USB vs S/PDIF
By Michael Fremer • Posted: Jan 21, 2011
Ayre Acoustics' designer, Charlie Hansen, has little good to say about S/PDIF.
He claims that asynchronous USB performs far better, which is one reason he omitted an S/PDIF input from the DX-5.
I could hear no differences between CDs played on the Audio Alchemy transport and fed to the Debussy via S/PDIF, and the same CDs ripped to and played by the Sooloos music server and connected to the Debussy via S/PDIF.
I could also hear no differences between CDs played via S/PDIF, and the same CDs ripped and played via USB.
However, the 24-bit/96kHz files of Markus Schwartz's Equinox, transferred to the Sooloos and then fed via S/PDIF to the Debussy, sounded quite different from the same files decoded via the Debussy's USB port.
The USB playback was noticeably airier and more spacious; the S/PDIF version sounded flatter and somewhat thicker, but also had more bass, which could have accounted for the thickness.
This was disturbing -I would have preferred to have heard no difference at all.
It made me wonder: Since the Sooloos server is essentially a computer, why doesn't it have a USB output?
That said, I heard no differences between the 24-bit Beatles files decoded via S/PDIF–Sooloos and MacBook Pro–USB, so perhaps something else was involved in the different sounds of the Equinox files.
You can't really fight it, nor should you: the Blu-ray disc excepted, the future of digital storage and playback is not any sort of silver optical disc.
Rather, it will be hi-rez files downloaded from the Internet, stored on a hard drive, and decoded by an outboard, multi-input D/A converter such as the dCS Debussy.
I don't see how even the most committed analog diehard would not enjoy the sound of high-resolution digital files decoded by the Debussy, fed via S/PDIF from either a dedicated music server like the Sooloos or via USB from a computer hard drive.
S/PDIF vs USB, Conclusion
Πλήρες
deleted user 10898
να διαβαζεις και τις μετρησεις στο τελος...
Finally, the Debussy offers superb rejection of jitter via both its AES/EBU and S/PDIF inputs and via USB, so I am not sure why MF found the two input modes to sound different from one another.
οταν υπαρχει τετοιος μηχανισμος μειωσης του jitter οπως στο debyssy,weiss κλπ κλπ ολες οι ΠΟΡΤΕΣ ειναι ιδιες... οταν δεν υπαρχει... τοτες ακους τα τρανσπορτς...
Απάντηση: USB vs S/PDIF
μην είσαι απόλυτος.
τα τράνσπορτς μπορούν να αφήσουν "ανεξίτηλα σημάδια" από τη μια, ενώ ο όποιος μηχανισμός επανασυγχρονισμού, μπορεί να προσπερνάει κάποια προβληματάκια. Εκτός κι αν θεωρείς εντελώς και απολύτως τέλειο τον επαναχρονισμό των μηχανών που αναφέρεις, κάτι που όμως (ενημερωτικά) δε το θεωρούν οι κατασκευαστές του.
deleted user 10898
Re: Απάντηση: USB vs S/PDIF
μην είσαι απόλυτος.
ποτε δεν ειμαι απολυτος, απλως αυτο ειναι ενας γενικος κανονας.
οσο καλυτερος ειναι ο μηχανισμος "αντιτζιτερ" τοσο ποιο λιγο ακουμε τα τρανσπορτ.
τα τεχνικα προβληματα τα ξερω (και τα εχω πληρωσει σε ευρα)
αυτο που εχει ενδιαφερον (και θα ηθελα να συζητηθει ισως στο νημα της hegel..) ειναι εαν μια ασυγχρονη μεταφορα δεδομενων (τυπου asynchronus usb η firewire) που μειωνει δραματικα τα σφαλματα χρονισμου ειναι ισαξια σε αποτελεσμα με mια αριστα υλοποιημενη λυση επαναχρονισμου με 2 ρολογια ακριβειας και μεγαλο buffer (psaudio,naim, και τωρα ισως hegel..)
η κοντρα πχ hegel (σαν usb to spdif) - hiface evo εχει ενδιαφερον...
ΙΜΗΟ, η πραγματική ακρίβεια του ρολογιού, δε παλεύεται. Αν μιλάμε για το "απόλυτο όπλο" στο χώρο της υψηλής πιστότητας αναπαραγωγής, μιλάμε υποχρεωτικά για ρολογάκι ακριβείας, ξέρεις, σαν αυτό το αντιλοπίσιο, ή σαν αυτό το πιο φτηνό ατομικό που μας έδειξε ο μπούτχιας.
Εκεί για μένα τελειώνει η συζήτηση, και οι "κόντρες" δε με απασχολούν.
... the Debussy offers superb jitter rejection via its AES/EBU, S/PDIF and USB inputs...
Να υποθέσω αυτό το λέει έχοντας κάνει τις μετρήσεις του...
... so I am not sure why MF found the two input modes to sound different from one another.
Γράφει κάπου μέσα στο κείμενο (είναι καιρός που το διάβασα και δεν θυμάμαι)
αν ήταν το ίδιο είδος καλωδίων σε όλες τις συνδέσεις που δοκίμασε?
... ή τις διαφορές των καλωδίων (για όσους πιστεύουν, φυσικά, σε αυτές...)
deleted user 10898
κωστη δεν ειναι ακριβως ετσι, η ακριβεια του ρολογιου ειναι το ενα.
ο τροπος διαχειρησης των δεδομενων ωστε το ακριβες ρολοι να τα χρονισει καταλληλα ειναι εξισου σημαντικος.
κοιτα τι κανει η αντιλοπη στο dac της (που εχει σημαντικα καλο ρολοι) και πως με καλο εξωτερικο βελτιωνεται περεταιρω.
Antelope's proprietary async USB implementation runs a buffer and field-programmable gate array to apply signal dejittering to byte-by-byte data extraction from the buffer. It runs both Windows and OS firmware for bidirectional communication protocols and special device drivers for USB 2.0 high speed. Actual data processing past establishing the data comm link with the host computer of course remains identical between different operating systems. As Igor Levin put it, "the jitter management module derives the sample rate via a DSP process that is largely insensitive to the USB packet arrival jitter. The reconstructed audio clock is acoustically pleasing and does not contain any measurable jitter products above 10Hz." For further sound enhancements, one can reference the Zodiac+ to Antelope's 10M+ Trinity/OCX master clock via the word-clock input. This supposedly results in "dramatically opening up the stereo image to reveal more details in three-dimensional space."
δε νομίζω να υπάρχει καμιά συσκευή που να έχει στην πλάτη της BNC βύσμα για ρολογάκι, κι αν της δώσεις μια ατομική αντιλόπη να καταφέρεις να μετρήσεις τζίτερ!!
το πως το κάνει ο καθένας, είναι μια άλλη ιστορία.
deleted user 10898
ουυυυ υπαρχουν παμπολες συσκευες που δεν μπορουν να διαχειριστουν τα εισερχομενα δεδομενα καλα πριν τα επαναχρονισουν, οποτε οτι και να τους βαλεις να τα χρονισει αστο.
παντως συμφωνω σε ολα, τα ιδια λεμε με μικρες διαφορες στις λεπτομερειες...
βαρεθηκα...
ολο δυο τρεις μιλαμε και για τα ιδια πραγματα....
καλα που στην ριαα γινεται λιγακι κουβεντα...
Τι θα γίνει ρε Νικόλα μ'αυτή την... υπογραφή σου??? :121:
Έχει συνέχεια. Δε θα την πω.
Κάθε φορά που την βλέπω μου φαίνεται σα να'ναι ημιτελής η απάντησή σου και... αγχώνομαι... :140:
:135:
:135:
Άλλαξε skin...:138:
(κάντε κάτι για να ξεχωρίζουν οι υπογραφές στο AfterDark πάντως...)
deleted user 10898
:143::143::138:
Berkeley Audio Design Alpha USB to AES/SPDIF converter
Πλήρες, The long awaited asynchronous USB to AES/SPDIF converter has been officially announced by Berkeley Audio Design.
The US retail price will be $1,695 and will ship in about 4 weeks.
The Alpha USB interface uses the industry leading Streamlength Asynchronous USB implementation.
Audiophilleo 1 με δύο λ για να είναι και όχι μόνο να δείχνει πλλουσιότερο...
Φυσικά είναι χαι ενδ αφού έχει 895$, η οθονούλα όμως είναι όλα τα λεφτά. Υπάρχει και η πτωχότερη έκδοση Audiophilleo 2, χωρίς την οθόνη και λοιπά παραφερνάλια (jog) της ακριβής έκδοσης (δεν καταδέχομαι να διαβάζω ποσο ζητάνε για την πτωχή).
Φοβερό σχόλιο στην φθηνή έκδοση :
• Any color you want, as long as it’s metallic gray :116:
Πλάκα έχουν.
http://www.audiophilleo.com/audiophilleo1.aspx
Nickk
