Ας παίξουμε λίγο με τον madVR
gkontoletas
trouble in my brain
madVR v0.87.5
* error diffusion now uses DirectCompute (DX11 GPU needed) instead of OpenCL
* added fast and reasonably high quality "ordered dithering" algorithm
* added "rendering\dithering" settings page with many new options
* new default dithering is now ordered dithering instead of random dithering
* madTPG now always uses monochromatic ordered dithering
* fixed: #107: XySubFilter: reducing CPU queue size during playback -> crash
* fixed: #112: 120fps clip resulted in 23Hz being selected instead of 60Hz
* fixed: #119: installation resulted in "might not have installed correctly"
* fixed: #123: XySubFilter: Nearest Neighbor/Bilinear distorted subtitles
* fixed: #125: forced film mode with unsupported FOURCCs: graphical corruption
* fixed: #133: XySubFilter: opaque black box when smooth motion was enabled
* fixed: #136: when playback is stopped, madVR now always turns the video off
* fixed: #137: Nearest Neighbor/Bilinear has problems with post-resize shaders
* fixed: #138: smooth motion FRC flickered when using Nearest Neighbor
* fixed: #145: DCI-P3 was using an incorrect white point
* fixed: #155: screeshots sometimes had an added black border
* fixed: #159: speciying DCI-P3 as the calibrated gamut -> green screen
* fixed: #160: corruption with uncompressed 4096x2304 v210 in AVI
* fixed: #161: YUV 4:4:4 videos with weird resolutions crashed madVR
* fixed: #165: overlay mode restricted madVR to single player window
* fixed: #167: dithering produced dithering noise on pure black areas
* fixed: #169: dithering produced dithering noise on pure white areas
* fixed: #170: Overlay mode sometimes unnecessarily cleared GPU gamma ramps
* fixed: Overlay mode applied 3dlut and gamma ramps in wrong order
* fixed: crash reporting didn't catch exceptions in private threads, anymore
* fixed: crash when using XySubFilter with small GPU queue size
* fixed: DVD navigator was not released properly by madVR
* fixed: Run/Seek hooks also affected secondary DirectShow graphs
* fixed: profile key shortcuts only worked for "scaling" profiles
* fixed: full range YCbCr input produced slightly incorrect colors
* reduced Overlay mode graphical corruption when resizing media player
* exclusive -> windowed switch now shows a black frame instead of an old one
* removed XySubFilter auto-loading functionality, it's now XySubFilter's job
* disabled resolution based DCI-P3 auto detection
* changed default luma doubling value to 32 neurons
* display bitdepth can be be set to as low as 3bit (just for testing)
http://forum.doom9.org/showthread.php?t=146228
gkontoletas
trouble in my brain
madVR v0.87.6
* fixed: #090: FSE mode switched to 23Hz instead of 24Hz in Windows 8
* fixed: #127: crash when jumping to next video file on secondary monitor
* fixed: #173: overlay: exiting multiple windows in same order -> black screen
* madTPG now forces ordered dither, but you can en/disable colored & dynamic
* added support for new subtitle API ISubRenderConsumer2::Clear()
Γιώργο, αν περάσω το τελευταίο firmware του madVR, πρέπει να τον ρυθμίσω (να τον ρυθμίσεις εσύ δηλαδή...:p) απ' την αρχή?
gkontoletas
trouble in my brain
Από την έκδοση 0.87 έχει πολλές αλλαγές, θέλει πολύ ψάξιμο
gkontoletas
trouble in my brain
madVR v0.87.7
* added linear light processing for ordered dithering and error diffusion
* added "trade quality for performance" option for linear light dithering
* fixed: #175: Banding appears if bitdepth is set to '7 bit'
* fixed: crash in MC19 when switching videos with native DXVA decoding
* fixed: rare overlay stability problems introduced in v0.87.5
* random dithering doesn't round down to less than 8bit, anymore
* "present several frames in advance = off" now auto-disables error diffusion
* display bitdepth can be be set to as low as 1bit (just for testing)
* added silent exception handling for Intel OpenCL initialization crashes
* madTPG now optionally supports APL windows (gamma and linear light)
* madTPG now has a minimum image area of 4% instead of 10%
* madTPG now draws a 20 pixel black border around the measurement area
* madTPG now properly supports dynamic dithering (didn't before)
* madTPG dithering was optimized to not dither for integer test patterns
* madTPG headers and demo projects updated
* madVR in a media player no longer supports test pattern, only madTPG does
gkontoletas
trouble in my brain
madVR v0.87.8
* added workaround for NVidia OpenCL <-> D3D9 interop driver bug
* fixed: #158: NNEDI3 chroma upscaling + DXVA deint + NVidia -> green image
* fixed: DirectCompute rendering resources weren't properly released
* fixed: some multi monitor problems introduced in v0.87.7
* fixed: smooth motion frc sometimes incorrectly dropped frames
* fixed: toggling subtitle "trade quality" option required restart
* some DirectCompute stability improvements
* added vendor based OpenCL device filtering
* non-DX11-GPUs: error diffusion now falls back to ordered dithering
* improved Windows 8.1 FSE mode refresh rate hack
gkontoletas
trouble in my brain
madVR v0.87.9
* fixed: NNEDI3 didn't work properly on AMD/Intel (introduced in v0.87.8)
* fixed: native DXVA decoding + NNEDI3 chroma up + NVidia -> green color cast
* fixed: #032: Smooth Motion FRC sometimes failed to activate
* fixed: #096: Smooth Motion FRC resulted in last/only frame being hidden
* fixed: #097: Smooth Motion FRC didn't respect "treat 25p movies as 24p"
* fixed: #098: "Treat 25p movies as 24p" now only activates up to 25.5fps
* fixed: #104: "Delay playback until ..." failed when toggling subtitles
* fixed: #113: film mode key shortcut didn't enable Smooth Motion FRC
* fixed: #124: videoLUTs were not properly restored in multi monitor setup
* fixed: #132: Image corruption when leaving FSE with 3dlut loaded
* fixed: #171: film mode activation with display mode change could crash
* fixed: #178: RGB/YUV 4:4:4 with mod2 height showed black screen
* fixed: #182: NNEDI3 chroma up neuron count wasn't properly memorized
* fixed: #187: switching subtitles triggered a short black screen
* fixed: #189: Smooth Motion FRC sometimes activated when not needed
* NNEDI3 no longer offsets by 0.5 pixel if Luma needs to be resampled, anyway
* added "HKCU\Software\madshi\madVR\OpenCL\forceVendor" override option
* modified madLevelsTweaker GUI to make intended multi monitor usage clearer
Πας γυρεύοντας βλέπω! :D
gkontoletas
trouble in my brain
Η νέα έκδοση του madvr απέκτησε 64bit φίλτρα και υποστήριξη πραγματικού 10bit χρώματος.
* added Direct3D 11 presentation path
* added support for native 10bit output
* added NEDI image doubling option
* added "image enhancements" settings page for source enhancements
* added "upscaling refinement" settings page for upscaling post processing
* added FineSharp to source enhancement and upscaling refinement
* added LumaSharpen to source enhancement and upscaling refinement
* added SuperRes to upscaling refinement
* added chroma upscaling option "activate SuperRes filter"
* added Shiandow's deband algorithm
* removed chroma image doubling options
* fixed some 64bit stability issues
* fixed crash when two madVR instances had the same parent (DVBViewer BiB)
* fixed one potential DXVA decoding freeze
* trade quality option "lose BTB and WTW..." is disabled by default now
* added SettingsSetBoolean("FinalizeOnWMClose") option
* (un)install.bat now complains if you don't run them as admin
* (un)install.bat now doesn't try to install madVR64 on a 32bit OS, anymore
madvr v0.88.1
gkontoletas
trouble in my brain
madVR v0.89.1
* added new device "screen config" settings page
* added screen masking feature
* added support for anamorphic stretch
* added new processing "zoom control" settings page
* added automatic detection of black bars with lots of sub options
* fixed: DXVA deinterlacing sometimes produced "DXVA processing failed"
* fixed: profiles: scaling factor wasn't properly reported
* increased seek "black screen protection" to 2 seconds (formerly 1)
gkontoletas
trouble in my brain
madVR v0.89.2
* fixed: one more media player startup crash
* fixed: DXVA deinterlacing and black bar detection didn't like each other
* fixed: DXVA scaling had some problems with v0.89.0 and v0.89.1
* fixed: some media player size/pos zoom wishes were not properly applied
Dragon
