Μπορείς από το serial number του Technics SL 1210 Mk2 να βρεις τι χρονολογία κατασκευής είναι?
Μπορείς από το serial number του Technics SL 1210 Mk2 να βρεις τι χρονολογία κατασκευής είναι ξέρει κανένας
Απο ιντερνετ : ''Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.''
Υ.Γ: Το δικο μου 1200 δεν εχει καν serial number.Πως γινεται αυτο??:idk:
δεν γίνετε να μην έχει τσέκαρε στο πίσω μέρος εμενα γραφει GE3CN34420 αρα ειναι στην κατηγορια new format
δες σε αυτό το σημείο
κατω δεξια? Κατι για voltage λεει...
Δεν εχει καν ετικετα εκει που μου δειχνεις.o_O
Μαλλον διπλα στο made in japan ειναι..
εκει που κοιτας αριστερα εχει ενα αυτοκολητο που λεει serial number
SeasideGR is the winner! Ειναι οντως απο κατω.Αποκωδικοποιηστε το μου καποιος...δεν το'χω :hi:
Η αληθεια ειναι οτι αυτος απο τον οποιο το αγορασα,μου ειπε πως το ειχε αγορασει ο ιδιος απο Ιαπωνια (φροντιστης στην ολυμπιακη) εκει καπου αρχες δεκαετιας 80.Αλλα θα ηθελα πολυ να μαθω την αληθινη ηλικια του πικαπ.Ειναι πραγματικα σε τελεια κατασταση.
Βλεπω να φτιαχνουμε thread μονο με σειριακους αριθμους και ερωτησεις ''ποιανου εισ'εσυ?'' :dance2:
JAndronikos
