mac users, mac computers & media players...
MakeMKV 1.8.12
What's New
Version 1.8.12:
  • Added support for LPCM streams with variable bit depth
  • Improved handling for discs with mastering errors
  • Better handling for partially damaged streams
  • Bug fixes:
    • FLAC audio streams with large frames were not supported
    • Rarely, program could crash at the end of audio transcoding, usually when processing DTS-HD 7.1 audio
    • Most of DTS-HD LBR (DTS express) streams failed to decode
    • Very very rarely, video frames were silently dropped at segment boundaries
    • DVD: some titles were incorrectly detected as fake
http://www.macupdate.com/app/mac/34693/makemkv
MakeMKV 1.8.13
What's New
Version 1.8.13:
  • Added support for AACS v48
  • Added support for DTS-HD streams with variable bit depth
  • Bug fix: Regression in 1.8.12 - program failed to process multi-channel LPCM audio
Προσοχή:Το πρόγραμμα ΔΕΝ είναι συμβατό προς το παρόν με το OS X Yosemite 10.10 public beta 2.
Αναβάθμιση για το HubFlow τον scraper για τα WD TV media players:
Note to OS X 10.8 users:
Thanks to a new feature (Gatekeeper), HubFlow won't launch directly after downloading, as it is not digitally signed. Please use this workaround for the first launch:
  1. Open your preferences, go to "Security and privacy", then select the tab "General" and choose the last option: "Anywhere".
  2. Launch HubFlow, it should start.
  3. When it's done, go back to your preferences and make sure you select "Mac app store and identified developers" or "Mac app store".
Once it’s done, you will never have to redo this procedure again to run HubFlow.
What's New
Version 1.60: Release notes were unavailable when this listing was updated.
http://www.macupdate.com/app/mac/38127/hubflow
Αναβάθμιση για το Transmit ftp client,ιδιαίτερα χρήσιμο για όσους μεταφέρουν αρχεία από mac σε media player που υποστηρίζει ftp:
Version 4.4.7:
  • Added full-screen mode
  • Improved compatibility with S3
  • Improved OS X 10.6 compatibility
Requirements
  • Intel
  • OS X 10.6.8 or later
http://www.macupdate.com/app/mac/6771/transmit
Αναβάθμιση για το MacPAR deLuxe ένα χρήσιμο utility για όσους κατεβάζουν από newsgroups.Ανοίγει .par .par2 .rar κλπ
Προσοχή η καινούρια έκδοση απαιτεί 10.9 και πάνω:http://www.macupdate.com/app/mac/11858/macpar-deluxe
Version 5.0.1:
  • This version requires OS X 10.9 (Mavericks) or later.
  • The application now processes archives created with rar version 5.
  • Each finished unrar (both successful and unsuccessful) is reported in the notification center.
  • Removed the option to automatically show the unrar result in the Finder; this is now accomplished by clicking the notification.
  • If a rar archive contains just one item, the application does not create an enclosing folder anymore.
  • If the unrar destination already exists on disk, the application now has the option to rename the existing item before extracting the new item.
  • A number of stability and reliability improvements.
Requirements
  • Intel, 64-bit processor
  • OS X 10.9 or later
Plex Media Server update
What's New
Version 0.9.11.1:
New
  • Added Hebrew translation.
Fixes
  • (Linux) A crash on Linux when media directory permissions were wrong.
  • Rapid seeking could lead to video playback stopping.
  • Improved reliability around publishing network connections.
  • Use TLS instead of SSLv3 when talking to plex.tv.
  • (DASH) More reliable seeking.
  • (ReadyNAS) Fix logo not appearing.
Requirements
  • OS X 10.6 or later
Διορθωτική,"πειραγμένη" version του DuneX 0.9.2 με σωστό gui,χωρίς τα προβλήματα με την original version.Τεσταρισμένη σε Yosemite και είναι ok!:thumbsup:
https://www.dropbox.com/s/4ght1v0p7n7nzv8/0.9.2_modified.zip?dl=0
Για όσους έχουν Dune media players,στα preferences του DuneX επιλέγουμε image format jpeg MONO!Αλλιώς δεν κάνει export το πρόγραμμα.Με τις υπόλοιπες επιλογές για media players όπως πχ τα Mede8er όλα είναι ok.
Για το Subler έχουμε ξαναμιλήσει σε παλιότερο post.Αφορά κυρίως όσους έχουνε Apple TV και θέλουνε να βλέπουνε "Nόμιμα";) ταινίες μέσω του iTunes.Είναι χρήσιμο ωστόσο και σε άλλα media players.Στην τελευταία αναβάθμιση έχει καλύτερη συμβατότητα για metadata εκτός των αγγλικών,audio decoders κλπ.Freeware φυσικά.
Subler is a simple mp4 file format muxer. Quickly remux your mkv or mov files to mp4 or add new subtitles tracks to your mp4 file.
The main features are:
  • Creation of tx3g subtitles tracks, compatible with all Apple's devices (iPod, AppleTV, iPhone, QuickTime).
  • Mux video, audio, chapters, subtitles and closed captions tracks from mov, mp4 and mkv.
  • Raw formats: H.264 Elementary streams (.h264, .264), AAC (.aac), AC3 (.ac3), Scenarist (.scc)
  • iTunes metadata editing.
What's New
Version 0.27:
  • Improved queue
  • Improved metadata search for non English languages
  • Added the "Alert Tone" media type and the "m4r" file type
  • Added a way to rename all the chapters to the format "Chapter number"
  • The audio decoders (AC-3, Vorbis, FLAC, DTS) are now bundled with Subler
  • Alert when the save destination folder is read-only
  • Improved validation in the optimize feature
Requirements
  • Intel
http://www.macupdate.com/app/mac/31647/subler
What's New
Version 0.27:
  • Improved queue
Requirements
  • Intel
Διορθωτικό update του Subler:
What's New
Version 0.28:
  • Fixed a crash that could happen when editing a mp4 with an unknown rating tag.
Σήμερα θα βάλω μια αναβάθμιση ενός αγαπημένου προγράμματος με πόνο ψυχής πραγματικά,μιας και είναι η τελευταία και σταματάει πλέον η ανάπτυξη και υποστήριξη του.:(
Το τέλος μιας ολόκληρης εποχής,μέχρι να βγει κάτι καλύτερο βέβαια!;)
Πρόκειται για το Unison τον αγαπημένο newsreader στο usenet (newsgroups) όλων των macusers που σήμερα κυκλοφόρησε το τελευταίο update.
Υπάρχουν και καλά νέα όμως.Είναι απόλυτα συμβατό σε 10.10 (Yosemite) και πλέον free προς όλους!Και όσοι δεν το είχατε αγοράσει ποτέ ή το είχατε με pirate license,κατεβάζετε το 2.2 και είστε πλέον νόμιμοι!
What's New
Version 2.2:
  • End of development, last update for Unison
  • Now free, unlocked for all users
  • Adds multi-connection downloads for much faster transfers
  • Adds a lot more Retina assets for more beautiful browsing on newer machines
  • Fixes many little bugs and quirks
Requirements
  • Intel
  • OS X 10.5 or later
http://www.panic.com/blog/the-future-of-unison/
Unison — our excellent OS X app for accessing Usenet Newsgroups and the many wonders and mysteries contained within — has reached the end of its road after years of faithful service.
First, a brand-new Unison 2.2.
Unison’s end is bittersweet. The market for a Usenet client in 2014 isn’t exactly huge. But if you know Panic, you know we do our very best to never drop things awkwardly — we like to leave our apps in a good place for our (very) valued users.
So we’re excited to release a nice, final update to Unison.
Unison 2.2 adds the #1 feature request for Unison: multi-connection downloads for much faster transfers. It also adds a lot more Retina assets for more beautiful browsing on newer machines, and fixes many little bugs and quirks.
It’s a great update for all Unison fans.
Now free, and unsupported.
While we can no longer work on Unison or offer support for it, the good news is it’s also free. This version of the app will be automatically unlocked for all users, no serial needed.
Just download it right there:
Download Unison 2.2 Now
Unison 2.2.zip (10 MB)
(If you recently bought Unison from us directly in the last month, please e-mail us and we’ll prepare a refund.)
What about Unison Access?
For now, Unison Access will continue to work just as it does today for all current subscribers. That said, we’re no longer accepting new signups. We figure we’ll migrate people to another service at some point in the future. If that happens, we’ll contact you by e-mail.
Thank you sincerely.
Our deepest thanks to each and every one of you who used, bought, or enjoyed Unison. We really enjoyed making this app and providing it to you. We hope it serves you well into the future!
Είναι αυτά τα κινέζικα προγράμματα κλώνοι που βγαίνουν.Η Macgo είναι η μητρική που αναπτύσει αυτό το πρόγραμμα.Καλό είναι πάντως.
Αναβάθμιση για το Handbrake με αρκετές αλλαγές και βελτιώσεις:
What's New
Version 0.10.0:
Core
  • Intel QuickSync Video Encode / Decode support.
    • Windows only currently. We hope to bring this to Linux in the future but not for 0.10.
  • Hardware Decode support via DXVA (Experimental - Windows Only)
    • Decoding of some H.264, VC1 and WMV content via the GPU.
    • Can provide a small improvement on slower hardware. Not suitable for fast CPU's
  • Choice of Scalers
    • Lanczos
      • This is currently Handbrake's default scaler and will remain so.
    • Bicubic (OpenCL) (Experimental)
      • Available on the Command Line (All Platforms) and Windows GUI. (Mac / Linux GUI's will come in a later release)
      • Currently only available in OpenCL form so requires a AMD or Intel GPU supporting OpenCL 1.1 or later. Nvidia GPU's are not currently supported.
      • When downscaling, up to 5% performance improvement can be achieved. No benefit when not downscaling.
      • Small loss in quality over the Lanczos scaler.
  • Denoise
    • hqdn3d filter now accepts individual settings for both chroma channels (Cr, Cb)
    • New NlMeans? denoiser. This is very slow, but results are significantly better than hqdn3d.
  • Presets
    • Added Windows Phone 8 Preset
  • Updated Libraries
    • x264 r2479-dd79a61
    • Libav v10.1
    • libbluray 0.5.0
  • Libavformat is now used for muxing instead of mp4v2 and libmkv
    • "Large File Size" checkbox has now bee removed for mp4, as the new muxer will transition to 64bit files automatically.
    • mpeg2dec has also been replaced in favour of using libav
  • The LibAV AAC encoder is now the default as FAAC has been removed.
    • This encoder is adequate for most, but until it improves a bit further, we have enabled support for the FDK-AAC encoder also.
      • This FDK option is a temporary measure until the LibAV encoder improves.
      • Note that FDK-AAC is much slower and will likely bottleneck the encode process, but will produce better quality audio.
  • H.265 encoder
    • Using x265 v1.4
    • This encoder is still early in it's development, so is missing many H.265 features and optimisations.
  • Added VP8 Encoder (using libvpx)
    • Available in MKV files only.
  • Removed mcdeint deinterlace and decomb modes. This relied on the snow encoder in libav which has been was removed by upstream.
  • Bug fixes and Misc Improvements
Mac
  • Build system updates to compiled under OS X 10.9
  • Automatic audio and subtitle track selection behaviours which can be stored per preset.
  • Improvements to Auto-Naming feature.
  • Misc UI enhancements.
  • Bug fixes
Command Line Interface
  • Basic support for return codes from the CLI. (0 = No Error, 1 = Cancelled, 2 = Invalid Input, 3 = Initialization error, 4 = Unknown Error")
Requirements
http://www.macupdate.com/app/mac/12987/handbrake
Features:
What's New
Version 0.31:
  • Added the Russian iTunes Store.
  • Fixed previews track generation.
  • Fixed a rare crash when importing a .srt file.
  • Fixed an issue where a subtitles track bold style couldn't be exported properly to srt.
  • Fixed an hang when trying to mux an unsupported track.
Requirements
  • Intel
C . papadakis
