VLC media player
gkontoletas
trouble in my brain
Απάντηση: VLC media player (free o.r.i.g.i.n.a.l. blu-ray player)
VLC v2.0
VIDEO
  • Rewritten video output core and modules, allowing subpicture blending in GPU.
  • Shader support in the OpenGL output, for colorspace conversion, including 10bits.
  • New video outputs for Windows 7, Android, iOS and OS/2.
  • New debanding, grain, denoising and anti-flickering filters.
  • New deinterlacing filter, including an Inverse Telecine algorithm.
AUDIO
  • New resamplers for higher quality audio.
  • New dynamic range compressor and karaoke filters.
  • Simplification of the audio core for faster processing.
  • New audio outputs for iOS, Android and OS/2.
FORMATS
  • Multi-threaded decoding for H.264, MPEG-4/Xvid and WebM.
  • Support for 10bits codecs, WMV image and some other codecs.
  • Rewritten support for images, including jpeg, png, xcf, bmp...
  • Important changes in RealVideo and Real Format support.
  • CrystalHD cards and Android OpenMAX support for hardware decoding.
INPUT AND DEVICES
  • Experimental support for BluRay discs:
    - Menus are deactivated in this release (will come soon).
    - AACS and BD+ DRM libraries and keys are not shipped, for legal reasons.
  • Support for SDI capture cards and QTKit devices.
  • Support for new adaptive streaming protocols, like HLS and DASH.
FOR MAC USERS
  • Completely new, single window interface:
    - Available in 2 colors: Lion grey and QTX black.
    - Extensions support and better Lion integration.
  • Support for all QTKit devices through qtcapture and qtsound modules.
  • Continued support for X 10.5 and PPC users (1080p and ProRes on Dual-G5!).
FOR ANIME FANS
  • Vastly improved MKV demuxer.
  • Rewritten linked segments and ordered chapter files support.
  • Correct support for FLAC, RV and Hi10p in MKV.
  • Rewritten seeking support in cue files.
  • Various ASS subtitles improvements.
FOR PROFESSIONAL USERS
  • Support for ProRes 422 and 4444, AVC/Intra.
  • Support for Jpeg-2000 and DNxHD/VC-3 in 10bits.
  • Support for EBU subtitles (stl) and EIA-608.
  • SDI and HD-SDI card support for input on Linux.
  • New Dirac/VC-2 encoder, faster than the previous one.
FOR DEVELOPERS
  • libVLC, libVLCcore and libcompat have switched from GPL to LGPLv2.1+.
  • New libVLC examples are available: media player, photobooth and mediainfo clones.
  • New JSON requests on the web interface to control running VLC instances.
  • Implementation of the MPRIS2 interface to control media players.
  • VLC's web plugins have been rewritten for better integration and stability in all browsers.
http://www.videolan.org/
2.0.4
# Audio Output:
* Improve playback synchronization with PulseAudio.
* Fix ALSA digital pass-through ("S/PDIF").
* Fix live audio device selection on Mac OS X
* Fix detection of some 5.1 and 7.1 kits on Windows.
* Fix audio output behavior when the output device is plugged or unplugged during playback on Mac OS X
# Access:
* Fix numerous DVD (dvdnav) crashes
* Fix HTTP playback through proxy and advertise gzip correctly
* Fix TLS busy-loop during client-side handshake
# Codecs:
* Support for Opus decoding via libopus, including multi-channel files
* Support MSS1 and MSS2 decoding through DMO libraries
* Fix Hebrew and Greek subtitles encoding
* Fix crashes on malformed subtitles and malformed png files
* Fix crashes when using hardware decoding
# Demuxers:
* Fix issues in Ogg with zero length packets
* Fix file duration of Ogg/Theora and Ogg/Vorbis files
* Fix vimeo, koreus and youtube lua parsers
* Support Youtube live streams
# Windows:
* Fix Wallpaper mode on Windows 7/8
# Qt:
* Fix media info dialog update
* Fix random/repeat preferences saving
* Fix crashes when opening audio effects dialog, with skins and playlist
* Fix crash on association dialog on Windows XP
* Fix album art display at start
# Mac OS X:
* Fix command-line options to control the interface behavior
* Deactivate CoreAnimation effects on Leopard
* Fix menus display and behavior
* Fix various crashes and small issues including bookmarks, playlist, buttons, streaming wizard, video size, hotkeys and fullscreen controller
* Fix font selection for Unicode subtitles
* Improve system sleep behavior when playing audio-only media. The screen is allowed to sleep while the system is kept awake during playback.
* Fix code signing of Delete Preferences application
* Add option to Audio Effects panel to activate the Karaoke filter
# Miscellaneous:
* Fix Notify (D-Bus) plugin deadlock.
* Fix buffer corruption in freetype and subtitles modules
* Improve Blu-Ray and HLS support
* Fix issues on selection of playlist items for WebUI
* Codec and other 3rd party library updates
* Fix swscale and canvas behavior with Aspect Ratio
* Fix mime-type when streaming Webm over HTTP
* Fix recording behaviour in Windows network environments
* Codecs and 3rd party libary updates
# Translations:
* Updates of Norwegian Bokmål, Korean, Slovak, Serbian, Russian, Traditional Chinese, Simplified Chinese, Portuguese, Walloon, Turkish, Thai, Polish, Dutch, Khmer, Hindi, Japanese, Galician, Hebrew, German, Breton, Scottish Gaelic, Czech, Estonian translations
* Initial translations for Bengali, Fula, Gujarati and Bosnian
http://www.videolan.org/vlc/
παντως μια παλια εκδοση που ειχα κρασαρε και παιζει χαλια τα m2ts
2.0.6 http://www.videolan.org/
# Access:
* Fix HTTPS playback with some certificates previously rejected
# Audio Output:
* Improve lookup of human readable device names in AUHAL plugin (OS X)
# Demuxers:
* Fix crash with broken asf files (SA-1302)
* Fix MKV behaviour with unknown or new ebml elements
* Fix use-after-free crash in Ogg demuxer, found by Tomi Juntunen
* Fix regression on some paletted codecs in AVI
* Fix ALAC in mp4 regression
* Improvements to the vimeo playlist parser
# Decoders:
* Fix GPU decoding on Intel HD 2000/3000 cards on Windows
* Fix FLAC 6.1 and 7.1 channel layout
* Fix crashes in HTML srt subtitles
* 3rd party codecs updates
# Mac OS X:
* Fix subtitle rendering resolution when using OS X's native fullscreen mode
* Improve fullscreen controller time slider with larger click target
* Fix listing of the lua interfaces (web, telnet and console) in the advanced preferences panel
* Fix spatializer audio filter panel
* Fix crash within the video output code
* Fix BDMV folder selection issue on OS X Mountain Lion, which treats such folders as a AVCHD file as soon as they include an item named INDEX.BDM
* Fix bug which caused a hidden fullscreen panel
* Fix various minor UI drawing issues (main window, fullscreen controller, lua extensions, ...)
* Allow VLC to be associated with .dvdmedia packages
# Qt:
* Fix clearing of Media Info panel on dialog exit
# GNU/Linux:
* Numerous D-Bus and MPRIS2 improvements
* Reject broken versions of PulseAudio
# Windows:
* Fix uninstallation in different location than C:\
# Translations:
* Update of Brazilian Portuguese, Traditional Chinese, Thai, Portuguese, Japanese, Italian, Hebrew, Estonian, Spanish, Czech, Catalan, Bosnian, Asturian, French, Romanian, Serbian, Russian, Hindi, Estonian, German Slovenian Norwegian Bokmεl, Khmer, Icelandic, Interlingua, Welsh, Ukrainian, Dutch, Danish, translations
* New Gujarati, Aragonese translations
2.0.7 http://www.videolan.org/
# Input:
- Fix playback termination when switching ES tracks (PowerPC only)
- Fix memory exhaustion vulnerability when playing specifically crafted playlist files
# Decoders:
- Fix WMA Pro, MPEG 4 ALS, APE, MLP and ADPCM-IMA4 playback
# Encoders:
- Fix audio encoding for numerous codecs, notably mp3 and aac
# Muxers:
- Fix noticeable memory leak when creating AVI files
# Video output:
- Fix crash when using libvlc in 3rd party applications (Mac only)
# Mac OS X Interface
- Minor improvements
- Fix issue which could lead to loss of media files created through transcoding
# HTTP Interface
- Fix two xss vulnerabilities (CVE-2013-3565)
# Translations:
- Update Basque, Simplified Chinese, Ukrainian, Turkish, Portuguese, Norwegian Bokmεl,Burmese, Lithuanian, Italian, Hindi, Spanish, German, Czech, Danish, Welsh translations
- New Azerbaijani, Kirgyz, Oriya translations
gkontoletas
trouble in my brain
Η νέα έκδοση του VLC 2.1 "Rincewind" υποστηρίζει αναλύσεις Ultra HD, δεν μένει όμως μόνο σε αυτό...
With a new audio core, hardware decoding and encoding, port to mobile platforms, preparation for Ultra-HD video and a special care to support more formats, 2.1 is a major upgrade for VLC.
Rincewind has a new rendering pipeline for audio, with better effiency, volume and device management, to improve VLC audio support.
It supports many new devices inputs, formats, metadata and improves most of the current ones, preparing for the next-gen codecs.
Rincewind fixes around a thousand bugs, in more than 7000 commits from 140 volunteers.
VIDEO
  • Port the OpenGL output to OpenGL ES.
  • Support color conversion shaders in glsl on Android and iOS.
  • New outputs for OpenMax IL on mobile and Decklink Blackmagic.
  • New video outputs for iOS using OpenGL ES2.
  • Support for deinterlacing for higher bit depth and XYZ colorspace.
  • New anaglyph filter for side-by-side 3D.
  • 4K-ready :)
CODECS
  • Add hardware decoding for OS X using VDADecoder.
  • Add hardware decoding for Android using MediaCodec.
  • Add hardware decoding for GNU/Linux using VDPAU.
  • Add hardware encoding for Windows using Intel QuickSyncVideo.
  • Support for G2M4, MSS1, MSS2, TSCC2, CDXL, Ut, VBLE video codecs.
  • Support for Ulead DV audio, Indeo Audio Coder, RealAudio Lossless audio.
  • Support for SCTE-27 and complete EIA-608 subtitles.
http://www.videolan.org/vlc/releases/2.1.0.html
vlasis
Φωτογράφος!
ωραια πραματα λεμεεεεεεε...η απορια μου κυριε μοντερατορα ειναι αν τον VLC τον παιζουμε μονο του ,με τους δικους του codecs η και εδω μπορουμε να παιζουμε με LAV και MADVR ?
Για πες?
σαν να τα λεει καλα .......
gkontoletas
trouble in my brain
Μπορείς να βάλεις διάφορα φίλτρα, τουλάχιστον σε Windows, δεν ξέρω τι γίνεται σε OS X, Linux και Android...
vlasis
Φωτογράφος!
μα μονο με πι τσι παιζω βρε ...και Windows βεβαιως βεβαιως!!!!!!!
για πες λοιπον......
Πάντως ειναι ενα πολυ χρησιμο και απλό προγραμμα και το κυριωτερο τζαμπα....:D
DAMBO
