Mac Mini Media Center
Αναβάθμιση για το Plex Media server:
WHAT'S NEW
Version 0.9.9.7:
New:
  • Add a preference to control whether we show notifications.
  • (API) Added /library/section/prefs?type=X for library preferences.
  • Report back product so that web app can show icon for DLNA plays.
  • Support for enhanced streaming when using Chrome.
  • Support sharing even when connecting to plex.tv fails because of NAT.
Fixes:
  • (Synology) Fixed installation on DSM 5.0
  • Fixed an issue where non-direct played Roku video took a long time to start.
  • Fixed syncing RAW photos (for real).
  • Fix a crash in the scheduled task for media analysis.
  • Fix a few cases where web's Now Playing information was out of date.
  • Fix a crash when cleaning bundles.
  • Fix a potential crash when uploading to Bitcasa.
  • Fix an issue when using the new "Disc Image" scanners.
  • Fix an issue syncing large RAW images.
  • Increase number of database sessions, should improve performance.
  • Fix a few miscellaneous field-reported crashes.
REQUIREMENTS
  • Intel, 64-bit processor
  • OS X 10.6 or later
https://www.macupdate.com/app/mac/42311/plex-media-server
Plex Home Theater
WHAT'S NEW
Version 1.0.13:
New:
  • Internal testing showed that Matroska streaming that was announced in 1.0.12 release notes did not work well with aspects of seeking and resuming. It has therefore been disabled while we figure these issues out. You can still try it out by adding on in your advancedsettings.xml but it will not work well with seeking and resuming. You have been warned.
Fixes:
  • Fixed deadlock in "Please Wait" dialog when navigating TV Shows.
REQUIREMENTS
  • OS X 10.6.3 or later
  • Core Duo 2 GHz processor or better
  • Note: Hardware-based video decoding is supported by Mac models equipped with the NVIDIA GeForce 9400M, GeForce 320M, GeForce GT 330M; ATI HD Radeon GFX; or Intel HD graphics.
https://www.macupdate.com/app/mac/27302/plex-home-theater
Gojakla
Αρχαιολάγνος πιουριτανίστας
Lessaros να ρωτήσω κάτι;
Γίνεται update μέσα από το XBMC ή κάθε φορά καταβάζουμε τη νέα έκδοση και ξαναμανασετάρουμε όλα από την αρχή;
Οχι update δεν γίνεται μέσα απ'το xbmc.Κατεβάζεις τη νέα version και με drag and drop αναβαθμίζεις.Τα settings παραμένουν όπως τα είχες και πριν.Δεν ξαναφτιάχνεις τίποτα.
Ξέρει κάποιο ομορφόπαιδο, για ποιόν λόγο στο macmini>xbmc όταν βάζω στα settings/ audio output την επιλογή "hdmi" τραβάει τρελλά κολλήματα; Όταν λέω κολλήματα όχι απλά μόνο στην ταινία αλλά ακόμη και το mouse κινείται με σπασίματα. Όταν όμως βάλω στο audio output επιλογή "analog" όλα πάνε καλά...
Το setup πως είναι?mac mini σε ενισχυτή με hdmi και απο κει σε tv ή και προβολέα?Ποια έκδοση του xbmc έχεις και ποιο λειτουργικό?
Δοκίμασε να απενεργοποιήσεις το auto framerate στα settings του xbmc και δοκίμασε πάλι.Καλό επίσης θα είναι να βάλεις το xbmc gotham 13.0 beta 4.
Θα δοκιμάσω και θα ενημερώσω. Μήπως πλέον το gotham είναι ΟΚ ώστε να περάσω και τα mavericks ή όχι;
Βάλε το Gotham beta 4 και δοκίμασε χωρίς ν'άναβαθμίσεις σε 10.9.2 ακόμη.
Η έκδοση 12.x του xbmc για mac τουλάχιστον,είναι η χειρότερη όλων των εποχών.
Λοιπόν, καλησπέρα :drinks:.
Το Gotham είναι πολύ καλύτερο στη ροή γενικότερα του υπολογιστή παίζοντας ταινία. Εντυπωσιακό το αυτόματο κατέβασμα subtitles, πολύ καλή η επιλογή της διάκρισης των διαθέσιμων settings σε basic, advanced και expert. Ακόμη το ψάχνω, ο διαθέσιμος χρόνος που έχω είναι λίγος.
Σε mavericks δεν πέρασα. Με έχει τρομάξει η διαφορά χρόνου του boot time μεταξύ του 10.7.5 και του 10.8.5 (1 λεπτό το 10.7.5 έναντι 3-4 του 10.8.5), οπότε το καθυστερώ!
Σε κάθε περίπτωση, το Gotham είναι must.
Ευχαριστώ για τις προτάσεις Λεωνίδα!
roque
