Test γνώσεων και όχι μόνο
nima
Banned
(Φίλε ika επιβεβαίωσε ότι είναι ADVENT και ποιο μοντέλο).
Νίκο α) θέλει φρεσκάρισμα, β) θυμάσαι τι κάνουν όλα τα κουμπιά; :p
ika
News
Μοιάζει πολύ αυτό που λές φίλε nima, αλλά δεν είναι αυτό που έχω βάλει. Πολύ πιθανά το ADVENT να είναι το ΟΕΜ αυτού που έβαλα.
Για να βοηθήσω, το δικό μου είναι από αγγλική εταιρεία και εισαγότανε στην Ελλάδα.
Αν θέλετε, το παίρνει το ποτάμι (όχι το κώμα).
nima
Banned
Ο Henry Kloss έφτιαχνε για την ADVENT, KLH & Campridge είναι επίσης σχετικές με αυτόν μάρκες, η κατασκευή πάντως είναι ίδια!
AriPetro
Ο Henry Kloss έφτιαχνε για την...Campridge...
Αλήθεια? Δεν το ήξερα ότι συνεργαζόταν με τη cambridge. Ποια από τις δυο? Την Arcam ή την Cambridge Audio?
ika
News
Και δεύτερο quiz (πιο στρωτό από το προηγούμενο)
Ποιο είναι αυτό το κουκλί;
nima
Banned
Henry Kloss, 72, Innovator In Audio and Video, Dies
By JOHN SCHWARTZ
Published: February 5, 2002
Henry Kloss, an inventor of innovative audio and video components who became a hero to audiophiles, died on Thursday in Cambridge, Mass. He was 72.
The cause was a subdural hematoma, said his son, David Kloss.
Throughout his career, Mr. Kloss (pronounced close) was guided as much by his senses as by his intellect. Loudspeaker manufacturers tend to stress the technical specifications of their products, which is like describing a wine by its levels of alcohol and tannin or a chocolate cake by its caloric content alone.
As an M.I.T.-educated engineer, Mr. Kloss developed formidable technical prowess but avoided marketing by the numbers. Instead, he strove to design equipment for the ear and not the spec sheet, and his products delivered a broad, smooth, clean sound that came to be called the ''Boston sound.''
Mr. Kloss, who was born in Altoona, Pa., and raised nearby, was rewarded by an almost cultlike devotion from those who bought his equipment and who followed his career through many companies and twists of fortune.
He began to build his reputation in 1952, while working at Acoustic Research with Edgar Vilchur, an engineer. Mr. Kloss invented a small revolution in listening, the AR-1. It was the first speaker that was small enough to fit on a bookshelf but could produce rich, deep bass tones. Low sounds are usually emitted by objects large enough to generate the long wavelengths of those notes. Mr. Kloss provided extra power to the low end of the sound spectrum and designed the speakers to accommodate the extra punch without overpowering the rest of the tonal range.
It was only the beginning of a career of firsts. In the 1960's, at KLH, a company Mr. Kloss helped found (the K was for his last name, L and H were his colleagues Malcolm Lowe and J. Anton Hoffman), Mr. Kloss made the Model 8 FM radio. It could pull in stations from a crowded dial -- a feature that came to be known as high selectivity. He also created some of the first successful audio devices to use transistors. He moved on to found Advent, where he created the first cassette tape deck to use the Dolby B noise reduction system.
Then he set his sights on video and designed pioneering projection TV equipment. Mr. Kloss said that he had never watched television until he decided to build one.
When Mr. Kloss decided to serve as the eyes instead of the ears, however, he foundered. Although his systems earned an Emmy for technological achievement, he lost control of Advent and then of a company he formed to sell the TV's, the Kloss Video Corporation, as consumers chose less expensive, simpler Japanese models.
Mr. Kloss returned to audio in 1988 with a company he named Cambridge Soundworks; the $250,000 in start-up capital was provided by a friend, Henry Morgan, a venture capitalist, with a handshake as security.
JAndronikos
