VU+ DUO 2
Τιμη : 480€
Features:
Transcoding function
Airplay function
Opera browser
HbbTV
HDMI 1.4 connection
HD PIP
Gigabit Lan
Plug and Play support for 2.5 "SATA - Hard Drives
2 x display (VFD and LCD)
WOL
Technical highlights VU+ Duo2
1300 MHz dual-core MIPS processor
1GB Flash
2GB DDR3 DRAM
Gigabit Lan
2 x DVB Common Interface slot
2 x Smartcard-Reader (Xcrypt)
3 x USB (1 x front, 2 x back)
SPDIF audio output optical (digital)
1 x HDMI 1.4 video / audio output (digital)
1 x Scart (TV)
1 x RCA video output
2 x audio output (L / R) RCA (analog)
Plug and Play support for 2.5 and 3.5 "SATA - Hard Drives
unlimited channel lists for TV / Radio
EPG (electronic program guide) support
Support of Bouquet lists
OSD in many languages and skin-support
automatic / manual channel search
DiSEqC 1.0/1.1/1.2, USALS
Power switch
Vu+ Solo 2
TIMH : 310E
The new generation. The Linux-based high-end Twin Tuner Full HD Receiver provides an unprecedented multimedia experience.
Full HD 1080p digital satellite receiver for digital TV and radio programs.
The main feature of the 1300-MHz processor the VU+ Solo2.
Experience high definition TV with your VU+ Solo2.
Airplay feature
Opera Browser
HbbTV
HDMI 1.4
HD PIP
Gigabit Lan
Plug and Play support for 2.5" SATA - Hard Drives
12 character VFD display
External 12 V power supply
Vu+ Solo2 Technical Information:
1300 MHz MIPS processor
256MB Flash
1GB DDR3 DRAM
Gigabit Lan
1 x DVB Common-Interface Slot
2 x Smart Card Reader (Xcrypt)
3 USB ports (1x front, 2x rear)
SPDIF optical audio output (digital)
1 x Scart (TV)
External 12 volt power supply
Power switch
VU+ Solo2 Specifications:
DVB-S2 tuner:
Input frequency range 950 .. 2150 MHz
Signal Level - 65 dBm ... - 25 dBm
Tuner Input Connector F-Type female
Input impedance 75 ohms
AFC + / - 3.5 MHz
QPSK and 8PSK demodulation
FEC Viterbi and Reed-Solomon
Viterbirate 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9
Roll-off Factor 35% Common-Interface:
Common-Interface Power Consumption max. 0.35 A/5V video decoding:
Video Compression MPEG-2 / H.264 and MPEG-1 compatible
Video Standard PAL G / 25 Hz, NTSC
4:3 / 16:9
Letterbox for 4:3 TV-Device Output Digital:
Output Level 0,5 Vss on 75 Ohm
Frequency: 32 kHz, 44.1 kHz, 48 kHz
S / PDIF optical, coaxial (AC3) audio decoder:
Audio compression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main / sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L / R 0,5 Vss on 600 Ohm
THD> 60 dB (1 kHz)
Crosstalk <-65 dB Video parameter:
Input Level FBAS 1 Vss + / - 0.25 dB on 75 Ohm TV Scart:
Output: FBAS, RGB, Ethernet over OSD:
1000/100/10 MBit compatible interface USB:
USB 2.0 connector (3x) LNB power and DVB-S2 Tuner:
LNB Current 400mA max. , Short-circuit proof
LNB Voltage horizontal "no load 19.5 V" 17.6 V at 400mA
LNB Voltage vertical "no load 14.5 V" 11,8 V at 400mA
LNB is switched off in the standby mode, control of the satellite position:
DiSEqC 1.0/1.1/1.2 and USALS - Rotor Control Power consumption:
<13W (in operation, with LNB) Goldwafers.com
<12W (in operation, without LNB)
<0.5 W (Deep-Standby-Mode) Input voltage:
External power supply:
Input:
110-240V AC / 50-60Hz / 1,0 A
Output:
12V = / 3,5 A
Further information on VU+ Solo2:
Ambient Temperature +15 ° C. .. +35 ° C
Humidity <80%
Dimensions (W x D x H): 280 mm x 200 mm x 50
  • 139,4 KB Προβολές: 78
jpaudio
Καλησπέρα. Που έχουν αγοραστεί τα μηχανήματα; Τι γίνεται με την εγγύησή τους; Μήπως η τιμές είναι πολύ κοντά, αν όχι ίδιες, με αυτές του επίσημου δικτύου;
Φιλικά,
Γιάννης
Σφραγισμενοι δεκτες ειναι με 1 ετος εγγυηση.
Οποιος δεν 'καλυπτεται' , ελευθερος ειναι να αγορασει απο τη γωνια που του αρεσει :)
Vu+ Duo 2 , 1 x twin dvb-s2 + 1dvb-t2 = 430E
akoustiklab
