vlasis
Φωτογράφος!
Main specifications
Input terminal Balanced × 3, × 3 unbalanced
Output terminal Line Out: Balanced × 2, × 2 unbalanced
Record Outputs: Balanced × 1, × 1 unbalanced
Rated output voltage Balance 1.5 V, 0.75 V unbalanced
The maximum output voltage 20 Vrms (balanced), 10 Vrms (unbalanced)
Rated distortion THD 0.0015%
SN ratio 120 dB
Frequency characteristic 10 Hz ~ 100 kHz, -1.0 dB
Gain 12 dB
Maximum input voltage (-40 dB) 20 V (balanced), 10 V (unbalanced)
Supply voltage AC100 V, 50 Hz / 60 Hz
Power consumption 52 W (0.5 W Standby power consumption below).
External dimensions
Body part: 450 mm (W) × 150 mm (H) × 440 mm (D)
Power Supply: 220 mm (W) × 185 mm (H) × 430 mm (D)
Mass Body parts: 29 kg
Power supply: 15 kg
