Αναβαθμίσεις Mac OS και προγραμμάτων της Apple!
iTunes 11.1
WHAT'S NEW
Version 11.1:
  • iTunes Radio
    • iTunes Radio is a great new way to discover music. Choose from over 250 stations or start a new one from your favorite artist or song. Enjoy iTunes Radio ad-free once you subscribe to iTunes Match.
  • Genius Shuffle
    • Introducing a magical new way to experience your music library. Choose Genius Shuffle and iTunes instantly plays songs that go great together. Click it again to hear something new: enjoying your music has never been this easy.
  • Podcast Stations
    • You can now create custom stations of your favorite podcasts that update automatically with new episodes. Your stations, subscriptions, and current play position sync over iCloud to the Podcasts app.
  • Sync with iOS 7
    • You can now use iTunes to sync your favorite music, movies, and more to devices with iOS 7. In addition, iTunes now makes it even easier to quickly organize and sync apps to your iPhone, iPad, and iPod touch.
Αναβαθμισεις για τα Airport Extreme & Time Capsule 2013 δηλ. αυτά:
Install the update through your Airport Utility.
AirPort Extreme and Time Capsule Firmware Update7.7.2 is for AirPort Extreme and AirPort Time Capsule base stations with 802.11ac. It:
  • Addresses an issue that prevents a USB hard drive connected to an AirPort Extreme from appearing as an available disk in Time Machine
  • Resolves an issue that may intermittently cause a loss in WAN connectivity
  • Resolves an issue that may result in a network loop
WHAT'S NEW
Version 7.7.2:
REQUIREMENTS
  • Intel
  • OS X 10.7.2 or later
  • AirPort Extreme or AirPort Time Capsule base station with 802.11ac
iPhoto update για το 10.9 μόνο:
WHAT'S NEW
Version 9.5.1:
  • Fixes an issue that could cause print previews to render incorrectly
  • Includes stability and performance improvements
REQUIREMENTS
Intel, OS X 10.9 or later
xfader
Διαθέσιμο για download το OS X Mavericks 10.9.1 update.
Οι βασικές βελτιώσεις:
  • Improved support for Gmail in OS X Mail, and fixes for users with custom Gmail settings Improves the reliability of Smart Mailboxes and search in Mail
  • Fixes an issue that prevented contact groups from working properly in Mail
  • Resolves an issue that prevented VoiceOver from speaking sentences that contain emoji
  • Fixes an issue that prevented iLife and iWork apps from updating on non-English systems
  • Addresses an issue that may cause multiple prompts to unlock “Local items” keychain
  • Addresses an issue that may cause Japanese keyboards to retain a previously used language
  • Resolves issue that prevents a Contact group name from populating the address field
  • Includes Safari 7.0.1
    • Fixes an issue that could cause Safari to become unresponsive when filling out forms on fedex.com, stubhub.com, and other websites Improves Credit Card Autofill compatibility with websites
    • Improves VoiceOver compatibility with facebook.com
    • Updates Shared Links periodically when open in the Safari Sidebar
Αναβάθμιση για το iTunes
WHAT'S NEW
Version 11.1.4:
  • Resolves an issue where the equalizer may not work as expected and improves performance when switching views in large iTunes libraries.
  • Minor bug fixes.
  • Note: If you are using OS X 10.9 Mavericks, your book library can now be found in iBooks for Mac.
REQUIREMENTS
  • Intel
  • OS X 10.6.8 or later
  • Safari 4.0.3 or later
Εχουν βγει εδώ και λίγη ώρα αναβαθμίσεις για Pages,Keynote & iMovie!
Θα τις βρείτε στο Mac App Store!
Σε λίγη/ες ώρες μάλλον θα δείτε και το Numbers να έχει update,αν δε το βλέπετε ήδη στο App Store.
Επίσης υπάρχει αναβάθμιση για Epson printers & scan drivers.Αυτό θα το δείτε στις αναβαθμίσεις αν έχετε εγκατεστημένο κάποιο printer ή scanner της epson.Αλλιώς δε σας το βγάζει,δεν έχει και νόημα άλλωστε αν έχουμε πχ canon εκτυπωτές και σαρωτές!
Ισως να υπάρχει και συνέχεια απόψε από την Apple!
P.S:Αν αναβαθμίζουμε τις εφαρμογές μέσα από το App Store καλό θα είναι να γυρίσουμε την γλώσσα σε αγγλικά,restart or logout και μετα την επιτυχή εγκατάσταση γυρίζουμε πάλι σε ελληνικό περιβάλλον.Φαίνεται το App Store σε 10.9,να έχει κάποιες δυσλειτουργίες σε ελληνικό περιβάλλον και σε συνδιασμό με αναβαθμίσεις κάποιων προγραμμάτων!
Παιδιά καλησπέρα. Έχω πάθει μεγάλη ζημιά. Έκανα την αναβάθμιση και απο την στιγμή αυτή το πρόγραμμα βιντεοεπεξεργασίας της δουλειάς μου, το οποίο είναι το i Movie HD (το παλιό i Movie όχι το νέο με το "αστεράκι" για εικονίδιο) έχει προβλήματα και κάποιες δουλειές μου δεν μου ανοίγουν σωστά. Ανοίγουν αλλα δεν μπορώ να κάνω τίποτα. Μόνο με το space απλά προχωράει το βίντεο απο εκεί που ήταν πρίν την ζημιά. Ούτε μπρός ούτε πίσω αλλα και καμιά παρέμβαση, ούτε καν export μπορώ να κάνω ώστε να ξανατοποθετήσω τα θέματά μου σε νεο project.
Δεν μπορώ και να επαναφέρω τον MacBook Pro μου στην προηγούμενη κατάσταση. 8-)
Υ.Γ. Σε ορισμένες δουλειές το κάνει και όχι σε όλες γενικά!!!!
Αν είσαι σε 10.9 δυστυχώς πρέπει να αναβαθμίσεις και το iMovie!
Δεν υπάρχει άλλη λύση!
Στείλε όμως και κάνα pm!;)
Κι εγώ επίσης! με το ίδιο ακριβώς πρόγραμμα δεν υπάρχει λύση σε 10.9.1 θα κάνεις downgrade!
Ωχ έμπλεξες με σκράπα σε ορολογίες και αγγλικά!!!:tongue: Με λίγα λόγια, την πάτησα; Πρέπει να βρω κάποιο άλλο Mac με την προηγούμενη εκδοχή του λογισμικού ώστε να δουλέψει το πρόγραμμα; Είδα επίσης στις επιλογές του i movie στο check for update να μου βγάζει 1 πινακάκι που μου λέει.... A new version of iMovie is available as part of iLife ’11. ΚΑΙ ΚΑΤΑΛΗΓΕΙ ΜΕ ΤΙΣ ΕΠΙΛΟΓΕΣ.... cancel η Learn More. Δεν το έτρεξα όμως,μήπως και τα κάνω χειρότερα!!!
Πίσω μου είπαν πως πάει μόνο εαν λειτουργούσα το time machine. Δεν ξέρω τι λες κι εσύ. Όσο για την αναβάθμιση του προγράμματος, μήπως να περίμενα κάποια διόρθωση του λειτουργικού στο να γίνει συμβατό με το i movie; Διότι η λογική λέει πως θα υπάρχουν χιλιάδες χρήστες στον κόσμο που θα χρησιμοποιούν το παλιό i movie. Λες να ...τρέξω το παραπάνω που σου έγραψα στο προηγούμενο μήνυμα;
Με το παλιό imovie το καλό,σε 10.9.1 δεν υπάρχει λύση!
Ή αναβαθμίζεις το imovie και προσαρμόζεσαι στα νέα δεδομένα,ή πας πίσω στο λειτουργικό!
Με Time Capsule αν έχεις ή με καθαρή εγκατάσταση από την αρχή.
Όταν λες αναβαθμίζω το i Movie HD τι θα αλλάξει; Είναι διαφορετικό το πρόγραμμα η όπως το ξέρω; Επίσης, θα χάσω σε κάτι άλλο εαν το κάνω; (πχ δεν θα ανοίγουν τα πάμπολλα project μου; )
Είναι αρκετά διαφορετικό το πρόγραμμα,τώρα σε πολλά projects δεν ξέρω ακριβώς, ανοίγουν όλα απλά αν είναι κάποια πολύ παλιά τα κάνει αυτόματα convert για να είναι συμβατά με το νέο imovie.
Θα σε ξενίσει λίγο στην αρχή η λειτουργία του,δε θα χάσεις τίποτα όμως από τα projects που έχεις!
Φοβάμαι να το κάνω. Το πρόβλημά μου το άμεσο πάντως είναι πως έχω έναν γάμο που πρέπει να παραδώσω και με την αναβάθμιση του λογισμικού δεν μου ανοίγει και έχω πρόβλημα με τους ανθρώπους. Περιμένουν να τους δώσω τον γάμο τους και δεν μπορώ να τον δουλέψω καθόλου.
JAndronikos
