VIEWSONIC Pro9000
Led προβολέας, 20.000 ώρες λειτουργίας, DarkChip3 και τιμή κάτω από 1.500€!
  • 0.65″ Digital Micromirror Device (DLP™), 1080p DarkChip3™
  • Resolution
  • 1920 x 1080 (native)
  • Lens
  • 1.2x manual optical zoom / manual optical focus
  • Zoom Factor
  • N/A
  • Keystone
  • Vertical digital keystone correction (+/- 15º)
  • Display Size
  • 38″–150″ / 0.97m–3.8m (diagonal)
  • Throw Distance
  • 4.9ft–16.4ft / 1.5m–5.0m
  • Throw Ratio
  • 1.5:1 ~ 1.8:1
  • Lamp Type
  • LED/Laser Hybrid
  • Lamp Life (normal/eco-mode)
  • >20,000 hrs
  • Brightness
  • 1600 Lumens
  • Contrast Ratio
  • 4000:1 (dynamic)
  • Aspect Ratio
  • 16:9 (native), 4:3, Auto
  • Color Wheel
  • N/A
  • Color Depth
  • 30 bits, 1.07B Color (10+10+10)
  • Color Gamut
  • 85% NTSC 1931 CIE
  • INPUT SIGNAL
  • Computer and Video
  • NTSC M (3.58 MHz), 4.43MHz, PAL (B, D, G, H, I, M, N, 60), SECAM (B, D, G, K, K1, L), 480i and 576i, 480p and 576p, 720p, 1080i, 1080p
  • Frequency
  • Fh: 15–100KHz, Fv: 24–85Hz Video:24-85 Hz
  • COMPATIBILITY
  • PC
  • VGA to 1080p
  • Mac®
  • Up to 1080p (requires MAC adaptor)
  • CONNECTOR
  • Audio Input
  • 3.5mm mini jack
  • Audio Out
  • 3.5mm mini jack
  • RGB Input
  • 15-pin mini D-sub (x2) / 15-pin mini D-sub
  • Composite Input
  • RCA jack
  • S-Video Input
  • 4-pin mini-DIN
  • Component
  • N/A
  • RGB Output
  • 15-pin mini D-sub
  • Control
  • RS-232 (DB-9)
  • Digital
  • HDMI 1.3 (x2)
  • Network
  • N/A
  • USB
  • N/A
  • Mic-In
  • N/A
  • Screen Trigger
  • N/A
  • Card Reader
  • N/A
  • AUDIO
  • Speakers
  • 2W (x2)
  • Amplifier
  • N/A
  • POWER
  • Voltage
  • 100~240VAC (Auto Switching), 50/60Hz (universal)
  • Consumption
  • <186W ±10% / <0.5W (stand-by mode)
  • CONTROLS
  • Basic
  • Power, keystone, arrow, blank, menu, exit, mode, enter, auto, source, volume, info
  • OSD
  • picture, video/audio, setting, options (See user guide for full OSD functionality)
  • OPERATING CONDITIONS
  • Temperature
  • 32ºF–104ºF (0ºC–40ºC)
  • Humidity
  • 10%–90% (non-condensing)
  • Altitude
  • Altitude 0~6,000 ft (1,800m), operational up to 10,000 ft (3048m)
  • NOISE LEVEL
  • Normal
  • 28dB
  • Eco-Mode
  • 22dB
  • DIMENSIONS (WxHxD)
  • Physical
  • 12.6 x 5.3 x 10.2 in. / 321 x 133 x 260 mm
  • Packaging
  • 17.6 x 15.7 x 9.6 in. / 447 x 398 x 243 mm
  • WEIGHT
  • Net
  • 9.4 lb. / 4.3 kg
  • Gross
  • 15 lb. / 6.8 kg
http://www.perfectimage.gr/2014/07/17/viewsonic-pro9000/
για τα λεφτα του αστερι μου ακούγεται!!!!! Αυπαρκτο ρεηνμποου,καλη χρωματικη αποδοση,καλη φωτεινοτητα,ευκρινεια και συστημα LED-LASER με πολλες Ωρες!!!!!Προγραμματιζω ηδη επισκεψη στην PSA να τον δω.
Mε 150€ παραπάνω παίρνεις τον EPSON TW8100 που έχει. :)
σιγα το μαυρο....εξαλλου κατσε να τον δω πρωτα τον VIEWSONIC και θα σου πω.Το προτέρημα εδώ είναι η φωτεινη πηγη,και θελω να δω και τα χρωματα.
σιγα το μαυρο...
Διαφωνώ, αν και δεν έχω δει τον VIEWSONIC.
Αλλά μόνο που είναι DLP καταλαβαίνω τι μαύρο θα έχει. :whistling:
Το μόνο θετικό βέβαια είναι οι 20.000 ώρες που υπολογίζω 10.000.
εγω φιλε μου βλεπω δυο χρονια τωρα DLP με απενεργοποιημενη ιριδα.Τον εχουν δει και παρα πολλοι φιλοι και κανενας δεν καταλαβε τιποτα περι μαυρου.Όταν τους λεω οτι δεν εχει καλο μαυρο,απορουν τι λεω.Ετσι για να εχουμε ένα μετρο σύγκρισης της πραγματικότητας του μεσου θεατη.
ΓΙα να παρεις καποιο μαυρο (ΟΧΙ επιπεδου CRTαλλα καπως καλο)πρεπει να παει κανεις στα τζεηβισια.Αυτή είναι η ταπεινη μου γνωμη.
Συμφωνώ για τους JVC.
Απλά πιστεύω ότι οι EPSON πλησιάζουν πολύ το μαύρο των JVC αλλά έχουν και καλύτερο απ' τους DLP.
καλυτεροι από τους DLP ναι,να πλησιαζουν τους JVC γενικως,όχι κατά την ταπεινη μου γνωμη.Όλα τα μηχανάκια που παιζουν από 1000μεχρι 2,5 χιλιαρικα εχουν μικροδιαφορες.Υπαρχουν αλλα δεν βλέπεις αλλης κλασης εικονα,μια απ τα ιδια λιγο καλυτερα οσο ανεβαινεις.Την ιδια εντυπωση απ οτι διαβασα απεκομισαν και πολλα ατομα από την εκθεση.Το αλμα που ειδα εγω ηταν ο 500αρης που πηγαινε 4 χιλιαρικα αν δεν κανω λαθος,οποτε υπαρχει και αλμα στο κοστος.
Για πες.
Είναι χαμηλότερη κατηγορία, καμία σχέση σε εικόνα με τις σειρές 8 & 9 που είναι άριστες. Ειδικά στο μαύρο, είναι σαν το δικό σου περίπου.
Δηλαδή να μη προχωρήσω σε αλλαγή?
Κάπου διάβασα οτι ειναι πολύ καλύτερος σε 3D
loggeo
Πολύ δύσκολο ως απίθανο, lcd προβολέας να παίζει καλύτερο 3d απο dlp.
Γιατι το λες αυτο?
Καπου διάβασα οτι ο epson σε 3D παίζει στα 480Hz που σημαίνει περισσότερο φως,που ειναι βασικό σε 3D
loggeo
Γιατι το λες αυτο?
Το τρίπτυχο του καλού (αν υπάρχει τέτοιο) 3d εξαρτάται από το φως, την ευκρίνεια, την εξάλειψη του ghosting.
Οι μονότσιποι dlp είναι ασφαλώς πιο ευκρινείς, έχουν πολύ λιγότερο motion blur και λόγω τεχνολογίας αναπαραγωγής ελάχιστο ghosting. Για τη δε φωτεινότητα τι να λέμε; Οι dlp προσφέρουν πολλά περισσότερα lumens, σε βάρος όμως του contrast. Άσε που δεν έχουν και μαύρο.:D Αλλά αυτό το πρόβλημα αμβλύνεται, όταν φορέσεις ενεργά γυαλιά που ρίχνουν 60-70% τη φωτεινότητα.
Τα 480hz του epson δε σημαίνουν περισσότερο φως, αλλά μεγαλύτερη ταχύτητα σάρωσης στην προσπάθεια να περιοριστεί το ghosting, που είναι αναπόφευκτο για τέτοιας τεχνολογίας μηχανάκια.
Andreas79
