Πωλείται ο Denon Avr 2809 150wx7 -8ohm ΤΙΜΗ 700Ε
Ο ενισχυτής δεν εχει ανοιχτει απο το κουτι του ΕΙΝΑΙ ΚΑΙΝΟΥΡΓΙΟΣ
Φυσικά διατίθεται στο κουτί του με ότι αυτό περιλαμβάνει, και φυσικά την εγγύηση
Τιμή 700 ευρώ
AVR-2809, AVR2809, AVR 2809 … The Latest HD Audio and Video Support … New lossless audio formats Dolby True HD and dts-HD Master Audio decoders … Deep Color 30/36 bits colour depth and xvYCC broader colour …
  • [FONT=&quot]The Latest HD Audio and Video Support[/FONT]
  • [FONT=&quot]New lossless audio formats Dolby True HD and dts-HD Master Audio decoders[/FONT] DSC00773.jpg
  • [FONT=&quot]Deep Color 30/36 bits colour depth and xvYCC broader colour space support[/FONT]
  • [FONT=&quot]4 x HDMI 1.3a inputs to handle HD audio and video signals with higher speed[/FONT]
  • [FONT=&quot]Identical quality and power for all 7 channels, 150W x 7[/FONT]
  • [FONT=&quot]Discrete Devices for ultimate performance in each block[/FONT]
  • [FONT=&quot]Dual 32bit floating point DSP[/FONT]
  • [FONT=&quot]Master clock design for more accurate processing and less jitter noise[/FONT]
  • [FONT=&quot]AL24 processing plus provides more dynamic range and improves low level sound details[/FONT]
  • [FONT=&quot]Denon's new audio technology for MP3/WMA/AAC compressed formats to reproduce higher frequency range and deeper bass sound[/FONT]
  • [FONT=&quot]HD Video Circuit[/FONT]
  • [FONT=&quot]Digital Media Connectivity[/FONT]
  • [FONT=&quot]Easeof-Use[/FONT]
  • [FONT=&quot]Auto set-up and Room EQ, featuring MultEQ XT from Audyssey[/FONT]
  • [FONT=&quot]Audyssey Dynamic EQ for clear voices, deep bass and an enveloping surround sound, even at low volume[/FONT]
  • [FONT=&quot]Audyssey Volume, Monitors the volume of program material moment-by-moment to ensure a consistent sound level regardless of boosted levels from the source, TV broadcasts etc (such as Advertising breaks etc)[/FONT]
  • [FONT=&quot]CEC protocol via HDMI - Bi-directional device control function between connected and compatible HDMI 1.3a devices (such as power on/off, volume control etc via TV remote)[/FONT]
  • [FONT=&quot]Includes dedicated zone remote control unit[/FONT]
  • [FONT=&quot]Auto Lip Sync (HDMI 1.3a)[/FONT]
  • [FONT=&quot]Multi Zone Capability[/FONT]
Απάντηση: Πωλείται ο Denon Avr 2809 150wx7.1 -8ohm ΤΙΜΗ 400Ε
Πωλείται ο Denon Avr 2809 150wx7 -8ohm ΤΙΜΗ 400Ε
Για χαρακτηριστικά δείτε τον παρακάτω σύνδεσμο:
http://www.denon.co.uk/site/frames_m...detail&Pid=386
Φυσικά διατίθεται στο κουτί του με ότι αυτό περιλαμβάνει, και φυσικά την εγγύηση Ακομα εχω και δυο ηχεια klipsch δαπεδου μαυρα 120watt 8 ohms δεν εχουν παιξει καθολου τιμη 300ευρω
Απάντηση: Πωλείται ο Denon Avr 2809 150wx7 -8ohm ΤΙΜΗ 700Ε
τελικα ειναι 700 ή 400? και χρωμα?
τα klipsch ποιό μοντέλο ειναι; μαζι και τα δύο 700Euro?
είσαι απο αθήνα?
Πωλείται ο Denon Avr 2809 150wx7.1 -8ohm ΤΙΜΗ 400Ε (ο ενισχυτης εκανε 1800ε και τα ηχεια 700ε)
Δυο ηχεια klipsch δαπεδου SF1 μαυρα 100watt 8 ohms δεν εχουν παιξει καθολου τιμη 300ευρω
ΠΡΟΣΦΟΡΑ ΚΑΙ ΓΙΑ ΤΑ ΔΥΟ
Ενισχυτης+230ευρω τα ηχεια=630ευρω
καλησπερα μηπως ειναι ακομα διαθεσιμος ο ενισχυτης;;
Ο ΕΝΙΣΧΥΤΗΣ ΕΙΝΑΙ ΑΚΟΜΗ ΔΙΑΘΕΣΙΜΟΣ ΚΑΙ ΠΩΛΕΙΤΑΙ
Βοήθεισέ με λιγο γιατι εχω μπερδευτει....
Εγγυηση??? Ποια εγγυηση? Ο ενισχυτης ειναι μοντελο του 2008. Πως γινεται και εχει εγγυηση? Και τι χτωμα ειναι? Μαυρος ή ασημι?
Περιμενω απαντηση γιατι ισως να με ενδιαφερει.
Σ'ευχαριστω!
Όταν αγοράσεις μια τηλεόραση π.χ. μοντέλο του 2008 σήμερα, δεν θα έχεις εγγύηση;
Επισης, συγνωμη για την παρεμβαση αλλα τα 7χ150 στα ποσα ωμ τα βγαζει? Δε νομιζω στα 8, γιατι οπου τον βρισκω στο νετ, γραφει 7χ115!!! Anyway!!
Ετσι κι'αλλιως αφου ειναι silver δε μου κανει. Ευχαριστω!
Dynamic power: 130 W x 2ch (8 Ω/ohms)
180 W x 2ch (4 Ω/ohms) ΕΥΧΑΡΙΣΤΩ ΓΙΑ ΤΟ ΕΝΔΙΑΦΕΡΟΝ
εαν αγοραστει απο καταστημα,σαφως και θα εχεις την εγγυηση απο την ημερα που αγοραστηκε.
ο συμφορουμιτης εχει καταστημα και τον πουλαει μεσω αυτου?
γιατι εαν ειναι ιδιωτης,εννοηται οτι εγγυηση εχει ληξη..
Πραγματικα, χωρις να εχω σκοπο να υποδειξω σε κανεναν τιποτα, η συγκεκριμενη αγγελια μονο κατανοητη δεν ειναι εξ΄αρχης...
Διαφορετικες τιμες με τεραστιες αποκλισεις με αποτελεσμα να μην καταλαβαινει κανεις ποσο στοιχιζει το καθε τι, αντι να απανταει ο ιδιος ο KRAT απαντανε στη θεση του διαχειριστες και συντονιστες, δεν διευκρινιζετε κατι συγκεκριμενο με την εγγυηση οπως αναφερει και ο φιλος dmtrpapa πιο πανω, και στοιχεια του ενισχυτη που μονο πραγματικα δεν ειναι....
Ο τιτλος της αγγελιας γραφει στα 8Ω και μετα μας γραφετε 2 X 130 κτλ. ενω πουλατε εναν πολυκαναλο av...
A
amoustakas
Θεωρώ ότι πρέπει να αναγραφεί από τον πωλητή η ημερομηνία αγοράς και τα έτη εγγύησης από την αγορά.
Καλησπέρα, δική μου παράλειψη κι ευχαριστώ για την επισήμανση.Ο ενισχυτής έχει αγοραστεί πριν από 2 χρόνια. Λόγω έλλειψης χρόνου δεν ήμουν όσο περιγραφικός χρειαζόταν.Η εγγύηση του έχει λήξει. Απλά έγινε κακή διατύπωση. Ο ενισχυτής βρίσκεται μέσα στο κουτί του σφραγισμένος γιατί δεν ανοίχτηκε ποτέ. Κατανοώ την καχυποψία -μέρες που ζούμε- αλλά τα πράγματα είναι just simple.AΠΛΑ. Για την ιστορία ΝΑΙ υπήρχε κι άλλος ενισχυτής ανέγγιχτος (μέσα στο κουτί). Δόθηκε -πουλήθηκε- στην ίδια τιμή κι ο άνθρωπος που τον πήρε με ευχαρίστησε.
Είμαι ιδιώτης για όσους ρωτάτε και δεν έχω μαγαζί. Λόγω προβλημάτων δεν χρησιμοποιήθηκαν για αυτό που τους προόριζα αλλά είναι μια καλή ευκαιρία για όσους πραγματικά ΘΕΛΟΥΝ ΝΑ ΑΓΟΡΑΣΟΥΝ.Χαιρετώ.
stratos.april
