Microsoft and Nokia Lumia Windows Phones
gkontoletas
trouble in my brain
Νέα μοντέλα παρουσίασε η Nokia, το Lumia 928 για τις ΗΠΑ και το Lumia 925.
Έχουν διαρρεύσει ήδη φωτογραφίες και πληροφορίες για το Lumia EOS
Lumia 928
Lumia 925
Lumia EOS
gkontoletas
trouble in my brain
Σήμερα στις 18:00 ώρα Ελλάδας θα ξεκινήσει η εκδήλωση της Nokia στην Νέα Υόρκη, βασικό θέμα θα είναι η παρουσίαση του Lumia 1020 aka EOS.
Δείτε τη ζωντανά από το επίσημο κανάλι της Nokia http://www.nokia.com/global/about-nokia/events-page/
gkontoletas
trouble in my brain
[YOUTUBE]5nRj9pv0y9M[/YOUTUBE]
Nokia Lumia 1020
Espoo, Finland and New York, NY - Today, Nokia established a new benchmark in smartphone imaging with the arrival of the Nokia Lumia 1020, boasting a second generation 41 megapixel sensor. Unlike any smartphone in the market today the Nokia Lumia 1020 reinvents zoom, enabling people to discover more detail than the eye can see. With Nokia's innovative PureView technology, including optical image stabilization, the device is able to produce some of the sharpest images possible by any digital camera.
This is made possible by leading hardware technology combined with a new application called Nokia Pro Camera, which makes it easy for anyone to take professional quality images. Either before a picture is taken or after it has been shot, the zoom capability enables people to discover and then rediscover the personal stories each image can tell. With a beautiful interface that visually demonstrates how settings will affect the final photo or video, Nokia Pro Camera makes it easier than ever to capture, edit and share photos and videos with unrivaled clarity.
Using a new feature called dual capture, the Nokia Lumia 1020 simultaneously takes a high resolution 38 megapixel image for endless editing opportunities, and creates a 5 megapixel picture that is easy to share to social networks with Windows Phone 8.
The Nokia Lumia 1020's 41 megapixel sensor features leading ZEISS optics with six physical lenses, plus optical image stabilization, delivering crystal clear pictures even in low light conditions. It also captures blur free videos with stereo sound even at the loudest concerts thanks to Nokia Rich Recording, which handles sound pressure levels six times louder than conventional smartphone microphones.
http://press.nokia.com/2013/07/11/zoom-reinvented-nokia-lumia-1020-arrives/
Networks: GSM: 850 MHz, 900 MHz, 1800 MHz, 1900 MHz, WCDMA: 2100 MHz, 1900 MHz, 850 MHz, 900 MHz, LTE network bands: 1, 3, 7, 20, 8
Display: 4.5” AMOLED WXGA (1280Χ768), 2.5 D sculpted Corning Gorilla 3 Glass, ClearBlack, high brightness mode, sunlight readability, super sensitive touch
Battery: 2000 mAh battery, wireless charging supported via cover
Processor: 1.5GHz dual-core Snapdragon
Main camera: PureView 41-megapixel with optical image stabilization, Resolution: 7712 x 5360. Includes Nokia Pro Camera. Xenon flash for still images, LED flash for video
Front facing camera: HD 1.2-megapixel wide angle
Memory: 2GB RAM, 32GB internal memory; 7GB free SkyDrive cloud storage
I/O USB2.0, BT 3.0, NFC with SIM based security, WLAN a/b/g/n, A-GPS and Glonass, 3.5 mm audio connector
Size/weight 130.4 x 71.4 x 10.4mm, Weight: 158g
http://conversations.nokia.com/2013/07/11/nokia-lumia-1020-the-smartphone-camera-revolution-begins/
Nokia Lumia 1020 whitepaper (pdf file)
Ενώ τώρα γράφει απούλητο! :biggrin:
Το 1020 δε θα ανακοινωθεί;
gkontoletas
trouble in my brain
στις 11 Ιουλίου ανακοινώθηκε το 1020, μάλλον κάποια υπηρεσία ή κάτι με τους χάρτες θα ανακοινώσουν αύριο
gkontoletas
trouble in my brain
Τελικά το "μεγάλο" αναφερόταν στην μεγαλύτερη οθόνη που χρησιμοποιεί μέχρι στιγμής η Nokia σε κινητό τηλέφωνο.
Το νέο Lumia 625 έχει οθόνη 4.7'' ανάλυσης 840 x 480.
Με τιμή κοντά στα 200 ευρώ είναι ένα φθηνό κινητό με μεγάλη οθόνη για όσους έχουν θέμα με την μικρή γραμματοσειρά των οθονών υψηλής ανάλυσης.
Είναι αρκετά όμορφο και έχει συμμαζεμένες διαστάσεις σε σχέση με το μέγεθος της οθόνης.
http://www.nokia.com/global/products/phone/lumia625
gkontoletas
trouble in my brain
Nokia Lumia 1520
Operating System: Windows Phone 8 with the latest updates
Networks: GSM/EDGE: 850, 900, 1800, 1900 MHz; WCDMA: 850, 900, 1900, 2100 MHz; ROW LTE: 1, 3, 7, 8, 20; USA LTE: 2, 4, 5, 7, 17; HSPA+: DL 42 Mbps (Cat 24) / UL 11.5 Mbps (Cat 7)
Speed: LTE 150/50 mbps, DC-HSPA 42mbps
Memory: 2GB RAM, 32 GB internal user memory; 7 GB SkyDrive cloud storage, micro SD card support up to 64GB
Display: 6-inch full HD 1080p LCD , ClearBlack, High Brightness Mode, Sunlight readability, Super sensitive touch for glove and nail usage, Gorilla Glass 2
Processor: 2.2GHz Quad Core Qualcomm Snapdragon 800
Primary camera: PureView 20-megapixel Auto Focus ZEISS optics with Optical Image Stabilization (OIS), 2x lossless zoom, oversampling technology, dual LED flash, 1080p @ 30 fps full HD video with optical image stabilization
Secondary Camera: HD 1.2-megapixel wide angle
Size & weight: 162.8 x 85.4 x 8.7mm (volumetric). Weight: 209g
Connectivity: NFC, A-GPS+GLONASS, WLAN (2.4/5Ghz) a/b/g/n/ac, μUSB, BT 4.0 LE, Accelerometer, Proximity sensor, Magnetometer, Gyroscope, Ambient Light Sensor
Battery: 3400 mAh (integrated) with built-in wireless charging (Qi compatible)
Audio: Rich Recording with four microphones; Wideband Voice and multi-microphone noise reduction with four microphones; Dolby(R) Headphone, Graphic equalizer, Audio leveling; FM radio
gkontoletas
trouble in my brain
Nokia Lumia 1320
Networks: LTE-ROW: GSM 850, 900, 1800, 1900 MHz; WCDMA 850, 900, 2100 MHz; LTE 800, 1800, 2600; LTE-LTA: GSM 850, 900, 1800, 1900 MHz; WCDMA 850, 1700, 1900, 2100 MHz; LTE 700, 850, 1700, 1900 MHz; HSPA+: GSM 850, 900, 1800, 1900 MHz; WCDMA/HSPA + 900, 2100 MHz.
Speed: LTE:3, 7, 20 bands – 100/50 Mbps (cat 3); DC-HSPA ROW: 42/5.76Mbps (cat 24 DL/Cat6 UL); HSPA+ CHINA: 21/5.76Mbps (Cat 14DL/Cat6 UL); GSM: EGPRS 236.8Kps
Memory: 1GB RAM, 8GB internal user memory; 7GB SkyDrive cloud storage, micro SD card support up to 64GB
Display: 6-inch HD LCD IPS (1280×720), Super sensitive touch support for glove and long nail use; Gorilla Glass 3
Processor: 1.7GHz Dual-Core Qualcomm Snapdragon 400
Primary camera: 5MP Auto Focus, flash. Video 1080p @ 30fps
Secondary Camera: 0.3MP VGA.
Size & weight: 164.25 x 85.9 x 9.79* mm (*volumetric). Weight: 220g
Connectivity: BT 4.0 + LE, Micro-USB 2.0, 3.5mm AHJ, WIFI 802.11(2.4GHz b/g/n)
Audio: 1 HAAC mic; 3.5mm AV connector, HD Voice; FM Radio
  • loggeo
Ioanniss
