H Musical Fidelity ξαναχτυπά
Από τα racks των περισσότερων φίλων του βινυλίου έχουν περάσει τα phono stage της Musical Fidelity. Οικονομικά, με καλό ήχο και ίσως η πρώτη επαφή με εξωτερικά phono stage πριν πάμε σε ποιο ακριβά λιβάδια......
"The stage of art" M1 ViNL όμως (όπως ονομάζει το νέο της Phono stage) μάλλον ξεφεύγει από τα δεδομένα και είναι η χαρά της παραμετροποίησης. Λέτε να ήρθε για να μείνει αυτή την φορά?
Κοντά στις 700 λίρες Αγγλίας
THE M1 ViNL
The M1 ViNL is a state of the art MM/MC phono stage with adjustable input capacitance, input resistance and RIAA/IEC equalisation curves with single ended and balanced outputs.
The M1 ViNL has extraordinary input flexibility. On MM it has 47k or 68k input impedance. Input capacitance has seven values; 50PF, 100PF, 150PF, 200PF, 250PF, 300PF, 350PF, 400PF. This extraordinary flexibility means perfect matching for almost any MM cartridge.
The MC stage has ultra flexible input resistance switching, 10R, 18R, 25R, 50R, 100R, 200R, 400R, 800R, 1600R and 47K.
The ViNL has switchable RIAA and IEC EQs.
The ViNL has another important feature; you can switch resistance, capacitance or equalisation curve whilst it is playing. This gives ViNL extraordinary flexibility and functionality.
And that's just the beginning! The ViNL's technical performance is no compromise, state of the art. The circuitry is based around our revered KW phono stage but, with modern technology, a setup from that incredible standard. We employ ultra low noise instrumentation amplifiers (the highest quality available). The RIAA EQ curve extends up to 50 KhZ within 0.2 dB. Distortion is almost non-existent and the noise is on the threshold of what can be achieved. The crosstalk is outstanding. In every technical parameter, the ViNL is state of the art.
The ViNL's incredible input flexibility and state of the art technical performance, result in an extraordinary product. As far as we can see the only problem is that it may not be expensive enough to be believable!
http://www.musicalfidelity.com/products/M1-Series/M1ViNL/M1ViNL.asp
Απάντηση: H Musical Fidelity ξαχαχτυπά
Νομίζω, ξέρω τι θα μου φέρει ο Άγιος Βασίλης του χρόνου!:404:
Απάντηση: H Musical Fidelity ξαναχτυπά
Χαίρομαι να βλέπω ρυθμιστικά πάνω σε MM (κυρίως) και φαίνεται καλό... αρνητικό είναι ότι έχει μόνο 2 εισόδους, 1MM & 1MC!
Φαντάζομαι ότι είναι αρνητικό για όσους έχουν π.χ. δύο ή τρεις βραχίονες (άρα και διαφορετικές κεφαλές) στο πλατώ τους ή για όσους έχουν 2 διαφορετικά στημένα σετ πλατώ-βραχιόνων-κεφαλών. Υπάρχει κάποιος άλλος λόγος;
Σωστός, αυτός και μόνο είναι ο λόγος!
Manos58
εγχειρισμένη
Λέτε κάποιος με 2-3 βραχιονες-κεφαλές να περίμενε το Μ1 η ακόμα χειρότερα με 2 πλατω +βραχ-κεφαλές .
Είναι εξαιρετικό ως προς τις ευκολίες για την κατηγορία τιμής του.μακάρι να παίζει και ανάλογα -best buy θα γίνει.
Manos58
εγχειρισμένη
και έπειτα θα το πιάσει ο Πετερμένης να του αλλάξει τροφοδοτικό:403::422:
Manos58
εγχειρισμένη
Το έχουν......το έχουν:126:
Δηλαδή τι έχουν αυτοί με τους 2-3 βραχίονες και δεν περιμένουν το M1?
Manos58
εγχειρισμένη
Πολλά λεφτά ρε Βασίλη.......
Με κάτι θα έπαιζαν μέχρι τώρα.....εκτός και χρησιμοποιούν ψηφιακή RIAA:414:
εσύ κάτι ξέρεις και δε το λες....
Μπορεί να δεχτεί πλατό με 2 βραχίωνες ή 2 πλατό αρκεί η μία κεφαλή να έχει τάση εξόδου κοντά στα 5mV (ΜΜ ή υψηλοέξοδη MC) και η άλλη να είναι κοντά στα 0.5mV (ΜC)
Προσωπικά δεν γνωρίζω (ιδικά σε αυτή την τιμή) πολλά phono stages που έχουν τέτοιες δυνατότητες (για ΜΜ). Αμα βάλουμε και τις ισορροπημένες εξόδους ακόμα λιγότερα.
Πολλοί κάτοχοι Shure θα χαρούν που επιτέλους υπάρχει ένα stage για αυτές (σωστά Βασίλη?)
ΙΜΗΟ είναι ιδανική αγορά για αυτούς που έχουν αρκετές ΜΜ κεφαλές στην συλλογή τους
Όντως Φίλε Γιώργο, γιαυτό και θα ήθελα να το ακούσω...:201:
Αλλά εγώ σαν απλός Βασίλης περιμένω αναλυτικές εντυπώσεις..., επίσης καλορίζικο.
Βασίλη, σε ευχαριστώ για τα καλά σου λόγια. Θα περιμένω να "χωνέψω" το νέο απόκτημα και την αλλαγή στον ήχο και μετά θα γράψω τις εντυπώσεις μου. Θα πάρει καιρό βέβαια, δεν είμαι υπέρ των πρώτων εντυπώσεων.
Δεν θυμάμαι τι κεφαλές έχεις στην συλλογή σου, αλλά θα είχε μεγάλο ενδιαφέρον να βάλεις πάνω του μια καλή ΜΜ (θα τα πούμε στο μέλλον...), λόγω των ρυθμιστικών που έχει. Καλές ακροάσεις και πάλι.
Καλές ακροάσεις κι από μένα!
Εξαιρετική επιλογή στις μέρες μας.
Να και μια εταιρία που έκανε ένα βήμα ...προς το μέλλον!:610:
Αναμένουμε αναλυτικές εντυπώσεις σου.:616:
mgm
