Sharp XV-Z30000
Sharp Adds a Whole New Dimension to Home Theater
It’s the latest in “reality” television! Sharp’s new 3D high definition DLP® home theater projector (XV-Z30000) offers out-of-this-world 3D visuals that make home theater more true to life. Jim Sanduski, vice president, strategic product marketing, Sharp Electronics Marketing Company of America (SEMCA) says, “No matter what the content, the XV-Z30000 offers consumers a clear entertainment projection solution. With a focus on providing consumers with superior entertainment experiences, this front projector is ideal for the dedicated home theater or viewing room and is a welcome addition to any home entertainment experience.” Simply put, the XV-Z300000 offers:
  • 3D 1080p high definition front projector
  • Motorized lens shift function and x2.0 optical zoom lens
  • 6-segment, 5x speed color wheel
  • 50,000:1 contrast ratio (in high contrast mode)
  • Two sets of 3D glasses, 3D emitter and cable
DLP Advantage.
Part of the XV-Z30000’s superior picture quality is due to the DLP advantage. All Sharp front projectors incorporate mirror-based components that use light more efficiently by bringing more light from lamp to screen. In addition, with Sharp’s proprietary digital image ICs, the XV-Z30000 reproduces high quality 3D picture with almost no cross talk and flicker.
Lens Functions.
The projector’s lens functions also make it a good choice for those looking for a high-quality home theater experience. It features flexible installation with center lens and lens shift; the center lens design allows for easy adjustment; and the wide range horizontal and vertical lens shift function allows for flexible installation.
And, with the motorized lens shift function, customers can select their preferable setting position. The projector also has control function with Crestron, Control 4, AMX, and RS 232C port and LAN control via network.
Ease of use.
With the wide range x2.0 optical zoom, users can select the preferable ceiling mount position. Or, for spontaneous projection, the projector is portable and can be positioned on a table. The resize function (V-stretch) allows users to choose a 2.35:1 wide aspect image (Cinema scope) and features dual memory for lens/zoom/image settings.
It also includes a One Touch Play function, which automatically turns on the projector when the user pushes the playback button of the playback equipment. Also, the System Standby function places the playback equipment into standby mode when the projector is turned off.
The XV-Z30000 offers extensive connectivity with two HDMI® inputs. To further enhance the viewing experience, two sets of 3-D glasses are included.
ichaltou
Αλλαχτήρι
o 17000 εμένα μου άρεσε πάντως...η τιμή του βέβαια είναι εκτός αγοράς...
Απάντηση: Sharp XV-Z30000
δεν εχω βρει κατι περι ρυθμισης.
οχι δεν ειναι κακος....μια χαρα μηχανακι ειναι με την δυναμικη ιριδα
με ενα lumagen mini 3d η dvdo iscan duo ερχετε ωραια....
απλα πας στα 5500 ευρω περιπου.....
Στην τιμή του ρε παιδιά, τι καλός? Θέλετε, αν υπάρχει, να βάλουμε απόψε τον 17000 δίπλα στον 30 να γελάσουμε?
ΟΚ πάω, αλλά αν χαλάσω τη μηχανή δεν θα με βάλετε να πληρώσω...
LefterisG
