HTC ONE, SnapDragon 600, 1080p
gkontoletas
trouble in my brain
Η HTC ανακοίνωσε το νέο ONE σε δυο παράλληλες εκδηλώσεις στην Νέα Υόρκη και στο Λονδίνο.
  • Android 4.1.2 with HTC Sense 5
  • Processor: Qualcomm Snapdragon 600, quad-core, 1.7GHz
  • DISPLAY: 4.7 inch, Full HD 1080p, 468 PPI
  • Total storage: 32GB/64GBi, available capacity varies
  • RAM: 2GB DDR2
  • Battery: 2300 mAh embedded rechargeable Li-polymer battery
  • SIZE: 137.4 x 68.2 x 9.3mm/4mm (max/min)
  • WEIGHT: 143 grams with battery
NETWORK
  • GSM/GPRS/EDGE (850/900/1800/1900 MHz)
  • WCDMA (1900/2100 (B2/B1) MHz)
  • CDMA (800/1900 BC0/BC1/BC10, Sprint)
  • LTE (1900 (B25, SPCS)
  • Frequencies will vary by region/operator
CAMERA
  • BSI sensor, Pixel size 2.0 μm, Sensor size 1/3'
  • Dedicated HTC ImageChip 2
  • F2.0 aperture and 28 mm lens
  • Optical Image Stabilization (OIS)
  • Smart Flash: Five levels of flash automatically set by distance to subject
  • Front Camera: 88 wide angle lens with HDR capability
  • 1080p Full HD video recording for both front and back cameras
  • HDR Video
  • Continuous shooting and VideoPic
  • Slow motion video recording with variable speed playback
  • HTC Zoe with highlights and HTC Zoe Share
  • Retouch with Object Removal, Always Smile, and Sequence Shot
CONNECTIVITY
  • 3.5 mm stereo audio jack
  • NFC capable
  • Compliant with Bluetooth 4.0
  • Bluetooth 4.0 with aptX enabled
  • Wi-Fi: IEEE 802.11 a/ac/b/g/n
  • DLNA for wirelessly streaming media from the phone to a compatible TV or computer
  • Support consumer infrared remote control
  • micro-USB 2.0 (5-pin) port with mobile high-definition video link (MHL) for USB or HDMI connection (Special cable required for HDMI connection.)
SENSORS
  • Gyro sensor
  • Accelerometer
  • Proximity sensor
  • Ambient light sensor
LOCATION
  • Internal GPS antenna + GLONASS
  • Digital compass
http://www.htc.com/gr/smartphones/htc-one/#overview
Απάντηση: HTC ONE, SnapDragon 600, 1080p
Μμμμμμμμ...
... και δεν πα να λέτε ό,τι θέλετε για τα android.
[video=dailymotion;xxmcqv]http://www.dailymotion.com/video/xxmcqv_htc-one-m7-hands-on_tech#from=embediframe[/video]
πολύ καλό το hardware...αλλά μια ζωή τρεις εκδόσεις πίσω θα είναι στο software...
για μένα pure android ftw...;)...nexus rulezz!
Φοβερά specs, μεταλλικό περίβλημα, ιδανικό μέγεθος και πολύ ωραίο design !
Αν έχει μια λογική τιμή και το στηρίξει η htc από πλευράς εκδόσεων, τότε...γιατί όχι ?
Αυτό με τα 4mp camera, τι ιστορία είναι ?
" The camera of the HTC One sports a 4MP sensor and 1080p@30fps video recording (with HDR). The sensor has what HTC calls Ultrapixels, which are much larger than the regular smartphone pixels and promise vastly improved per-pixel quality and low-light performance. The smartphone also offers gyroscope-based Optical image stabilization which should come in handy for video recording."
Έχει κάποια βάση ή είναι μαρκετινίστικο κόλπο ?
αμέ πολύ λογική...750!
όσο για την υποστήριξη...ένα update σε 4.2.2 και μετά θα έρθει το επόμενο μοντέλο...as always...
εάν επαληθευτούν αυτά, τότε μάλλον θα πάει...άπατο...
Η αλήθεια είναι πως η HTC μας έχει συνηθίσει σε τέτοιου είδους συμπεριφορές, αλλά κάπου διάβαζα πως προτίθεται να αναθεωρήσει κάποια πράγματα και πως θα ακολουθήσει μια διαφορετική πολιτική για να αυξήσει το μερίδιό της.
Είναι κρίμα για μια εταιρεία η οποία έχει τα φόντα να πρωταγωνιστήσει.
Ίδωμεν...
gkontoletas
trouble in my brain
Το HTC One έχει πομποδέκτη υπερύθρων, μια δυνατότητα που την είχαμε χάσει εδώ και μερικά χρόνια.
Η HTC παρουσίασε το IR API που είναι μέρος του HTC OpenSense SDK και επιτρέπει την δημιουργία εφαρμογών που εκμεταλλεύονται τον πομποδέκτη υπερύθρων.
Ήδη το Sense 5 περιέχει την εφαρμογή Sense TV που επιτρέπει τον απευθείας έλεγχο διαφόρων ηλεκτρονικών συσκευών, π.χ. TV, AV receivers και BD players.
http://blog.htc.com/2013/02/calling-all-ir-apps/
DAMBO
