Νέα άφιξη: VPL-HW30ES - ο νέος...
loggeo
Να τους δούμε πρώτα παιδιά. Το θέμα βέβαια είναι θα τους δούμε ή απλά θα διαβάζουμε γι'αυτούς;
MAD
Σιαρτάκιας
Απάντηση: Νέα άφιξη: VPL-HW30ES - ο νέος...
Μπά! πάνε οι καλές εποχές που μαζευόμαστε!
δεν ξερω αν θα τους δουμε ως avsite, αλλα τα προβολια αυτα θα ερθουν σιγουρα,δεδομενου οτι ειναι εμπορικη κατηγορια.
Nelsy
Ιεράπετρα
Ποιες εποχές εννοείς;;;
αυτές που μαζευόσασταν μια φορά τα δέκα χρόνια για να δείτε κανένα καινούργιο CRT;;;:105:
...ε βέβαια περάσανε......ανεπιστρεπτί:103:
ichaltou
Αλλαχτήρι
review απο avforums
http://www.avforums.com/reviews/index.php?reviewid=219
The HW30ES offers up excellent black levels and dynamic range at its price point. Images are solid with good levels of shadow detailing on show in the best possible viewing surroundings. It offers a good level of brightness on our 110” 2.37:1 screen in our testing environment with complete light control, but this will differ for larger screens in less than ideal surroundings. Even with some levels of ambient light (or light coloured walls and ceilings) the HW30 does its best to offer an image which stands up quite well to ambient light washing out the image slightly. ......
The slight downside to all this is the lack of a working colour management system which means we were unable to fine tune and calibrate the projector to hit the industry standards. ....
The RCP control does not work without adding in image artefacts due to clipping in the higher end of the luminance which means the system is unusable. So we have to fall to the out of the box ‘Normal’ colour gamut which is a little under saturated overall with a strong blue. But falling onto this preset is not all bad news and the actual onscreen performance with film and TV material offers a good image that only the real videophile out there will be a little disappointed with....
The overall image quality in 2D is good and this also translates to the 3D side of things that are a vast improvement over the VW90ES we reviewed earlier this year. Gone are the cross talk and parallax issues that plagued that model and what we get here is an image with plenty of depth and very little visible crosstalk. It is not crosstalk free with some tough content pushing the capabilities and showing areas of ghosting, but for the vast majority of viewing material the 3D images hold up very well with nothing that would take you out of the experience
Μανώλης Κ.
Calibrator! Επαγγελματίας
Απάντηση: Re: Νέα άφιξη: VPL-HW30ES - ο νέος...
Τον είχα στα χέρια μου και έπαιξα μαζί του.
Είναι ένα πολύ καλό μηχάνημα και με φωτεινότητα και στα 2 mode.
Περισσότερα μετά την κυκλοφορία του ΗΧΟΥ αυτού του μήνα.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Μονο μια ερωτηση Μανωλη:
Ειναι καλυτερος η χειροτερος απο τον 90αρη?
Nelsy
Ιεράπετρα
Καλυτερος με λιγότερα χρήματα.
Ενας μικρός 90άρης είναι.
...με λίγα λόγια,πλέον με ~3.000 ευρώ αγοράζεις ένα πολύ καλό μηχάνημα με καταπληκτική εικόνα και για τους πιο απαιτητικούς...επιτέλους:444:
Υ.Γ Μανόλη,στις 136' παίζει η' να περιμένω τον 'μεγάλο' της Μπενεκιού;;;:105:
Μέχρι να βγάλει μεγάλο η Μπενεκιού, δεν βολεύεσαι με τον 30? :136::116:
θελει να βγαλει κανα 1000αρικο λιγοτερο απο την στεπη...:116:
Μπερδεύτηκα λίγο με το τεστ του Sony στον "Ήχο" από τον Μανώλη Καστρουνή.
Γράφει ο Μανώλης: "Σε θέαση υλικού 3D, o Sony, δείχνει τα δόντια του. Κοιτάζει στα ίσια τον ανταγωνισμό, ενώ οι μηχανικοί έκαναν πολύ καλή δουλειά. Φυσικά, αναφέρομαι στην επάρκεια φωτεινότητας, που ήταν και η "αχίλλειος πτέρνα" του 90άρη"
Σε διπλανή στήλη όμως, στις μετρήσεις, ο Μανώλης αναφέρει: "Με τη χρήση των γυαλιών για τη θέαση 3D η φωτεινότητα έπεσε μέχρι και 85%, ενώ η θερμοκρασία χρώματος αλλάζει έως και 6500*Κ περισσότερο (δηλαδή 13000*Κ), ανάλογα με την επιλογή."
Πες μας βρε Μανώλη, είναι τόσο φωτεινός σε 2D, ώστε η πτώση της φωτεινότητας κατά 85% σε 3D να δίνει περισσότερη φωτεινότητα από τον 90άρη? Ή μήπως δεν κατάλαβα κάτι καλά?
Μανώλης Κ.
Γιάννη,
ο 90άρης έιχε μια πτώση φωτεινότητας σε 3D κοντα στο 95% ενω αυτός μόνο:107: 85%. Από αυτό και μόνο καταλαβαίνεις ότι ειναι ποιο φωτεινός.
Για τον 30άρη γραφω "Η φωτεινότητα του προβολέα για κάδρο 84 ιντσών από απόσταση 3 μ. μετρήθηκε στα 670 ANSI lumens, με τη λάμπα στο High. "
Για τον 90άρη έχω γραψει ". Η φωτεινότητα του προβολέα για κάδρο 84 ιντσών από απόσταση 4,24 μέτρα μετρήθηκε στα 354 Ansi Lumens με την λάμπα στο High."
Αν και τα μετρα ειναι διαφορετικά υπάρχει διαφορά στην φωτεινότητα.
Σε αντίστοιχη μετρηση που εκανα στον 90άρη (ιδια αποσταση και θεση φακού ) μου είχε δώσει 485 Ansi Lumens.
Γιάννη νομίζω να σε κάλυψα.
Για όποια άλλη απορία σχετικά με τον προβολέα εδω είμαστε...
Σε σχεση με τον JVC X3 ειναι πιο φωτεινος;
Σε 2D ποιος ειναι καλυτερος SONY 90, SONY 30 ή JVC X3
βεβαια σε λιγο καιρο θα ερθουν και οι νεοι JVC X30..
Μανώλης Κ.
Σε 2D είναι ποιο φωτεινός με την λάμπα στο low και οι δυο.
Με την λάμπα στο high ειναι πολύ κοντα με μικρό προβαδισμα στον 30άρη.
Σε 3D είναι ισάξιοι, με τον x3 να εχει λιγότερο crosstalk.
Το καλύτερος πως το εννοείς? Απόλυτα ή σε σχέση με την τιμή του?
δλδ 120" για 500 ωρες ειναι μια χαρα......αν παζεις βεβαια το ζουμ μεση και προς ανοιχτο..
ωραιος.....
  • rose.athens
roberto_portale
