TEAC HR audio player
Gojakla
Αρχαιολάγνος πιουριτανίστας
Απάντηση: TEAC HR audio player
Συμβατό μόνο με τα DAC's της εταιρίας, UD-501, AI-501DA, UD-H01 και A-H01.
Αναπαράγει DSD(μόνο με το UD-501), dsf, diff, wav, flac, mp3.
Το έχει δοκιμάσει κανείς;
http://teac.jp/product/hr_audio_player/
Κάτι στα Αγγλικά δεν παίζει?
Μόνο στην Ιαπωνία βλέπω να παίζει προς το παρών... όλα τα άλλα site της Teac δεν το συμπεριλαμβάνουν.
Τα στοιχεία που έγραψες παραπάνω πού τα βρήκες? Μην μου πείς ότι διάβασες τα Τζαπανέζικα?!?!?!
Compatible with both music playback software DSD5.6MHz/PCM384kHz Win / Mac.
The current version: V1.0 (Windows) V1.0 (Macintosh)
"TEAC HR Audio Player" is a high-quality software compatible sound player that runs on Macintosh and Hi-Res Windows. Enjoy high-quality sound reproduction sound source, including hi-res DSD it is made ​​possible by the combination of the TEAC USB DAC corresponding to the sound source, such as a high-res TEAC UD-501, without any complicated settings. Since the launch of the DS-D98 DSD recorder for business in 2001, TEAC Co., Ltd. has accumulated know-how in the field of recording and playback on the DSD for commercial use. Continued to release DSD compatible devices since 2005, the year, 2006 DV-RA1000 is a DV-RA1000HD, we released the corresponding DSD USB ​​DAC UD-501 finally this year as consumer audio. By combining the UD-501 we know so far about the DSD was incorporated as "TEAC HR Audio Player", we will be able to enjoy high-quality sound playback DSD anyone easily. Playback software DSD traditional are often specialized, to play high-quality sound, but it was complex configuration is required advanced knowledge and, in the "TEAC HR Audio Player", the equipment you have connected in the configuration screen after installation high-quality listening environment is completed if you choose. Side-by-side on the player just the files you want to listen to by drag and drop, rest and play high-quality hi-res files you will be available. So that not only provides a high-res file playback environment can easily maximize the potential of compatible devices, high-quality care to play on the software side. By reducing the CPU load to simplify the display, I have made ​​so that you can play more smoothly. In DSD file playback under Windows environment supports the native DSD playback method and by ASIO2.1 DoP. You can select the playback method to suit the taste of the listener I am available. In addition to the listener you want quality trumps is equipped with a playback function RAM buffer to avoid deterioration of sound quality due to changes in CPU load to be loaded into memory once the data on the PC side. In addition, not only playing DSD, even in general play music files, high-quality sound reproduction is possible because it is a program that take into account quality. Since it is possible to benefit even play MP3 files, also used, A-H01 AI-501DA, UD-H01, free playback environment of high quality even those who use these devices You can get on. You can enjoy high-quality sound reproduction with high-res files easily anyone, "TEAC HR Audio Player" is a dedicated music playback software made ​​by TEAC USB DAC for free.
και ελληνικά (κορακίστικα)
Ο καθένας μπορεί εύκολα να απολαύσετε την υψηλής ποιότητας αναπαραγωγή αρχείων ήχου.
Συμβατό με τόσο λογισμικό αναπαραγωγής μουσικής DSD5.6MHz/PCM384kHz Win / Mac.
Η τρέχουσα έκδοση: V1.0 (Windows) V1.0 (Macintosh)
"TEAC HR Audio Player" είναι ένα υψηλής ποιότητας λογισμικό συμβατή συσκευή αναπαραγωγής ήχου που τρέχει σε Macintosh και Hi-Res Windows. Απολαύστε υψηλής ποιότητας αναπαραγωγή ήχου πηγή ήχου, συμπεριλαμβανομένων των υψηλής ανάλυσης DSD καθίσταται δυνατή με το συνδυασμό της TEAC USB DAC που αντιστοιχεί στην πηγή ήχου, όπως ένα υψηλής ανάλυσης TEAC UD-501, χωρίς περίπλοκες ρυθμίσεις. Από την έναρξη του DS-D98 εγγραφής DSD για την επιχείρηση το 2001, TEAC, Ltd έχει συσσωρεύσει τεχνογνωσία στον τομέα της εγγραφής και αναπαραγωγής με την DSD για εμπορική χρήση. Συνέχισε να απελευθερώσει DSD συμβατές συσκευές από το 2005, το έτος 2006, DV-RA1000 είναι ένα DV-RA1000HD, που κυκλοφόρησε το αντίστοιχο DAC DSD USB ​​UD-501 τελικά φέτος ως ήχο των καταναλωτών. Με το συνδυασμό της UD-501 που γνωρίζουμε μέχρι σήμερα για την DSD ιδρύθηκε ως «TEAC HR αναπαραγωγής ήχου", θα είμαστε σε θέση να απολαμβάνουν υψηλής ποιότητας αναπαραγωγή ήχου DSD κανείς εύκολα. Αναπαραγωγή λογισμικό DSD παραδοσιακά είναι συχνά εξειδικευμένες, για να παίξει υψηλής ποιότητας ήχο, αλλά ήταν πολύπλοκη ρύθμιση απαιτείται προχωρημένη γνώση και, στην "TEAC HR Audio Player", η συσκευή που έχετε συνδέσει στη διαμόρφωση οθόνη μετά την εγκατάσταση υψηλής ποιότητας περιβάλλον ακρόασης έχει ολοκληρωθεί αν επιλέξετε. Side-by-side για τον παίκτη μόνο τα αρχεία που θέλετε να ακούσετε με drag and drop, ξεκουραστεί και να παίξει υψηλής ποιότητας hi-res αρχεία σας θα είναι διαθέσιμο. Έτσι, ότι όχι μόνο παρέχει μια υψηλής ανάλυσης του περιβάλλοντος αναπαραγωγής αρχείων μπορεί εύκολα να μεγιστοποιήσουν το δυναμικό των συμβατών συσκευών, υψηλής ποιότητας περίθαλψη για να παίξει από την πλευρά του λογισμικού. Με τη μείωση του φορτίου της CPU για να απλοποιήσει την οθόνη, έχω κάνει, έτσι ώστε να μπορείτε να παίξετε πιο ομαλά. Στην αναπαραγωγή αρχείων DSD σε περιβάλλον Windows υποστηρίζει την εγγενή μέθοδο αναπαραγωγής DSD και από ASIO2.1 DoP. Μπορείτε να επιλέξετε τη μέθοδο αναπαραγωγής για να ταιριάζει με το γούστο του ακροατή είμαι διαθέσιμος. Εκτός για τον ακροατή θέλετε ατού ποιότητας είναι εξοπλισμένο με ένα απομονωτή RAM αναπαραγωγή λειτουργία για να αποφευχθεί η υποβάθμιση της ποιότητας του ήχου που οφείλονται σε μεταβολές του φορτίου της CPU που θα φορτωθεί στη μνήμη αφού τα δεδομένα από την πλευρά της PC. Επιπλέον, όχι μόνο παίζοντας DSD, ακόμα και σε γενικές γραμμές το παιχνίδι αρχεία μουσικής, υψηλής ποιότητας αναπαραγωγή ήχου είναι δυνατή, διότι είναι ένα πρόγραμμα που να λαμβάνουν υπόψη την ποιότητα. Δεδομένου ότι είναι δυνατόν να επωφεληθούν ακόμη και να παίξετε αρχεία MP3, χρησιμοποιούνται επίσης, A-H01 AI-501DA, UD-H01, ελεύθερο περιβάλλον αναπαραγωγή υψηλής ποιότητας, ακόμη και εκείνους που χρησιμοποιούν αυτές τις συσκευές Μπορείτε να πάρετε σε. Μπορείτε να απολαύσετε υψηλής ποιότητας αναπαραγωγή ήχου με υψηλής ανάλυσης αρχεία εύκολα ο καθένας, "TEAC HR Audio Player" είναι ένα ειδικό λογισμικό αναπαραγωγής μουσικής γίνεται με την ΕΑΒ TEAC USB για δωρεάν.
(απο αυτόματη μετάφραση)
υγ. Αντουάν θα σου κόψω μισθό...:105:
:619:
Gojakla
Δωρεάν παιδεία γιόκ? :114:
Το κατέβασες φίλε Gojakla? Έχει καμία διαφορά με foobar ή άλλο κλασικό player?
Gojakla
Απάντηση: Re: TEAC HR audio player
Αυτές οι δουλειές γίνονται ΣΚ αδερφέ Τεκάκιε...
ΥΓ. Από Φουμπαρ ντεν ξερει. Μακ έχω να παίζω τα Σαββατοκύριακα... :)
Αδερφέ Τεκάκιε χαχα ωραία θα το κατεβάσω και γω και θα σου πω :cool:
Gojakla
Το εγκατέστησα χθές στο Mac αλλά δεν άνοιξε ποτέ... κράσαρε συνέχεια!!!!
Έχει κανείς τρόπο να μάθουμε τί requirements έχει?????
Δεν μπορώ να βάλω όλο το manual στο Google Translate!!!!
roberto_portale
