3D Projectors
Αν θέλετε τους συγκεντρώνουμε εδώ ως νέα προϊόντα και reviews...
Sharp XV-Z17000
http://www.avguide.com/review/sharp-xv-z17000-3d-projector-tpv-101
Slim and trim...
Consider this projector if: you’re looking for a relatively affordable 3D DLP 1080p projector
Look elsewhere if: you need installation flexibility, as the XV-Z17000 doesn’t feature lens shift,
which pretty much relegates it to ceiling mount-only installations.
You can forget about tabletop or shelf mounting at the rear of the room, as the fixed offset means
the projector must be mounted forward and lower than the screen’s bottom edge.
Ratings:
Overall picture quality (HD): 9
Features: 6
Connectivity: 7
User interface: 6
Value: 6
Απάντηση: 3D Projectors
Ωραιο post!Να ξερουμε τι κυκλοφορεί και να κανονίζουμε σιγα σιγα τα οικονομικά μας...
New 3D 1080p Home Theater Projectors from Optoma: HD33, HD8300
Movies are certainly a big part of the summer entertainment mix. 3D movies? Even better. However, sticky floors, crowds and theater texting don't have to be an integral part of the summer movie experience. Optoma is hoping to entice more movie fans to stay at home this summer, with three new projector releases, including their first full HD 1080p projectors to offer 3D capabilities.
With more 3D TVs flooding the market, it's only natural that projector manufacturers would follow suit. Optoma was an early seller of 3D-capable DLP projectors, but these were all limited to 720p (1280x720 pixels) resolution. This summer Optoma will add two more options to the 3D line-up, and this time they're offering full HD resolution (1920x1080 pixels) projectors with 3D capabilities: the new models are the HD8300 and HD33.
Optoma's HD8300 features the latest 1080p DarkChip3 DLP technology from Texas Instruments, as well as a 30,000:1 contrast ratio with DynamicBlack, 1300 lumens of brightness, True 10-Bit Full HD processing and 3-Stage Optoma Image processing. Promising over 1.07 billion colors, this projector also has the PureMotion2 processing engine, which boasts super-smooth, judder-free images for a better overall viewing experience.
Because this is a 1080p full HD 3D-ready projector, it's compatible with 1080p 3D, 720p 3D, HD (1080i/p, 720p), EDTV (480p/576p), NTSC, PAL, and SECA. The company also lists the projection distance as 4.9 to 32.8 feet, delivering images from 29.8 to 297.3 inches. Optoma says that the HD8300 should start shipping by mid-July.
Optoma's HD8300 is compatible with 1080p 3D, 720p 3D, HD (1080i/p, 720p), and more.
In August, Optoma says they will release the HD33 (or HD3300 - model number details are still a little sketchy). This model also features a 1080p DLP imaging engine and will support 3D sources, but initial specs say that 3D support will be limited to 720p resolution. The HD33 will be compatible with NTSC, PAL, SECAM, SDTV (480i), EDTV (480p), and HDTV (720p, 1080i/p) formats. The HD33 can also do 120Hz Frame Sequential 3D for resolutions up to 720p and 60Hz Field Sequential 3D for resolutions up to 480i -- with compatible 3D glasses, of course.
Other HD33 features include 1800 ANSI lumens of brightness and contrast ratio of 4000:1. This one is also rated for a slightly larger maximum image than the HD8300 -- up to 301.1 inches -- but you'll need a lot of space (and a very dark room and/or high grain screen) to come anywhere close to that.
Optoma says that they are also planning to offer new active shutter RF 3D glasses timed with these two projector introductions. Expect info on those, as well as HD8300 and HD33 pricing, to be announced soon.
Optoma's Pro8000 is specifically designed for larger venues.
For the commercial side, the PRO8000 will be available this month. This one is specifically designed for large venues, with 5800 lumens and five different lens options. The four zoom lenses have a combined range of 1.2 to 6.98 throw ratio (depending on the lens). It also offers 24/7 operation, motorized lens shift, zoom and focus. For now, the info is preliminary, so Optoma hasn't announced official pricing on the PRO8000 model, either.
Δυστυχως δεν πουλαει με τοσα λεφτα που θελει ο Sharp XV-Z17000
η Sharp εβγαζε καλα προβολια και σταματησε να βγαζει,οπως και η marantz απο το 2007.
To τελευταιο προβολι της marantz ηταν ο vp-11s2..και δεν βρηκα review αναλυτικο...
Tο τελευταιο sharp προβολι ηταν ο XV-Z20000 το 2007 που δεν μπορει να σταθει σημερα με τετοια νουμερα.
ANSI contrast: 416:1
http://www.displaycalibrationonline.com/reviews_z20000.asp
Πιστευω οτι η τεχνολγια dlp εφτασε το μαξιμουμ που μπορει στον οικιακο κινηματογραφο και γι'αυτο σταματησαν εταιριες οπως η sharp και marantz μιας και δεν μπορουν να ειναι ανταγωνιστικες..
Δυστυχως χασαμε και τους καλους φακους που διεθεταν...!!!!!
Δεν βρηκα κατι....οποτε θα μιλαει για τον 17000 επι Ελληνικου εδαφους....:116:
C . papadakis
