thickness. A flatbelt can be produced within the finest margins."
Αφού λοιπόν συμφωνήσουμε απόλυτα μαζί του, περιμένουμε να δούμε την μετρημένη επίδοση της δημιουργίας του. Επιτέλους, αφού είναι τόσο ακριβό,ω μπαρδόν, καλό, τι ακρίβεια περιστροφής έχει;
Άραγε έφτασε το 0,002; (ΜΚ2).
Έστω το 0,01; (ΜΚ1)
Λογικό;
Επίσης:
1) Rumble;
2) Wow & flutter;
Αμ' δε... (Mετά)αναλογική εποχή...
:122:
AudioFuture
