νεο μπλοκι απο την musical fidelity
stathis
Ultra Home Theater
AMS50 - Specifications
Performance
  • Power output: 50 Watts per channel into 8 Ohms (17 dBW)
  • THD(+ noise): <0.006% typical
  • Signal to Noise Ratio: >110dB
  • Frequency Response: +0, –0.4dB, 10Hz to 40kHz
Inputs
  • 1x RCA Phono Line Level
  • 1x Line level XLR Balanced
General
  • Dimensions - WxHxD (mm): 483 x 325 x 460
  • Weight (unpacked / packed): 60 kg / 65 kg
Ο μεγαλυτερος εδω
http://www.avsite.gr/forum/threads/musical-fidelity-ams100-power-amplifier.103377/
Y
Yiannis_B
"The AMS50 has 50 watts into eight ohms and 100 watts into four ohms throughout its total power rating. Don't let the power rating of 100 watts into four ohms fool you into thinking that the AMS50 would not do well at driving low-efficiency speakers. Its peak-to-peak current rating is a whopping 100 amps. The AMS50 has enough current to drive virtually any speaker on today's market with control and ease."
Virtual reality ...:rolleyes: quiz: ποια η σχέση του peak to peak current με την στιγμιαία μέγιστη τιμή?
http://en.wikipedia.org/wiki/Alternating_current
  • Like
Reactions: PPG
Evasound
