H265, HEVC η νέα προδιαγραφή video codec
gkontoletas
trouble in my brain
Εγκρίθηκε από την ITU ο νέος video codec Η265-HEVC.
Geneva, 25 January 2013 – A new video coding standard building on the PrimeTime Emmy award winning ITU-T H.264 / MPEG-4 AVC was agreed by ITU members today.
The new codec will considerably ease the burden on global networks where, by some estimates, video accounts for more than half of bandwidth use. The new standard, known informally as ‘High Efficiency Video Coding’ (HEVC) will need only half the bit rate of its predecessor, ITU-T H.264 / MPEG-4 Part 10 ‘Advanced Video Coding’ (AVC), which currently accounts for over 80 per cent of all web video. HEVC will unleash a new phase of innovation in video production spanning the whole ICT spectrum, from mobile devices through to Ultra-High Definition TV.
ITU-T’s Study Group 16 has agreed first-stage approval (consent) of the much-anticipated standard known formally as Recommendation ITU-T H.265 or ISO/IEC 23008-2. It is the product of collaboration between the ITU Video Coding Experts Group (VCEG) and the ISO/IEC Moving Picture Experts Group (MPEG).
Dr Hamadoun I. Touré, Secretary-General, ITU: “ITU-T H.264 underpinned rapid progression and expansion of the video ecosystem, with many adopting it to replace their own proprietary compression codecs. The industry continues to look to ITU and its partners as the global benchmark for video compression, and I have no doubt that this new standard will be as effective as its predecessor in enabling the next wave of innovation in this fast-paced industry.”
ITU-T H.264 / MPEG-4 AVC is deployed in products and services from companies including Adobe, Apple, BBC, BT, France Telecom, Intel, Microsoft, Motorola, Nokia, Polycom, Samsung, Sony, Tandberg, Toshiba and others to deliver high definition video images over broadcast television, cable TV, a variety of direct-broadcast satellite-based television services, Blu-Ray disc formats, mobile phones, videoconferencing tools, digital storage media, and Internet Protocol television (IPTV). It remains the most deployed global video compression standard.
ITU-T H.265 / ISO/IEC 23008-2 HEVC will provide a flexible, reliable and robust solution, future-proofed to support the next decade of video. The new standard is designed to take account of advancing screen resolutions and is expected to be phased in as high-end products and services outgrow the limits of current network and display technology.
Companies including ATEME, Broadcom, Cyberlink, Ericsson, Fraunhofer HHI, Mitsubishi and NHK have already showcased implementations of HEVC. The new standard includes a ‘Main’ profile that supports 8-bit 4:2:0 video, a ‘Main 10’ profile with 10-bit support, and a ‘Main Still Picture’ profile for still image coding that employs the same coding tools as a video ‘intra’ picture.
The ITU/ISO/IEC Joint Collaborative Team on Video Coding (JCT-VC) (formerly JVT) will continue work on a range of extensions to HEVC, including support for 12-bit video as well as 4:2:2 and 4:4:4 chroma formats. Another important element of this work will be the progression of HEVC towards scalable video coding. The three bodies will also work within the Joint Collaborative Team on 3D-Video (JCT-3V) on the extension of HEVC towards stereoscopic and 3D video coding.
http://www.itu.int/net/pressoffice/press_releases/2013/01.aspx
Τι ακόμα απλά Blu-Ray βλέπεις εσύ?:biggrin: (Σώωωωωωωωωωωπα! Δουλεύουν και τα smilies κι ας είναι απαίσιο το νέο λευκό skin).
Απάντηση: Re: H265, HEVC η νέα προδιαγραφή video codec
...κι ας είναι απαίσιο το νέο λευκό skin.
...το οποίο είναι απείρως καλύτερο από το προηγούμενο μονόχρωμο/μουντό. Αν και πάντα μου άρεσε το σκουρόχρωμο, τουλάχιστον αυτό έχει και κάποιες χρωματικές αντιθέσεις.
Sorry για το off topic. :idk:
gkontoletas
trouble in my brain
Απάντηση: H265, HEVC η νέα προδιαγραφή video codec
καλό θα είναι το 4Κ για αρχή, το 8Κ είναι το μέλλον...
loggeo
Νομίζω ότι ως την ανακοίνωση του ps4 (μέχρι τον Ιούνιο), θα έχουμε και την οριστικοποίηση του 4k blu ray.
Chauncey Gardiner * tl;dr *
Μα τι γράφετε? Δεν υπάρχει ούτε ο αποθηκευτικός χώρος γιά 8K. Ποιοί σοβαροί τα λένε?
Για bandwidth ας μην το συζητήσουμε, δεν υπάρχει ούτε για 2K.
Εδώ καλά καλά δεν έχουμε δει ολοκληρωμένο 4Κ (υλικό, πηγές, μέσα απεικόνισης) και φτάσαμε στα 8Κ...:headbang:
για τους σχιστοματηδες μιλαμε βρε....:tongue:
ωραια φατσουλα αυτη με την γλωσσα.....:tongue:
......η φατσουλα με τον τυπο που εχει κατεβασμενο το βρακι ο ενας και ριχνει ξυλειες ο αλλος,μηπως μπορουμε να την βαλουμε...?:tongue:
Re: Απάντηση: H265, HEVC η νέα προδιαγραφή video codec
Τι λες μωρή ανώμαλη? :rofl:
gkontoletas
trouble in my brain
Οι προδιαγραφές λένε ότι ένα video με codec HEVC θα χρειάζεται το μισό περίπου bitrate σε σχέση με τον codec Η264 για την ίδια τουλάχιστον ποιότητα απεικόνισης.
The delivery of UltraHD TV requires a more efficient compression codec made possible by the use of the new High Efficiency Video Coding (HEVC) standard. HEVC speeds Internet video downloads giving operators and users the ability to download content such as movies in half the time and with higher quality video at 50 percent of the bit rate previously required.
http://www.broadcom.com/press/release.php?id=s732069
Επίσης μη λαμβάνεις υπόψη το bandwidth που έχεις στο χωριό σου, οι χώρες που πρωτοστατούν στις εξελίξεις έχουν μέσο όρο πάνω από 30Mbps ήδη και θα πάνε στα 100Mbps στα επόμενα 3-5 χρόνια
Γιατι ανωμαλος βρε.....μια χαρα φατσουλες ειναι...:tongue:
δεν μπορω να την βρω ρε γαμωτο....!!!!
ο abcd μπορει ομως......για να δω..!!!!!
Στις μεγάλες πόλεις μόνο. Διάβασε λίγο το μέσο όρο των ΗΠΑ να γελάσεις.
ταχουμε πει βρε....
[YOUTUBE]9TFo5ja4TQY[/YOUTUBE]
gkontoletas
trouble in my brain
Βρε οι ΗΠΑ ακολουθούν, δεν διαμορφώνουν πλέον τις εξελίξεις, προς την ανατολή να κοιτάς...
Ρε παίδες, πιστεύει κανείς ειλικρινά ότι χωρίς φυσικό μέσο (δισκάκι ή κάτι άλλο) πρόκειται να περάσουμε σε εποχή 8Κ? Ακόμα ψάχνουμε (ή σχεδόν) να βρούμε πού θα χωρέσουμε τα 4Κ.
μα και ο νεος video codec ειναι μερος του 4κ βρε Γιαννη μου..... ειναι το χαλί :tongue:
Πλάκα θα κάνεις, τουλάχιστον όσο αφορά στις ταινίες.
albie
