οppo 93
Απάντηση: οppo 93
ξεχασα ,,, του κουμπωσα και φλασακι μπροστα και παιζει μια χαρα φλακ.
Απάντηση: οppo 93
Oppo Digital in a few short years has become a force in home entertainment, competing with, and sometimes embarrassing some of the well established giant conglomerates that produce audio visual components sold to mass markets. Their first products were feature packed "universal players" that could handle DVD video, DVD-A audio, and SACD/CD discs. They also decoded HDCD, and could handle just about any video format through a USB input. They were priced at too good to be true prices, and performed at a level unseen at those price points.
A few years ago I bought an Oppo DV- 980H DVD player and was absolutely blown away by the quality of video playback, the feature set, connectivity, and ease of use. I thought audio playback was what you would expect for a budget component. Styling and reliability were well beyond what you would normally get for around $180. The DV-980H was also a universal player, and had digital outputs, video up scaling, and a great user interface.
Oppo continued to update their products and blazing speeds. They redesigned power supplies, upgraded firmware, re-engineered signal paths and chassis design, and just plain led the pack. The company began to get notice from the audiophile community with several positive reviews in the two major domestic hifi publications and all over the web. The ability to playback DVD-A and SACD was certainly an attention getter, as those formats have been completely ignored outside of the audiophile world. Oppo players began appearing as “special editions” and were even modded by third party companies to maximize audio and video potential.
But Oppo has not rested on its laurels. They have a line of Blu-Ray players that is already turning heads as the new format starts to increasingly make its way as the video disc du jour. The promise of Blu-Ray offers unparalleled resolution, and enormous storage capacity. My brief encounters with Blu-Ray were quite impressive, but I had not yet tested it yet in my own set up. That brings us now to the subject of this review, the BDP-93 Network Blu-Ray player. The BDP-93 also handles 3D Blu-Ray discs. It is priced at $499 and is available directly from Oppo and from various other online sources.
Internally, the BDP-93 is packed with cutting edge technology. I won’t turn this review into a technical white paper, but some of the BDP-93 design and guts deserves some mention. First it offers cutting edge networking options, which allows the Oppo to act as a de facto entertainment hub. For state of the art video performance, Oppo says “the BDP-93 incorporates Marvell's Kyoto-G2 video processor with the second generation Qdeo™ technology. Qdeo video processing delivers a truly immersive viewing experience by rendering quiet natural video free of noise and artifacts for all types of content. For high-quality Blu-ray content, the BDP-93 faithfully reproduces the program just as the director intended; for DVD, the up-converted picture quality bridges the visual gap from your current DVD library to Blu-ray disc.”
The BDP-93 also incorporates True 24p™ Video. Oppo says “many Blu-ray Discs are recorded at 24 frames per second, the same frame rate as the original movie's theatrical release. The BDP-93 can faithfully redeliver the original frames using 1080p 24Hz output (compatible display required) for smoother motion and a flicker-free, film-like home theater experience.” Of course the player also decodes just about every digital format including, Dolby® TrueHD and DTS-HD Master Audio™.
On the audio side, Oppo has taken great pains to improve sound quality and flexibility by tweaking an already soundly engineered circuit. The on board DACs can handle up to 192 Khz program material via LPCM. Audio can be sent to an external AV receiver or DAC via the HDMI or Coaxial/Optical outputs. Good quality analog outputs are also in evidence.
Απάντηση: οppo 93
ο πιονερος αποτελει παρελθον.Μεχρι να ερθει ο απογονος του , επαιξα λιγο με το 93 και :
1 σε αναλογη συνδεση ο ηχος ειναι ΗΧΟΣ , αντε για τετοιο ηχο ειχα αν ακουσω χρονια στον χωρο μου ,
σε δικαναλο οι διαφορες ειναι κραγαυλεες, στο hc δεν καταλαβαινω να λειπει κατι απο μερικες προχειρες ακροασεις.
2 σε ρυθμισεις ειναι λιγο κουλο , δεν μπορεις on the fly να τριμαρεις καθε ηχειο με παρεα ενα ντεσιμπελομετρο, θελει πρωτα να δινεις db ,χωρις ακους . Μετα να βγαινεις απο το ηχειο, να βγαινεις απο το μενου -να ξαναμπαινεις και να βλεπεις με το ντεσνιμπελομετρο που εισαι.
3 Στο δικαναλο δεν δουλευει το σαμπ , δεν ξερω αν ειναι θεμα ρυθμισης, αλλα δεν.
4 τα ηχεια δηλωνονται ανα ζευγος σε
μεγεθος-db -αποσταση.Οποτε δεν λειπει κατι, και τα σαμπ κοβει απο οπου θελουμε.
5 Σε προχειρες ακροασεις δεν καταλαβα να λειπει κατι , βεβαια αυτο θα το καταλαβω εν καιρο.
6 viva analogue
7 viva 93
8 evivi γενικως μην παμε απο αφυδατωση
Re: Απάντηση: οppo 93
καλησπέρα, μπορεί κανείς να μας πει πως συμπεριφέρεται το 93 με ταλαιπωρημένα δισκάκια DVD, όπως αυτά που έχουν τα βιντεοκλάμπ; Ρωτάω γιατί ενδιαφέρομαι, αλλά έχω άσχημη εμπειρία με ένα κατά τα άλλα εξαιρετικό Universal player της Denon, το οποίο έπαιζε μόνο καινούρια και άθικτα δισκάκια.
Απάντηση: Re: Απάντηση: οppo 93
η ντενον ειχε τη φημη οτι στα dvd ειχε θεμα στο διαβαζω, ακομα και το hi tech το ανεφερε συχνα πυκνα.
Πλεον στα μπλε δεν ξερω τι γινεται.Υποψιν τα μπλε ειναι σκρατς προυφ.Δεν εχω βαλει ταλαιπωρημενο δισκακι για να ξερω τι κανει.....Παντως σε νοικιασμενα μπλε , μια χαρα παει.Βεβαια ολα τα δισκακια δεν ειχαν ξανανοικιαστει.
απιστευτο , αλλα απο hdmi επαιζε καλυτερα απο το 91.Βεβαια δεν δοκιμασα το 91 να εβλεπα τι κανει το 91 αναλογικα , που στα χαρτια ηταν εξαιρετικο.
Απάντηση: οppo 93
χωρις να θελω να υποτιμησω το εδω ΕΞΑΙΡΕΤΙΚΟ σερβις, και επειδη χρειαστηκα ινφο χθες βραδυ,(και επειδη ειχα δεσμευσει το 93 μεχρι χθες-να εβλεπα τι να κανω) (λοιπον αποφασια να κρατησω το 93 - μου κανει την δουλεια μου) εστειλα 3 μειλακια στην οπο αμερικα, Αν και βραδυ απαντησαν ακαριαια στα 2 απο τα 3 μηνυματα......
Απάντηση: οppo 93
ειλικρινα δεν ξερω αν καποιος κορυφαιος av ή proc μπορει να συναγωνιστει το oppo σε αποκοδικοποιηση, ο πιονερακος δεν ηταν κακο μηχανακι για τα λεφτα του.Το 93 κελαιδαει ακριβα , πανακριβα θα ελεγα..............χθες σε καποιες δοκιμες -ρυθμισεις με εστειλε......
Απάντηση: οppo 93
τον αλλο μηνα δοκιμη στο hcc, νωρις το βαζουν οι αγγλοι.Και δεν το λεω ειρωνικα, γιατι το προηγουμενο μπλε το εβαλαν με πολλους μηνες καθυστερηση
Απάντηση: οppo 93
Aχχχχχχχχχχχ !!!! Το σκοτεινό αντικείμενο του πόθου :404::404: και έχω τάξει στα παιδιά ταξίδι στο εξωτερικό το καλοκαίρι :110:
Απάντηση: οppo 93
μπορει να διαβασει απο σκληρο δισκο DVD-A Discs,εχω μαζεψει καμια 50ρια
Απάντηση: οppo 93
στον ηχο ειναι καλυτερο απο το DENON DVD 3910(εχω βρει ενα μεταχειρισμενο),ποιο απο τα δυο να προτιμησω μονον για ηχο το θελω
Δεν έχω το 93... εχω το 83SE ... Το 83 λοιπον παιζει τα ταλαιπωρημενα δισκακια DVD αρκει να μην ειναι αισχρα ταλαιπωρημενα...
Φανταζομαι οτι και το 93 θα ακολουθει την παραδοση ΟΡΡΟ ... και στον τομεα αυτο...
knazito
