Zappiti Player 4k
Εδώ με το υπάρχον δοκιμαστικό firmware τα τεστ που έχουν γίνει και τα bugs που έχουν διαπιστώσει μέχρι στιγμής:
1. video files are played so jerky on XBMC/Kodi. Corrected.
2. the Framerate auto does not work on files 25 p and 50 p. The files in question are displayed in 60 p. Planned correction.
3. the 23.976p files are displayed in 24.000 Hz. planned Correction.
4. the 3D subtitles are displayed in 2D. Planned correction.
5. video files encoded in 10 - bit are not supported. Consideration.
6. the change of ratio function does not display 4096x2160p.
7. when using the keys from 1 to 9 for direct access (10-90%), there is a display bug in the timeline.
8. No Direct Outpout HDMI function.
9. the 3D BD ISO files do not play on XBMC/Kodi. Corrected.
10 video playback with Kodi from disk network hard. Planned correction.
11. not supported WMA currently (pending a patch on the Realtek part).
Successfully tested:
-Reading the Ultra HD files and 4K native codec DivX HEVC UHD (fluid)
-Read all files through the network through Zappiti Media Center V4
-Video playback with Kodi (hardware decoding and not only in "hardware acceleration") from an internal hard drive (fluid).
-3D BD ISO (fluid) - Attention! Subtitles displayed in 2D for the moment.
-2D BD ISO (fluid) with the subtitle languages displayed in the list
-DVD ISO (with menus)
-Only M2TS (fluid) displayed subtitles but not language displayed in the list (indexing is in the BDMV structure)
-Structures BDMV - lisbles from Zappiti Media Center V4 - readable since XBMC Pas
-Subtitles PGS (Blu - ray)
-Subtitles DVBSUB (DVB-T/DVB-S/DVB-C)
-.mk3d in full Side-by-Side (fluid)
-.mkv full Side-by-Side (fluid)
-.mkv and .avi in Top-Bottom (fluid)
-.mkv HEVC (fluid)
-.mkv H.265 (fluid)
-.mkv H.264 (fluid)
-.wmv WMV9 (fluid)
-.mp4 DivX 10 HEVC (fluid)
-.mp4 DivX 10 H.264 (fluid)
-.mp4 XviD H.253 Advanced Simple@L5 (fluid)
-.avi XviD H.253 Advanced Simple@L5 (fluid)
-.flac 2.0 24-bit/96 kHz-24-Bit/162kHz (reading depends on the music apps)
-.aiff (reading depends on the apps)
-.mp3 128 Kbps 48.0 KHz 2.0
-Auto-framerate: works on files 24 p, 30 p and 60 p (not yet on 25 p and 50 p files) - Attention! 23, 976p is displayed in 24 Hz for the moment
-DTS, DTS - HD, Dolby Digital Plus, Dolby TrueHD, Dolby Atmos, Dolby Digital (downmix to stereo and bitstream) via Zappiti Media Center or XBMC
Τα πολυπόθητα Zappiti Players 4k επιτέλους έφτασαν στη Γαλλία.
Οπως αναφέρουν οι της Zappiti,αν δεν υπάρξει κάποιο πρόβλημα με το γαλλικό τελωνείο αυτή τη φορά,θα τα εκτελωνήσουν Δευτέρα ή Τρίτη και θα αρχίσουν αμέσως τις αποστολές.
Αντε γιατί θα γεννήσω στο τέλος!:D
Τα τελευταία νέα,θα πρέπει να πω ότι έχουμε μπλέξει με απίθανους τύπους κυριολεκτικά:
Αυτή τη στιγμή το zappiti 4k είναι διαθέσιμο μόνο στην Ινδονησία!
Τα players για όλη την υπόλοιπη οικουμένη βρίσκονται στο Αζερμπαϊτζάν και Πέμπτη βράδυ θα είναι στο αεροδρόμιο στο Παρίσι.Αν δεν υπάρξει κάποιο πρόβλημα με το γαλλικό τελωνείο ή απεργία των οδηγών(!!!) θα ξεκινήσουν οι ταχυδρομήσεις από την Παρασκευή.:gotcha:
Οτι μας λένε σας λέω!:newrussian:
Ειδικά αυτό για απεργία οδηγών που έγραψαν,απ'ότι καταλαβαίνω θα τα στείλουν οδικώς στις χώρες της Ευρώπης.
Οσοι αγοράζετε τακτικά από ευρωπαϊκές χώρες,νομίζω αντιλαμβάνεστε τι σημαίνει αυτό!:cautious:
Αν πάντως κάποιος ζει στην Ινδονησία και μας διαβάζει,ας γράψει εδώ και θα του στείλω τη δνση να το αγοράσει και να ξεκινήσει την παρουσίαση!:D
[2015.01.23] The Zappiti Player 4K units are still blocked at French customs in the Paris Airport due to HDMI verification process. No news from HDMI USA yet but customs contact then regulary to know about the situation.
Και στα δικά μας αεροδρόμια τους ίδιους ελέγχους στην πιστοποίηση HDMI κάνουν; :whistling:
Να συμπληρώσω ότι η Zappiti είναι για όλον τον κόσμο ο "δημιουργός" ας το πω έτσι του συγκεκριμένου player και γι αυτό και όλες αυτές οι διαδικασίες,πιάστηκαν αδιάβαστοι σε τέτοια θέματα,η απειρία βλέπετε.
Εμείς δεν έχουμε δημιουργήσει κάτι ανάλογο μέχρι τώρα και μακάρι να το κάνουμε κάποια στιγμή.Τα ίδια θα είχαμε κι εμείς με το τελωνείο και μάλλον ακόμη πιο πολλά λόγω και της παραδοσιακής ελληνικής γραφειοκρατείας.
Γεγονός είναι ότι πιάστηκαν αδιάβαστοι και έχουν εκνευρίσει και πολύ κόσμο που τους εμπιστεύτηκε!;)
Το γεφύρι της Άρτας λέμε... :)
Εγώ θα γεννήσω στο τέλος,πραγματικά!:D
Το μόνο καλό που έχουν και ομολογώ δεν το έχω ξαναδεί σε εταιρίες media players,ότι τους συμβαίνει,ότι γίνεται,το γράφουν και το λένε στα "ίσα" σε όλους τους φίλους τους,δεν κρύβουν κάτι.
Το θεωρώ θετικό αυτό και κάνω υπομονή!:thumbsup:
Οταν ξεκινούσα αυτό το νήμα,δεν μπορούσα να διανοηθώ σε τι απίστευτες περιπέτειες θα μπαίναμε με αυτό το player!
[2015.01.27] HDMI still not validate. And the players are still blocked at customs.
Manosmathiou
