bt.1886
για οσους παιζουν ......:D
Μια αρκετα καλη συμπεριφορα αποτελεσματος στην εικονα σας παιζοντας με gamma bt -1886 οταν δεν εχετε καλο μαυρο και αρκετο φως δλδ το συνηθες....για TV η PROJECTOR
The correct approach is suggested by the sRGB standard and has fairly recently been codified in a new gamma specification called BT.1886, which uses 2.4 as a starting point but adjusts the overall response curve depending on the black level and white level of the display. Like sRGB, BT.1886 recommends a gamma response that is higher at the top end than at the low end. A straight power curve of 2.4 is correct only if the display has a zero black level and an infinite contrast ratio, which no real-world display has. The full BT.1886 specification is complex and its precise recommendations vary depending upon the white level, and especially the black level, of the display. However, if you don't want to bother with a precise BT.1886 calculation, white/black values of 120/0.03 cd/m2 serve as a good rule of thumb. This results in a gamma response between 2.3-2.4 at the top end and 2.2-2.1 on the low end.
ξεκιναει με gamma 2 στο 5% και φτανει με gamma 2.3 στο 95%
loggeo
Κώστα είναι πολύ καλό, αλλά...
No DVD/Blu-Ray you will watch will have been mastered to this new standard...
(or general TV programs either...)
It will be adopted in time, but that time is not yet.
Ο τύπος που το λέει είναι ο υπεύθυνος της light illusion, με της οποίας το λογισμικό γίνεται το mastering σε πολλά studio του Χόλιγουντ.
The goal of BT.1886 was to create a standard that effectively emulated what CRTs did. The idea being that you could start using the new formula on flat panels replacing the old CRT BVMs. So while it's true it wasn't used officially to master DVDs, the intent is that you'd calibrate a display with BT.1886 and get results comparable to what the old BVMs did. It is accurate to say that while studios are interested, aware, and will likely move to BT.1886 at some point, they aren't currently calibrating their displays with it. Of course that may be partially due to a lack of software with support for BT.1886.
Τα παραπάνω ανήκουν στον Joel Barsotti υπεύθυνο της spectracal (βλέπε calman).
Για την ιστορία πάντως το bt.1886 μοιάζει ιδανική λύση για home cinema, όπως σωστά αναφέρεις. Ήδη calman και chromapure το υποστηρίζουν στο λογισμικό τους.
για να φτιαξεις βεβαια κατι τετοιο σε gamma πρεπει να εχει και το καταλληλο μενου το μεσο απεικονισης.
δυστυχως η ρυθμιση gamma σε πολλα μεσα απεικονισης δεν υπαρχει ......ειδικοτερα και συγκεκριμενα σε προβολεις dlp δεν υπαρχει πουθενα......
αυτη η τεχνολογια ρε παιδι μου εχει μεινει πισω για τα καλα....
μιας και βρηκα λιγο χρονο δοκιμασα για να εχω και αποψη.....γιατι μονο απο το γραφημα μπορει να κανεις λαθος......βασικα ηθελα να δω την δυσκολια ρυθμισης ......
με white/black 40 / 0.008 cd/m2 πρεπει να εχουμε gamma οπως ειναι η κοκκινη γραμμη...!!!!!
....καμια σχεση με αυτα που γνωριζαμε...δλδ το 2.2 - 2.3
δοκιμασα την ρυθμιση με δυναμικη ιριδα on
....με δυναμικη ιριδα off δεν δοκιμασα....η δυναμικη ιριδα αυτου του προβολεα ειναι αρκετα καλη σε σχεση με τις περισσοτερες μιας και διπλασιαζει μονο το on/off του χωρις προβληματα κατα την θεαση της και χωρις φιδακια στην καμπυλη gamma.
η δυσκολια ρυθμισης και τελικου αποτελεσματος εικονας ειναι εκει(οπως εγραψα παραπανω)επεσα μεσα.....δλδ χρειαζεται το μεσο απεικονισης να διαθετη τουλαχιστον ανα 10ire ρυθμιση του gamma σε RGBY .....αν διαθετη μονο ρυθμιση Υ δεν φτανει....εκτος και αν κατσει κατα λαθος...
Εννοειτε οτι ενας εξωτερικος scaler μπορει να σας κανει οτι θελετε...
αλλα το gamma 2.2 - 2.3 απο 5ire ως 95ire ειναι το καλυτερο :D
loggeo
Εντύπωσεις με υλικό; Πως σου φάνηκε; Στα χαμηλά ire αποδίδει μια χαρά. Όσο ανεβαίνει έχει μια τάση να κάνει πιο κοντραστάτη την εικόνα, αλλά με ξενίζει λίγο σε σχέση με το 2.2. By the way, με εξωτερικό scaler μπορείς να φτιάξεις μια χαρά bt.1886 ανα 5 ire.
gkontoletas
trouble in my brain
Κωστάκη θα μας τρελάνεις!!!!!!
έγραψες καλό λόγο για δυναμική ίριδα,
ποιο είναι το προβόλι;
οπως τα λες ειναι....
"9. What are the main advantages of using BT.1886?
BT.1886 creates a closer match between different video displays, so that the same video signal
will appear more consistently on different displays.
Since BT.1886 has rapidly been adopted by content producers, setting your display to BT.1886
will also provide the best opportunity to view video content as it was originally produced."
Σωστο ειναι μιας και εχει σχεση με το μαυρο-λευκο.
βεβαια υπαρχουν καποια θεματα ως προς την οριοθετιση φωτεινοτητας....θα δουμε.
και οπως ειπα πιο πανω χρειαζεται το μεσο απεικονισης πληρες μενου για την ρυθμιση του gamma ......δυστυχως ελαχιστα μηχανηματα το διαθετουν αυτο.
καλη χρονια Γιωργο μου......:)
loggeo
Καλή χρονιά φίλος! Το έν λόγω gamma προσπαθεί να συνδυάσει τα πλεονεκτήματα απ´ τα υπόλοιπα. Δεδομένου ότι "πατάει" στο black level του προβολικού, με σωστή μέτρηση στα χαμηλά δεν υπάρχει κίνδυνος να χάσει shadow detail. Απ´ την άλλη στα ψηλά ire δείχνει λίγο πιο κοντραστάτη και "σκοτεινή" η εικόνα. Δεν είναι καθόλου κακή λύση. Pick your poison!
MaxHeadroom
Ενδιαφέρον στις παρούσες συνθήκες.
Όμως με τις OLED 1ης γενιάς να βγάζουν ήδη "μη-μετρήσιμο" επίπεδο μαύρου με ταυτόχρονη παρουσία φωτεινών σημείων στην οθόνη (και 0,0004 cd/m2 στο μαύρο της 4Χ4 ANSI-σκακιέρας!), μάλλον θα είναι φτου κι απ'την αρχή το θέμα του "ψηφιακού γάμμα".
Katerinanota
