audyssey multi subs position
Τι προτεινει το μανιουαλ του audyssey για τεις θεσεις των subwoofer-s
Multiple Subwoofers
The Sound Equalizer
supports multiple
subwoofers. In fact, all
eight channels can be
used for subwoofer
correction if so desired.
Use of multiple subwoofers
operating from
various positions in the
room can smooth the bass
response.
There are two ways to
connect multiple
subwoofers.
If the pre/pro has an
advanced bass
management system that
directs bass from different
channels to a separate
subwoofer, then each
subwoofer output should
be connected to a separate
Sound Equalizer channel.
In such systems, the delay
and trims calculated by
MultEQ Pro can be entered
in each individual
subwoofer setting in the
pre/pro.
The most common
configuration for
preamplifier/processors
that provide multiple
(usually two) subwoofer
output connectors is to
have them internally
connected in parallel (ycord).
In such cases, it is
not possible to enter
separate delays and trims
for each subwoofer. In
this case, connect ONE of
the subwoofer outputs
from the pre/pro to ONE
input channel of the Sound
Equalizer and then attach a
Y-cord to the
corresponding output
channel to feed the signal
to each subwoofer. In this
situation, it is best to place
the subwoofers in
symmetrical locations at
equal distance from the
main listening position
If the subwoofers can not
be placed in symmetric
locations, Audyssey
recommends using a delay
that is the average of the
distances from the
subwoofers to the
principal listening location
The Sound Equalizer supports multiple subwoofers. In fact, all eight channels can be used for subwoofer correction if so desired.
Use of multiple subwoofers operating from various positions in the room can smooth the bass response.
There are two ways to connect multiple subwoofers. If the pre/pro has an advanced bass management system that directs bass from different channels to a separate subwoofer, then each subwoofer output should be connected to a separate Sound Equalizer channel. In such systems, the delay and trims calculated by MultEQ Pro can be entered in each individual subwoofer setting in the pre/pro.
The most common configuration for preamplifier/processors that provide multiple (usually two) subwoofer output connectors is to have them internally connected in parallel (ycord). In such cases, it is not possible to enter separate delays and trims for each subwoofer. In this case, connect ONE of the subwoofer outputs from the pre/pro to ONE input channel of the Sound Equalizer and then attach a Y-cord to the corresponding output channel to feed the signal to each subwoofer. In this situation, it is best to place the subwoofers in symmetrical locations at equal distance from the main listening position.
If the subwoofers can not be placed in symmetric locations, Audyssey recommends using a delay that is the average of the distances from the subwoofers to the principal listening location.
Έλεος βρε Αργύρη.
Αυτό το έβαλες γιά να καταλάβουμε πως πρέπει να μπουν συμμετρικά, ή άλλο quote ήθελες να βάλεις?
Δεν γράφει πού συνιστούν να μπει το sub.
Απάντηση: Re: audyssey multi subs position
Έλεος βρε Αργύρη.
no mercy :626::622:
Αυτό το έβαλες γιά να καταλάβουμε πως πρέπει να μπουν συμμετρικά NAI, ή άλλο quote ήθελες να βάλεις?
Δεν γράφει πού συνιστούν να μπει το TA sub.-ιση αποσταση ολα
αυτα που εμεις εχουμε δεδομενα ειναι ανγωστα για μελη , και καλυτερα να απανταω στον αγερα , οποτε να μην το ξαναβρω μπροστα μας,
δεν ειναι ολοι του επιπεδου μας :143:, αλλοι ακομα παλευουν ψαχνουν που ειναι η υποδοχη του σκαρτ στο μπλου ρει τους,
αλλοι παλευουν να κανουν τον ηλιακο μπασοκουτι........
και αλλοι κανουν παραπονα στη νοβα γιατι δεν εχει κομπονεντ ο αποκωδικοποιητης τους..................
Θα τα τύφλωνες όμως τα μέλη με τη γραμματοσειρά! :142::142:
Μου κόλλησε το No Mercy... :105:
Απάντηση: audyssey multi subs position
κοματαρα .....παιζει ριπιτ που παει νεφος
Katerinanota
