ACER K750 DLP Led laser 1080p
Nelsy
Ιεράπετρα
Απάντηση: ACER K750 DLP Led laser 1080p
Πολύ μου αρέσει:137:
gkontoletas
trouble in my brain
Product Features
This product is a single-chip DLP projector. Outstanding features include:
• DLP technology
• Native 1920 x 1080 1080p resolution 4:3/16:9/L.Box aspect ratio supported
• Versatile display modes (Bright, Presentation, Standard, Movie, Dark
Cinema, Game, Sports, User) enable optimum performance in any situation
• NTSC/PAL/SECAM compatible and HDTV (480i/p, 576i/p, 720p, 1080i/p)
supported
• Compact size projector facilitates business purposes and home
entertainment.
• Acer EcoProjeciton Technology delivers Intelligent power management
approach and physical efficiency improvement
• Empowering Key reveals Acer Empowering Technology utilities (Acer
eView, eTimer, ePower Management) for easy adjustment of settings
• Equipped with HDMITM connection supporting HDCP
• Advanced digital keystone correction delivers optimum presentations
• Multi-language on screen display (OSD) menus
• Environmental light source and longer life by Laser/LED solution.
• Microsoft Windows 2000, XP, Vista Windows 7, Macintosh OS
compliant
The specifications listed below are subject to change without notice. For final
specs, please refer to Acer's published marketing specifications.
Projection system DLP
Resolution Native: 1080P (1920 x 1080), Maximum: UXGA (1600 x1200), WSXGA+ (1680x1050)
Computer compatibility IBM PC and compatibles, Apple Macintosh, iMac and
VESA standards: SXGA, XGA, SVGA, VGA, UXGA
Video compatibility NTSC (3.58/4.43), PAL (B/D/G/H/I/M/N), SECAM (B/D/G/
K/K1/L), HDTV (720p, 1080i, 1080p), EDTV (480p, 576p), SDTV (480i, 576i)
Aspect ratio Auto, 4:3, 16:9, L.Box
Displayable colors 1.07 billion colors
Projection lens F = 2.55 ~ 2.86, f = 22.37 mm ~ 26.73 mm, 1:1.2 Manual
Zoom and Manual Focus
Projection screen size (diagonal) 38" (96 cm) ~ 300" (762 cm)
Projection distance 4.9' (1.5 m) ~ 32.7' (10.0 m)
Throw ratio 60"@2 m (1.50 ~ 1.80:1)
Horizontal scan rate 30 k - 100 kHz
Vertical refresh scan rate 50 - 85 Hz
Keystone correction +/- 15 degrees
Weight 3.95 Kg (8.71 lbs)
Dimensions (W x D x H) 321 mm x 231 mm x 87 mm (12.64" x 9.09" x 3.43")
Power supply AC 100 – 240 V, 50-60 Hz
Power consumption Normal mode: 174 W +/- 10% @ 110 Vac (Bright mode
@ full power)
ECO mode: 117 @ 110 Vac (Video mode @ eco power)
Standby < 0.5 W
Operating temperature 5ºC to 40ºC / 41ºF to 104ºF
I/O connectors
• Power socket x1
• RS232 x1
• Composite input x1
• S-Video x1
• VGA input x1
• HDMI x2
• Audio input x1
• Audio output x 1
τον βαζουμε στην υπογα σου με lumagen .....τον διορθωνει ο Καστρουνιξ ......και βλεπουμε τι ψαρια πιανει..
runco vs acer :103:
βεβαια αυτος ειναι πολυ φωτεινος(αν ισχυουν τα νουμερα)και η οθονη με πολυ κερδος.....
αλλα θα καταλαβουμε...:403:
Loggeo, έχεις άκρες στην Ιαπωνία? :138:
ερχεται και ενας Mitsubushi 4k sxrd
7000-8000 ευρω :103:
Αυτόν τον αφήνω για σένα.
Τα 2 φιλαράκια μου με τους LED, μήπως σιγά σιγά να βάζουν καμμιά αγγελία;:145:
Με 10 χιλιαρικάκια δικός σου Γιωργάκη. :126::127:
gkontoletas
trouble in my brain
Αυτό είναι γνωστό από τον περασμένο μήνα, έχει να κάνει με τις interactive δυνατότητες του προβολέα και έχει κύριο στόχο τις αίθουσες διδασκαλίας.
DALLAS, TX / LAS VEGAS – June 13, 2012: Texas Instruments (TI) (NASDAQ: TXN) DLP, the worldwide leader in projection technology, today unveiled a new family of image processing chips designed for front projectors, which enable broader standardization of 3D and interactive technologies. Projectors with the new chipset design, which will be incorporated in shipping units starting late summer 2012, will seamlessly display content from common 3D-formats supported by HDMI 1.4, from virtually any mobile device including tablets, smart phones, laptops and Blu-ray players.
A leading benefit of the chipset is that it allows projectors to work with any standard input-format as well as any light source, at any of our full spectrum of resolutions, including XGA, SVGA, WXGA, 1080p and WUXGA. Additionally, functionality has been integrated enabling more cost effective interactive ready projectors.
“Creating a chipset that makes 3D and interactive technologies more accessible for projector developers is a major step forward for the industry,” said Roger Carver, General Manager, DLP Front Projection. “This helps our customers build off-the-shelf projectors while adding new capabilities at a comparable price point that allows for global deployment while still serving unique regional needs.”
The new chipset also helps facilitate the shift to lamp-free light sources by incorporating features designed specifically for solid state deployment, enabling a wider range of manufacturing options.
“The display industry has evolved beyond the days of the higher resolution chase and the brightness battles,” added Carver. “As projectors increasingly become the central hub of the classroom, this new chipset will help optimize hardware and software for the new frontiers of interoperability, 3D and interactive display.”
As the adoption of lamp-free, 3D and interactive technologies continues to increase in the classroom, ease of connectivity and deployment is another major benefit of the new chipset, allowing end users to run downloadable content from a laptop, tablet or other mobile device, while still supporting standard formats like Blu-ray and DVD, enhancing the ability of teachers to transition between content sources.
http://www.dlp.com/technology/dlp-press-releases/press-release.aspx?id=1541
Nelsy
Ιεράπετρα
on/off native 7014:1
1700 ευρω :105: και dc3...!!!!!!
Dark Chip 3 με native 7014/1,από δύσκολο ως αδύνατο...απορώ πως δεν το σχολίασες:105:
knazito
