Anthem Statement M1 Mono Amplifier
vlasis
Φωτογράφος!
Anthem announced the Statement M1 single rack unit Class D mono power amplifier offering sophisticated monitoring circuits that maintain proper frequency response, even when powering the heaviest speaker loads using a 120V line.
Engineered with advanced load monitoring and power factor correction technology to satisfy demands up to 2400 W, even when connected to a 120V/15A line. Anthem claims the M1 will win over skeptics who think Class D amplifiers aren't suitable for hi-end sound systems. The M1's frequency response is load-independent with the difference in response between a 2-ohm load and an open circuit is just 0.1 dB. Between 4 ohms and 8 ohms there is no change in frequency response at all.
The M1 is also a true "double-down" amplifier with 1000W into 8 ohms and 2000W into 4 ohms, with total harmonic distortion remaining under 0.1% from 20 Hz to 20 kHz. Class D amplifiers provide tremendous value over traditional amps because of their efficient output from a smaller form factor, and the M1 is no different. Occupying only a single rack unit, Anthem also outfitted the new Statement amplifier with a heat pipe cooling system that allows multiple M1s, with feet removed, to be rack-mounted directly on one another. Fanless and easy-to-integrate, the M1's design makes it a serious contender whether installed in the listening room or in an equipment closet.
Specifications:
Power Output continuous, 20 Hz to 20 kHz, <0.1% THD+N
8 Ω 1000 W
4 Ω 2000 W
3 Ω 2400 W
2 Ω >2000 W depending on line voltage regulation
With 120V AC supply the amplifier's maximum output into impedances 4 Ω and lower, as well as its maximum duration, vary depending on line voltage regulation.
Frequency Response 20 Hz to 20 kHz
open circuit ±dB
8 Ω ±0.1 dB
4 Ω ±0.1 dB
2 Ω ±0.2 dB
Power Bandwidth 1000 W at 8 Ω 5 Hz to 45 kHz
THD+N at 1 kHz, 8 Ω
1 W = 0.01 %
10 W = 0.01 %
100 W < 0.03 %
1000 W < 0.06 %
IMD 19 kHz + 20 kHz, CCIF 0.003 %
Damping Factor 800 to 1400 depending on frequency
$7000 pr
Απάντηση: Anthem Statement M1 Mono Amplifier
αν ήταν στο 1/3 της τιμής, στα 2 χιλιαρκάκια, θα ήταν η σούπερ ντούπερ μηχανάρα για όλους.
τώρα, στα 7 χιλιάρικα, είναι απλά άλλο ένα ενισχυτικό. σφυρίξτε αδιάφορα...
Θα ήθελα να μάθω πώς ακριβώς και με ποιά κριτήρια μπερδεύεται η ωμική αντίσταση των ηχείων με την απόκριση του ενισχυτή.
Τωρα ρε παιδια αυτο το μηχανημα μπορει να σε φτιαξει? Αν το παρεις να ριξεις ενα χαλι απο πανω του, να μην φαινεται καθολου και αντε καπως τρωγεται.
Alex_Zapantis
Είναι απλό: οι ενισχυτές μας δεν είναι ιδανικές πηγές τάσης.
Πιο αναλυτικά (και αρκούντως απλουστευτικά):
Vload=Vout X Rload / (Rout+Rload) = Vout X 1 / [(Rout/Rload) + 1]
όπου:
Vload η ταση στο φορτίο (ηχείο)
Vout η ταση εξόδου του ενισχυτή
Rload η αντίσταση του φορτίου (ηχείο)
Rout η αντίσταση εξόδου του ενισχυτή
Από την παραπάνω σχέση
Vload= Vout X 1 / [(Rout/Rload) + 1]
φαίνεται ότι όσο πιο μικρή είναι η αντίσταση εξόδου του ενισχυτή σε σχέση με την αντίσταση του φορτίου τόσο πιο κοντά είναι είναι και η τάση που αναπτύσσεται στο φορτίο στην τάση εξόδου του ενισχυτή.
Συνεπώς, στον πραγματικό κόσμο όπου αντί για απλές ωμικές αντιστάσεις έχουμε σύνθετες αντιστάσεις τόσο στα φορτία όσο και στα στάδια εξόδου (αλλά και εισόδου) των ενισχυτικών βαθμίδων μας (ή και των πηγών μας - αναφέρομαι π.χ. στην έξοδο ενός DAC) είναι προφανές ότι τόσο η τελική απόκριση πλάτους όσο και η τελική απόκριση φάσης εξαρτώνται από την αλληλεπίδραση μεταξύ των σύνθετων αυτών αντιστάσεων, στο βαθμό που τους το "επιτρέπει" ο λόγος Ζout/Ζload (όχι Rout/Rload μια και τώρα μιλάμε για σύνθετες αντιστάσεις).
Στους διακοπτικούς ενισχυτές τώρα όπου συναντούμε συν τοις άλλοις και ένα φίλτρο στο στάδιο εξόδου, είναι πιο ""έντονη"" η εξάρτηση της αντίστασης εξόδου αλλά και της αρμονικής παραμόρφωσης από τη συχνότητα (εκτός εαν ο εν λόγω ενισχυτής είναι Hypex).
Κάπως ετσι εξηγούνται τα παρακάτω:
Specifications:
8 Ω 1000 W
4 Ω 2000 W
3 Ω 2400 W
open circuit ±dB
8 Ω ±0.1 dB
4 Ω ±0.1 dB
2 Ω ±0.2 dB
THD+N at 1 kHz, 8 Ω
1 W = 0.01 %
10 W = 0.01 %
100 W < 0.03 %
1000 W < 0.06 %
$7000 pr
Fig.1 Soulution 710, frequency response at 2.83V into: simulated loudspeaker load (gray), 8 ohms (left channel blue, right red), 4 ohms (left cyan, right magenta), 2 ohms (green). (1dB/vertical div.)
Fig.1 Wavac SH-833, 8 ohm tap, frequency response at 2.83V into (from top to bottom at 80Hz): simulated loudspeaker load, 16 ohms, 8 ohms, 4 ohms, 2 ohms (1dB/vertical div.).
Fig.2 Wavac SH-833, 4 ohm tap, frequency response at 2.83V into (from top to bottom at 80Hz): simulated loudspeaker load, 16 ohms, 8 ohms, 4 ohms, 2 ohms (1dB/vertical div.).
Το ζήτημα βέβαια είναι τόσο το τι είδους φορτίο είναι κάθε ηχείο όσο και τι απαιτήσεις έχει για να οδηγηθεί σωστά...
Alex_Zapantis
όπου:
Απλουστευτικά, μια και στην περίπτωση ενός παθητικού ηχείου, εκτός της Rout, θα έχουμε επίσης και τις Rcable, Rcrossover, οπότε, πάλι λίγο απλουστευτικά, θα έχουμε τις παρακάτω εξισώσεις
Vload=Vout X Rload / (Rout+Rcable+Rcrossover+Rload)
Vload=Vout X 1 / [(Rout+Rcable+Rcrossover/Rload) + 1]
Όπου και καταλαβαίνουμε το γιατί Damping Factors υψηλότεροι από ένα σημείο και μετά δεν έχουν (από μόνοι τους) και τόσο μεγάλη σημασία.
Ο ορισμός του Damping Factor:
Damping Factor = 8 Ohm / Rout
Δηλαδή ο DF ενός ενισχυτή ισούται με το λόγο μιας ονομαστικής αντίστασης ηχείου 8 Οhm προς την αντίσταση εξόδου του.
http://www.audioholics.com/education/amplifier-technology/damping-factor-effects-on-system-response
Alex_Zapantis
"ΔΙΑΜΑΝΤΙΑ" ΚΑΙ "ΔΙΑΜΑΝΤΕΝΙΑ" ΣΚ@Τ@
http://www.stereophile.com/content/soulution-710-power-amplifier-measurements
The following sentence appeared in a review of the Soulution 710 published in October 2005 in the German magazine Stereo: "Lab chief technician Rolf Hahle has hung the test certificate for the Soulution 710 in a golden frame over his measuring desk." I wouldn't go quite that far, but the Soulution 710 is definitely one of the best-measuring amplifiers I have encountered. Color me impressed.
http://www.stereophile.com/content/wavac-sh-833-monoblock-power-amplifier-measurements
The SH-833's output impedance was on the high side, at 5 ohms from the 8 ohm transformer tap and 2.6 ohms from the 4 ohm tap. These figures were maintained across most of the audioband, with a rise at 20kHz from the 4 ohm tap to 3.6 ohms. Unexpectedly, the 20kHz source impedance from the 8 ohm tap dropped from 5 to 4.3 ohms. This difference in top-octave behavior can be seen in the amplifier's frequency-response plots from the 8 and 4 ohm taps (figs.1 and 2, respectively). The amplifier's output from the 8 ohm tap (fig.1) tips up slightly between 20kHz and 40kHz (more so into lower impedances), whereas that from the 4 ohm tap rolls off into lower impedances, reaching -3dB at 18.5kHz into 2 ohms (fig.2).
This rolloff will be audible, but is not that important. What is subjectively important is the SH-833's behavior in the bass. As with another amplifier using a circuit developed by the late Shishido-san—the Antique Sound Lab Explorer reviewed by Art Dudley in March 2004—there is a bass boost, the amount of which depends on the output transformer tap, the source impedance, and the load impedance. In the worst case, 4 ohm tap into 16 ohms, the boost reaches 9dB between 80Hz and 160Hz, while in the best case, 8 ohm tap into 2 ohms, there is a broad plateau 2dB high between 30Hz and 200Hz. With our simulated loudspeaker load, the high source impedance and exaggerated low frequencies produce a well-defined, 10dB peak at the woofer's resonant frequency.
So, that's that for the Wavac SH-833. I can't explain why Michael found its sound so seductive; all I can do is point to the measurable problems or audible idiosyncrasies that must be listened through to hear what it does right. All I have to do now is work out how to get this mondo amplifier back out of my basement and into the SUV so that Mikey can spend another couple of weeks luxuriating in its sound.
Alex_Zapantis
Βέβαια, όλα τα παραπάνω έχουν γραφτεί πολλές φορές στο παρελθόν...
παρολο που εσωτερικα δεν μοιαζει καθολου τα specs του μοιαζουν με τον ucd2k αλλα με μεγαλυτερη
παραμορφωση.
προφανως αντιγραψαν το κολπο με το feedback μετα τα πηνια εξοδου για να μην πω στις μπορνες εξοδου.
Ρε συ Alex, δηλαδή αν δεν ήταν απλό, τι θα έγραφες;:111::123:
Re: Απάντηση: Anthem Statement M1 Mono Amplifier
όπου:
Αυτός ο Wavac στο λαιμό σου κάθεται ε;:116:
Alex,
Μηπως ξεχνας οτι οι ενισχυτες ειναι σχεδιασμενοι με ελαχιστο ωμικο φορτιο στην εξοδο τους?
Συγκεκριμενο και αναγραφεται στα χαρακτηριστικα τους της ταξης του 0.5 ohm.
Alex_Zapantis
Could you rephrase that?
Τι εννοείς;
* Ότι η ελάχιστη αντίσταση εξόδου ενός οποιουδήποτε ενισχυτή είναι 0.5 Ohm ή ότι το ελάχιστο ωμικό φορτίο που μπορεί να συνδεθεί στη έξοδο ενός οποιουδήποτε ενισχυτή είναι 0.5 Ohm;
* Ότι ακόμα και καλοί ενισχυτές δύνανται να ενεργοποιήσουν τα συστήματα θερμικής προστασίας τους υπό ορισμένες συνθήκες;
* Μιλάς για κάποιους συγκεκριμένους ενισχυτές ή γενικά;
Γνωρίζεις πολλά ηχεία των οποίων το μέτρο της εμπέδησης να πέφτει κάτω από τα 0.5 Ohm (ενώ παράλληλα η φάση της να είναι π.χ. στις -50 μοίρες) και μάλιστα σε "ενεργοβόρα" περιοχή του φάσματος ;
Τι είναι πιο δύσκολο φορτίο, ένα Ribbon με καθαρά ωμική αντίσταση "καρφωμένη" στα 2 Ohm σε όλο το εύρος λειτουργίας του, ή ένα ηχείο ονομαστικής αντίστασης 8 Ohm που "πέφτει" στα 3.5 Ohm στις -60 μοίρες στα 50 Hz;
Το ότι ένας ενισχυτής μπορεί να ενεργοποιεί τη θερμική προστασία εαν συνδεθεί σε φορτίο - "βραχυκύκλωμα" αποτελεί άραγε άλλοθι για έναν άλλο ενισχυτή που κοστίζει μια περιουσία και αδυνατεί να οδηγήσει σωστά ένα νορμάλ ηχείο;
Μπορεί το οποιοδήποτε λογικό - τεχνικό επιχείρημα που είσαι σε θέση να αρθρώσεις να δικαιολογήσει τα χάλια του παραπάνω σκ@τού;
Ρωτάω ειλικρινά.
Εσύ θα τον άλλαζες τον ενισχυτή σου με τον παραπάνω Wavac?
Υπ' όψιν:
Θα έπρεπε να τον κρατήσεις και να τον χρησιμοποιείς υποχρεωτικά και αποκλειστικά στο σύστημά σου, και όχι να τον πουλήσεις σε dt για όσα περισσότερα μπορούσες.:116:
Άμα ήταν έτσι κι εγώ θα τον αγόραζα στο 1/1000 της σημερινής τιμής του - εν μέσω ΔΝΤ δεν είμαστε και για πολλά ρίσκα...:114:
Alex_Zapantis
Εννοείται ότι πέρα από τα τρία πρώτα ερωτήματα, οι υπόλοιπες ερωτήσεις είναι λίγο - πολύ ρητορικές...
Alex_Zapantis
Είναι απλό βρε.
Αν η αντίσταση εξόδου του τελικού είναι συγκρίσιμη με την αντίσταση του φορτίου, τότε η απόκριση πλάτους του τελικού θα ακολουθεί τα "ανεβοκατεβάσματα" της αντίστασης του φορτίου εντός του φάσματος του τελευταίου (μια και στη γενική περίπτωση έχουμε να κάνουμε με σύνθετες αντιστάσεις που δεν είναι σταθερές ούτε ως προς το μέτρο ούτε ως προς τη φάση).
Καλωσήρθατε στη "μαγεία" των γραμμικών παραμορφώσεων (τη "μαγεία" των μη γραμμικών παραμορφώσεων την αφήνω απέξω).
Αν θέλετε μόνο μη γραμμική "μαγεία", τότε ευχηθείτε το φορτίο σας (π.χ. το tweeter) να έχει εμπέδηση σαν την παρακάτω:
Fig. 1: X-ART tweeter impedance: linear within ± 15 mΩ (green) in comparison to a 1” dome tweeter (red)
Alex_Zapantis
Είναι απλό βρε.
Ας μην ασχοληθούμε με ενδεχόμενες "ζεϊμπεκιές" της απόκρισης φάσης για την ώρα...
Re: Απάντηση: Re: Απάντηση: Anthem Statement M1 Mono Amplifier
Ε, αγόρασέ τον ντε να "ξαλαφρώσω".:114:
Τα 350 τα έχω, τα μηδενικά μου λείπουν. Αν και για να είμαι ειλικρινής, πολλά θα αγόραζα με αυτά τα λεφτά και θα άκουγα εφ όρου ζωής με ακουστικά, προτιμότερο το βρίσκω από το να δώσω τόσα λεφτά για ενισχυτή. Ειδικά έναν ενισχυτή με τη δική του απόκριση.
JAndronikos
