HDMI 2.0 officially announced
gkontoletas
trouble in my brain
Ανακοινώθηκαν οι προδιαγραφές του HDMI 2.0.
HDMI 2.0, which is backwards compatible with earlier versions of the HDMI specifications, significantly increases bandwidth up to 18Gbps and adds key enhancements to support continuing market requirements for enhancing the consumer video and audio experience.
New functionality includes:
  • 4K@50/60, (2160p), which is 4 times the clarity of 1080p/60 video resolution
  • Up to 32 audio channels for a multi-dimensional immersive audio experience
  • Up to 1536kHz audio sample frequency for the highest audio fidelity
  • Simultaneous delivery of dual video streams to multiple users on the same screen
  • Simultaneous delivery of multi-stream audio to multiple users (up to 4)
  • Support for the wide angle theatrical 21:9 video aspect ratio
  • Dynamic synchronization of video and audio streams
  • CEC extensions provides expanded command and control of consumer electronics devices through a single control point
HDMI 2.0 does not define new cables or new connectors. Current High Speed cables (Category 2 cables) are capable of carrying the increased bandwidth.
http://www.hdmi.org/manufacturer/hdmi_2_0/index.aspx
HDMI 2.0 FAQ
Απάντηση: HDMI 2.0 officially announced
δλδ στο "περιμενε" αν κάποιος θελει να έχουν τα μηχανακια του το νεο hdmi...
blue-ray και av ενισχυτές...αλλαγή στα βύσματα θα υπάρχει σίγουρα...
Re: Απάντηση: HDMI 2.0 officially announced
Το γράφει στο πρώτο post, δεν αλλάζουν τα βύσματα.
στα FAQs γράφει οτι για να υποστηρίξη μια συσκευή που ήδη έχουμε το hdmi 2, θα χρειαστεί απο τον κατασκευαστή του να γίνει hardware/firmware upgrade...αν όντως βγάλουν όλες οι εταιρίες ένα firmware update και "καθαρίσουμε" έχει καλώς...
Is HDMI 2.0 backwards compatible with HDMI 1.x?
Yes, all HDMI versions are fully backward compatible with all previous versions.
Does HDMI 2.0 require new connectors?
No, HDMI 2.0 uses the existing connectors.
Does HDMI 2.0 require new cables?
No, HDMI 2.0 features will work with existing HDMI cables. Higher bandwidth features, such as 4K@50/60 (2160p) video formats, will require existing High Speed HDMI cables (Category 2 cables).
Can my existing HDMI 1.x devices be upgraded with HDMI 2.0 features?
Currently, there are no provisions for doing such an upgrade. Because of the new enhanced feature set, any such conversion would require hardware and/or firmware upgrades. If there are such conversions, it would come from the manufacturer. Please check with them directly.
gkontoletas
trouble in my brain
Η IFA θα είναι γεμάτη με προϊόντα που θα έχουν HDMI 2.0
Από τις νέες δυνατότητες θα ξεχωρίσω ότι αφορά την εικόνα και κυρίως την δυνατότητα ανάλυσης 4Κ στα 50/60Hz.
Η βελτίωση του CEC είναι επίσης πολύ χρήσιμη όπως και η μεταφορά δυο streams video και μέχρι τεσσάρων streams audio.
Τα 32 κανάλια ήχου αφορούν πολύ λίγους, για τους περισσότερους είναι μια δυνατότητα που δεν θα χρησιμοποιήσουν ποτέ, δύσκολα σε ένα μέσo HC μπορεί κανείς να βάλει πάνω από 7 ηχεία.
Θα συμφωνήσω με τον Δημήτρη πολύ αρνητικά βλέπουν αρκετοί την εξέλιξη.
loggeo
Απορώ τι hdmi θύρες θα έχουν τα ps4 και xbox one. Το πρώτο το έχω ήδη προπαραγγείλει. Λογικά θα είναι τα πρώτα players που θα υποστηρίζουν native 4k σε 60 hz.
gkontoletas
trouble in my brain
Η Panasonic TC-65WT600 4K είναι εξοπλισμένη με HDMI 2.0 και DisplayPort 1.2a.
Οι φίλοι των H/Y ας μην βιαστούν να στεναχωρηθούν ή να αλλάξουν κάρτα γραφικών, όσοι έχουν κάρτες γραφικών με DisplayPort 1.2a υπερκαλύπτουν ήδη τις προδιαγραφές του HDMI 2.0
gkontoletas
trouble in my brain
Λόγω περιορισμένου internet δεν έχω διαβάσει πολλά για το HDMI 2.0.
Μήπως είδατε κάπου να αναφέρουν κάτι σχετικό με το handshake, θα έχουμε βελτίωση ή θα περιμένουμε πάλι αρκετά δευτερόλεπτα όταν αλλάζουμε είσοδο;
loggeo
Πάντως αυτό που κάνει εντύπωση είναι η δυνατότητα να αναβαθμιστούν οι ultra hd τηλεοράσεις της sony σε hdmi 2.0 με ένα απλό software update.
Ποιος ξερει...ας μην ξεχνάμε οτι το πρώτο playstation 3 με μια αναβάθμιση του λογισμικού έγινε 3D
loggeo
Φαινόταν ότι κάποιο λάκκο είχε η φάβα. Στο βίντεο που ακολουθεί ο "πολύς" Joe Kane εξηγεί γιατί το hdmi 2.0 δε θα μπορέσει να δώσει τη καλύτερη δυνατή λύση στο μελλοντικό 4k/60 hz υλικό. Για όσους βαριούνται να δουν το βίντεο να πούμε ότι οι προδιαγραφές του νέου hdmi, επιτρέπουν μεν την αναμετάδοση 4k υλικού στα 60hz, αλλά με αρκετά μεγαλύτερη συμπίεση (κι ως εκ τούτου κατώτερη ποιότητα) απ' το 4k@24 και 30hz.
Link
gkontoletas
trouble in my brain
To HDMI 2.0 υποστηρίζει τους παρακάτω συνδιασμούς
4K/60p/4:4:4/24bit
4K/60p/4:2:2/36bit
4K/24p-30p/4:4:4/36bit
το bandwidth δεν φτάνει για 4K/60p/4:4:4/36bit
HDMI 1.4
2K/60p/4:4:4/36bit
Τι μας κόφτει εμάς; 24p θα έχουμε κι αυτό έχει σημασία. :D
Για τα τηλεοπτικά 4Κ(!!!) και τα 3D; :fuckyou:
loggeo
Θέλω τη συλλεκτική έκδοση του hobbit που θα κυκλοφορήσει το 2021 σε 4k/60hz μωρή!:D
gkontoletas
trouble in my brain
HDMI 2.0a με την προσθήκη HDR...
HDMI FORUM, INC. RELEASES 2.0a SPECIFICATION
Enables Transmission of High Dynamic Range (HDR) Formats
SUNNYVALE, Calif., - April 8, 2015 – HDMI Forum, Inc., a non-profit, mutual benefit corporation, today announced the completion and release of Version 2.0a of the HDMI® Specification. It is available to current HDMI 2.0 Adopters via the HDMI Adopter Extranet.
The specification has been updated to enable transmission of HDR formats, which provide enhanced picture quality by simultaneously enabling greater detail for both the dark and bright parts of an image. The HDR-related updates include references to CEA-861.3, CEA’s recently published update of HDR Static Metadata Extensions.
“We recognized that HDR would be a critical feature as the industry evolves. Our support for HDR enables our 800+ HDMI 2.0 Adopters to develop market-leading products that include HDR and will maintain interoperability across the entire HDMI ecosystem,” said Robert Blanchard, President of the HDMI Forum, Inc. “Along with the publication of the CEA extensions, the HDMI Forum continues to update the HDMI Specification and remain closely aligned with leading CE standards organizations.”
“By adding HDR, the HDMI Specification continues its history of supporting the latest formats and technologies planned for Hollywood content,” said Arnold Brown, Chairman of the HDMI Forum, Inc. Board of Directors.
For more information about HDMI technology, please visit http://www.hdmi.org.
http://www.hdmi.org/press/press_release.aspx?prid=138
  • loggeo
Konstantinos M.
