Rega DAC
tyler durden
Μη ριβγιούερ
Καινουριο DAC το οποιο γεφυρωνει το χασμα μεταξυ της εισαγωγικης κατηγοριας (MF M1, Arcam rDac, CA) και των dac >1000 euro (m2tech, benchmark κλπ)
απο τη σελιδα του κατασκευαστη
Τhe Rega DAC is a 16/20/24-bit at 32kHz to 192kHz digital to analogue converter incorporating an enhanced version of the Rega designed circuit. Developed to be simple to set up and use, the Rega DAC is designed to optimise performance from any two channel PCM digital audio source such as a CD player PC or streaming device.
With the PC/Laptop and MAC now widely accepted as creditable mediums for storing and streaming music. The use of high quality lossless files such as WAV, FLAC and ALAC offer performance through the DAC equal to and in some cases better than red book CD.
Housed in a custom aluminium and steel case and boasting a pair of Wolfson DAC IC's, 5 user selectable digital filters, two isolated Co-axial inputs, two Toslink SPDIF inputs and an isolated USB input. The Rega DAC is designed and engineered to perform way above its class.
Technology
The input stage comprises a Wolfson digital receiver with a high stability low jitter clock. The receiver and PLL have their own dedicated power supplies. The DAC stage comprises of a pair of parallel-connected Wolfson WM8742 DAC's, which are driven via a buffer stage, which ensures the integrity of the data being fed to the DAC IC's similar to the arrangement used in the Isis (Rega's refrerence CD player). Great care has been taken to remove noise generated by the PC and other input sources. During development this was identified as a major drawback with many DAC's on the market today.
The output amplifier employs a discrete differential multiple feedback filter and output amplifier, with a high cut-off frequency for use with higher sample rates. We decided not to use a sample rate converter and process the data at the incoming sample rate which keeps the signal processing to a minimum. Jitter was minimised by synchronously clocking the digital data with our receiver PLL (removing any jitter from the input signal).
All the capacitors associated with the analogue signal path are Nichicon FG bypassed with MMK polyester capacitors, and low impedance conductive polymer capacitors are used for DAC decoupling. The power supply utilizes a toroidal transformer, fast rectifier diodes and again Nichicon FG capacitors. There is a power supply for the control microcontroller, separate from the digital & analogue audio stages. Special attention being paid to the inter IC control signals ensuring the control data noise is kept to a minimum.
Το πρωτο review απο το WHF ειναι πολυ ενθαρρυντικο http://www.whathifi.com/review/rega-dac
...και εδω μεταξυ αλλων ενα σχολιο καποιου που το συγκρινε αμεσα με το DacMagic.
http://www.whathifi.com/review/rega-dac/user-reviews
αλλο ενα review
http://www.techradar.com/reviews/aud...-945203/review
κι αλλο ενα
http://canadahifi.com/index.php/rega...lusive-review/
αν τα γραφωμενα ανταποκρινονται στην πραγματικοτητα και το μηχανημα στη χωρα μας ερθει στην αναμενομενη τιμη με βαση την τιμη του στην Αγγλια, μαλλον θα κανει θραυση.
Απάντηση: Rega DAC
Κάποια στιγμή θα πάω από την αντιπροσωπεία να τον δοκιμάσω, ελπίζω να ακούγεται καλά.
Η αλήθεια είναι ότι έχει κάποια μειονεκτήματα σε σχέση με άλλα dacs που κοστίζουν τα μισά λεφτά.
Το usb για παράδειγμα είναι ψόφιο. Επίσης το κουτί του είναι μαύρο χάλι, ευτυχώς η ασημί version φαίνεται καλύτερη. Βέβαια το θέμα είναι να ακούγεται ωραία, απλά είναι κρίμα να βλέπεις προχειροδουλειές σε αυτή τη τιμή.
tyler durden
Μη ριβγιούερ
Απάντηση: Rega DAC
...το θεμα ειναι να παιζει μουσικη ωραια. Υπαρχει dac 12ετιας χωρις ουτε καν upsampling, το οποιο το βαζεις και παιζει διπλα σε ολα αυτα τα γνωστα κ εμπορικα, και τα στελνει για μπανιο. Τωρα αν ειναι προχειροδουλεια, θα θελα να το παρω στα χερια για να το διαπιστωσω.
Απάντηση: Rega DAC
Τώρα που το πες διάβασα ότι δεν κάνει upsampling. Αυτό για μένα καλό είναι γιατί υπάρχουν πολλά dacs που το κάνουν θες δεν θες και δεν είμαι ιδιαίτερα φαν του upsampling. Από την άλλη θα μπορούσαν να το είχαν βάλει σαν επιλογή, να διαλέγεις δηλαδή αν θες ή όχι. Τέλος πάντων όπως είπες το θέμα είναι πως ακούγεται. Αν αξίζει τα διπλάσια χρήματα σε σχέση με τα μοντέλα των 300 ευρώ θα τον αγοράσω.
Απάντηση: Rega DAC
Το κουτι που το ειδατε και λετε για μαυρο χαλι; μηπως λογω σχηματος;
Απάντηση: Rega DAC
σε τεστ του hi-fi choice "εσκισε", εχει ερθει στη χωρα μας?
vlasis
Φωτογράφος!
Απάντηση: Rega DAC
Με γεια σας κυριε μου.....καλα ακουσματα!!!!!!:143::143:
Ωραια πραματα λεμεεε....αληθεια....παιζει και βινυλλια που ειναι της μοδος????:204:
vlasis
Φωτογράφος!
Απάντηση: Rega DAC
Μα ποσο ηλιθιοι ειναι καποιοι τυποι τελικα...........................
for kanapedatos ....only!!!!
Y
Yiannis_B
Απάντηση: Rega DAC
Βλάση μη τσιμπάς…..
Πράγματι το χούμορ σ’ αυτό το post δεν ήταν πετυχημένο…
Σβήσε το ή άστο, δεν θα χαλαστώ.
vlasis
Φωτογράφος!
Απάντηση: Rega DAC
Βλάση μη τσιμπάς…..
Ωπαααααααα....τι καταλαβες βρε Γιαννη??????
αυτο που εγραψα ηταν για τον καναπεδατο που μας επρηξε σημερα με το blog του !!!!!!!!!!!
Μ εστειλλες βρε!!!!!!
Y
Yiannis_B
Απάντηση: Rega DAC
…τώρα που το ξαναβλέπω….το καταλαβα που πηγαινε.......ολα καλα ......
vlasis
Φωτογράφος!
Απάντηση: Rega DAC
ενταξει τωρα??????
το καταλαβαμε κυριε Γιαννη μας που πηγαινε το κομπλιμεντο?:135::135:
Y
Yiannis_B
Απάντηση: Rega DAC
Είσαι τρελοκομείο....:105:
Τέσπα, εξακολουθώ να πιστεύω ότι το χούμορ μου δεν ήταν της προκοπής...
Συγνώμη στον tyler durden που άνοιξε το θέμα και σ’αυτούς που ακολούθησαν…
ΒΑΣΙΛΗΣ ΜΗΤΣΙΟΥ
