m2tech joplin
deleted user 10898
[SIZE=+3]Venus meets Mars… Analog and Digital join the forces in the Joplin 384/32 ADC![/SIZE]
joplin
Analog is feminine: it’s warm, smooth, relaxing. Digital is macho: sharp, cold as iron, absolute. Joining the best from these two worlds seemed an impossible challenge… until today. M2Tech made it one more time with the Joplin 384/32 Analog-to-Digital converter: the perfect solution to connect the analog world to a digital system.
The Joplin is a very high performance analog-to-digital converter capable of 110dB SNR and up to 384/32 operation, with an USB port to connect it to a computer (as well as all other standard digital outputs capable of up to 192/24 operation).
To summarize the essence of the Joplin with the sentence above is fairly reductive. In fact, the Joplin is equipped with many interesting features which make it a complete solution to provide your system or your computer with the best analog front-end.
Noteworthy is the selectable analog input stage gain: 0dB (equivalent to 1.7Vrms for 0dBFS) to 65dB! This means that the full dynamic of the Joplin can be exploited even with sources providing a full-scale output as low as 0.95mVrms. This feature alone suggests to vinyl lovers that a cartridge can be directly connected to the Joplin inputs, to acquire the phono signal and equalize it in software on the computer.
But there’s more.
As owners of digital-only systems would love to connect a turntable to their digital amp, we provided the Joplin with comprehensive real-time equalization capabilities in digital domain: phono eq can be performed by the Joplin itself, thus outputting a digital signal ready for amplification out of a turntable, without the need for a phono preamp upstream the ADC inputs.
You may say: the Joplin is not the only ADC providing RIAA eq capability, and you’d be right. But the Joplin goes a long step further: use can choose from a complete set of eq curves, for microgroove LP’s, 78 rpm and even reel-to-reel tapes! All of this without the need for a computer, in real-time!
To complete the features set, the Joplin makes high-pass (anti-rumble) filters, low-pass (anti-hiss) filters and even an MPX filter (19kHz) available, to cope with noisy sources, warped records and FM signals coming out of tuners!
A high dynamic led VU-meter and an IR remote allow for full control of the Joplin.
Why choosing between analog and digital? Go for the Joplin and enjoy both!
deleted user 10898
http://www.m2tech.biz/joplin.html
Joplin
384/32 A/D converter
DETAILS
High-speed asynchronous USB connection. Single-ended stereo input on RCA.
S/PDIF, AES/EBU and Toslink digital outputs. Auxiliary S/PDIF input for bridging.
Selectable input gain 0dB to 65dB. Wide choice of equalization curves in digital domain.
Various filter options (anti-rumble, anti-hiss, MPX). Remote control.
Encased in a stylish aluminium case.
FEATURES
Joplin is a high performance A/D converter capable of handing up to 384kHz sampling rates and 32 bits resolution (USB output).
It features a high speed asynchronous USB input based on the hiFace Two technology, further developped to allow for higher sampling rates.
A comprehensive output set (S/PDIF on RCA, AES/EBU on XLR and optical on Toslink) provide great connection versatility.
Also, an auxiliary S/PDIF digital input on RCA allows for re-using the digital connection used for the Joplin for a digital source,
as well as for redirecting the output from a digital source to a computer which is not provided with an S/PDIF input.
Despite its price, Joplin encopasses a leading edge technology for data handling and processing.
An FPGA is used to provide a seamless connection between the ADC IC and the USB port (both operating in master mode for low jitter reasons),
as well as for a large number of important clock and data routing tasks, not to mention the VU-meter drive.
The analog stage is based on the best PGA (Programmable Gain Amplifier) available on the market, and allows for gain as high as 65dB (equivalment to 0.95mVrms for 0dBFS).
A comprehensive set of equalization curves can be selected, to accommodate all phono formats ever used from 1925 to the present day,
plus eq curves for reel-to-reel tapes with straight output from the playback head.
The small size and stylish look of the Joplin allow for a uninvasive placement in every living space.
SPECIFICATIONS
Size: 200(w) x 50(h) x 200(d) mm
Weight: 1Kg approx.
Sampling Frequencies(kHz):
44.1, 48, 88.2, 96, 176.4, 192, 352.8*, 384*
Resolution: 16, 20, 24 bit (S/PDIF, AES/EBU, optical, with or without dither), 16, 20, 24, 32 bit (USB, with or without noise shaping)
Frequency response: 10-20kHz +0.1/-0.5dB (fs = 44.1kHz), 10-150kHz +0.1/-0.1dB (fs=384kHz)
SNR: 122dB (A weighted, 384kHz, 32 bits, gain 0dB), 114dB (A weighted, 192kHz, 24 bits with noise shaping, gain 0dB), 100dB (A weighted, 192kHz, 24 bits with noise shaping, gain 40dB)
THD+N: 0.00045% (1.7Vrms in, 192kHz, 24 bits, gain 0dB)
Gain: 0dB, 10dB to 65dB in 1dB steps
Cross-talk: -110dB @1kHz
Inputs: analog single ended on RCA female, S/PDIF on RCA female
Oututs: 1x S/PDIF (RCA female), 1x AES/EBU (XLR), 1x optical (Toslink), 1x USB (USB female Type B)
Input voltage: 1.7Vrms (4.8Vpp @ 0dBFS)
Supply voltage: 15VDC
Supply current: 290mA
*: only USB
Manos58
εγχειρισμένη
Απάντηση: m2tech joplin
Μισή Metric δηλαδή.
Άντε να δουμε τι ψάρια πιάνει.
deleted user 10898
Re: Απάντηση: m2tech joplin
Μισή Metric δηλαδή.
η ουσια ειναι η ευχρηστια της συσκευης και ο σχεδιασμος της για την συγκεκριμενη χρηση, ενω απο τα χαρακτηριστικα της δειχνει αξιολογοτατη.
Απάντηση:το " joplin" αναφέρεται στο Scott ή τη Janice;
η ουσια ειναι η ευχρηστια της συσκευης και ο σχεδιασμος της για την συγκεκριμενη χρηση,ενω απο τα χαρακτηριστικα της δειχνει αξιολογοτατη.
Ο χαρακτηρισμός ΄΄αξιολογώτατη΄΄ υπερτιμά μιά συσκευή του δεδομένου βεληνεκούς η οποία δείχνει να περιφρονεί τα πλήρως ισορροπημένα κυκλώματα.
Απομονώνεται όμως ένα αξιοσημείωτο απόσπασμα από το εγχειρίδιο χρήσης:
The main difference between records and tapes is that almost no turntable is provided with
a built-in phono amplifier/equalizer, while almost all reel-to-reel tape recorders are. Thus,
providing tape equalizations could seem to be useless.
Not always. Reel-to-reel recorders lovers know that most of the machines around, built
between ’60 and the beginning of ’80, have generally great transports and heads but
barely adequate, if not poor, electronics. For this reason, some recorders owners ask
technicians to jump the playback circuit of the recorder, taking the signal right out of the
playback head and feeding a dedicated external amp/equalizer.
Same thing can be done with the Joplin, connecting the playback head of a tape recorder
to its analog inputs (eventually via an impedance adaptor), adjusting the gain as required
and selecting the appropriate equalization curve for the tape being played back. The signal
is acquired, equalized in digital domain and sent to a computer for recording or to a DAC
or digital amplifier for real-time listening. The ample bandwidth of the Joplin set to 96, 192
or 384kHz, and its high resolution are more than adequate to accommodate the tape
recorder performance.
deleted user 10898
Re: Απάντηση:το " joplin" αναφέρεται στο Scott ή τη Janice;
η τοποθετηση της συσκευης σε συγκεκριμενη αγορα με την εξοδο του πικαπ να ειναι σχεδον παντα στερεο rca νομιζω καθορισε την συγκεκριμενη επιλογη.
(ευχαριστω για την ορθογραφικη διορθωση, δυστυχως το "Μονάχη έγνοια η γλώσσα μου στις αμμουδιές του Ομήρου..." παραμενει για εμε ατοπικο....)
Manos58
εγχειρισμένη
Οι πιουριστές θα την "καταραστούν",οι ψηφιακοί θα αδιαφορήσουν........
Να δούμε το χαϊρι της .
... Analog is feminine: it’s warm, smooth, relaxing. Digital is macho: sharp, cold as iron, absolute. Joining the best from these two worlds...
Η εισαγωγή έχει “πλάκα” και διαφωνώ... πάντως με 2000 ευρώ θέλει ψείρισμα... ίδωμεν...
Y
Yiannis_B
Πιουρίστας ή πουρίστας? :116:
m2tech joplin:κατάρριψη της αναλογικής...αγνότητας
"... Analog is feminine: it’s warm, smooth, relaxing. Digital is macho: sharp, cold as iron, absolute. Joining the best from these two worlds..."
Η εισαγωγή έχει “πλάκα” και διαφωνώ...πάντως με 2000 ευρώ θέλει ψείρισμα... ίδωμεν...
Ένα δηκτικό σχόλιο θα μπορούσε να παραλληλίσει-με αφετηρία την εισαγωγή- την ΄΄αναλογική θηλυκότητα΄΄ με μιά ωραία κορασίδα που είναι από εμπρός παρθένα και όπισθεν...120 εργοστάσια ενωμένα:137:
deleted user 10898
Back to back and box fresh there are areas where I prefer the Joplin and where I prefer my Prefix. The Joplin does better bass. It has more depth, greater slam and less overhang. It’s better nuanced with every kick and thwack having more shape and more natural tone. It’s not a small difference, it’s a fundamental difference and if the bottom end is where it happens for you then the Joplin excels here. It memory serves me right it sounds better in the bass than either the Superline or Uphorik did, it really is first class. Across the mids I think there’s little to separate them you could prefer either on a particular day. I think the Joplin may trade a little sweetness in the mids, but repays you with greater soundstage definition and placement. It’s only in the treble where I prefer the Prefix and not by any great margin. Reading that back it sounds very cut and dried, and it isn’t. I think there’s more ‘flow’ to how my phonostage presents the music. I’ll refrain from serving up analog vs digital analogies but that’s what I’m hinting at, at least with the supplied SMPS.
http://www.computeraudiophile.com/f...-digital-my-experience-m2tech-joplin-d-13597/
deleted user 10898
For your money you get a nice case, an adequate psu, remote control, a high gain low noise pre-amp, top notch A/D, a Hiface evo, and the ability to use the Joplin as phonostage, Archival quality A/D and standards convertor between different digital formats. It would be unfair to call it a jack of all trades, with all that implies, as it does seem to be the master at extracting the best your records have to offer.
Simon
Απάντηση: m2tech joplin:κατάρριψη της αναλογικής...αγνότητας
Ένα δηκτικό σχόλιο θα μπορούσε να παραλληλίσει-με αφετηρία την εισαγωγή- την ΄΄αναλογική θηλυκότητα΄΄ με μιά ωραία κορασίδα που είναι από εμπρός παρθένα και όπισθεν...120 εργοστάσια ενωμένα :137:
Όταν έφυγαν οι “μεγάλοι” για τους γνωστούς λόγους... οι μικροί που έμειναν, έκαναν συνεταιρισμούς....
Απάντηση:Ουτοπίες αναλογικής υφής
Είναι οι αξιώσεις που προβάλλει η εν λόγω συσκευή στην αναλογική (όχι αποκλειστικά βινυλιακή) αγορά και η διαρρύθμιση του κυκλώματος οι οποίες θα επέτασσαν την επιπρόσθετη αναλογική είσοδο.
Αυτό τι είναι που έγραψες τωρα... οι δόσεις για την συσκευή
Οι απορίες μου είναι εύλογες
1. Εάν τα στούντιο σήμερα γράφουν σε 24/44.1 ή 24/96 ή 24/192 τότε ποιά η ανάγκη μετατροπής ενός αναλογικού σήματος σε ultra HD file 384/32? Ποιά είναι τα benefits αυτής της μετατροπής σε αντιδιαστολή με το 24/192? Υπολείπεται κάπου ή το 384/32 μπορεί να αποτυπώσει και την "θηλυκότητα"? (νέα εισαγώμενη ορολογία είναι αυτή για τον αναλογικό ήχο? :118:)
2. Εάν θες να το αναπαράγεις τότε θες και ένα 384/32 DAC. (άλλα τόσα χρήματα?)
3. Η ενίσχυση του ηλεκτρικού σήματος της κεφαλής (PGA που λέει ο κατασκευαστής έως 65DB) είναι η μοναδική παράμετρος που λαμβάνουν υπ'όψην? Σε μία κεφαλή για να πάρεις τα μέγιστα (για ορισμένους) ή για να παίξει απλά (για τους περισσότερους) οφείλεις να λάβεις υπ'όψην σου και άλλες παραμέτρους.
4. Εάν αποθηκευτεί τότε έχει αποθηκευτεί μία τυχαία αναπαραγωγή από τους 1.000.000 πιθανούς συνδυασμούς της και σε ποιότητα εξαρτώμενη αποκλειστικά από την ποιότητα του αναπαραγωγέα και του εγγραφόμενου μέσου που ακυρώνει το ultra HD της εγγραφής 384/24 καθώς μία lower με καλύτερο αναπαραγωγέα έχει καλύτερα αποτελέσματα.
ΙΜΗΟ για το connectivity του analog και digital world που το διαφημίζει θέλει πολλά καρβέλια ακόμα και αυτό μόνο εάν κάτσει να αφουγκραστεί το τι έχει να του πεί η κεφαλή.
Αυτά
Manos58
εγχειρισμένη
Η παντελής έλλειψη παραμετροποίησης της εισόδου (pF & Ω ) νομίζω καθιστά απαραίτητο ένα phonostage .
Επίσης στο manual μιλάει για (σχετική αλλά υπαρκτή)υποβάθμιση της ποιότητας του σήματος :422:από 384 σε 192 για να ειναι συμβατό με όλα τα mainstream dac .
Με το καλύτερο τροφοδοτικό θα παίξει και καλύτερα,θέλει και dac έπειτα για να ακούσεις.......και.....και
Μάλλον ακριβό βγαίνει τελικά το πείραμα .
Μόνο για ψηφιοποίηση βινυλίων κι αυτή με περιορισμούς .:415:
DimAster
